Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Thread Tools Display Modes
Old 07-21-2008, 11:03 AM   #1
I30 stuttering when cold
When I let my '01 I30 (78K) sit overnight and then go to drive to work, it sometimes behaves strangely. When I start driving through the parking lot of my apartment building (obviously slowly) the car does something that I can only describe as stuttering...it's a mild shudder but it doesn't feel like the car is about to stall. Once I get out onto the road it disappears completely. This only happens when the engine is cold and the car has sat over night. I know this is a little vague but any kind of direction to look in would be appreciated.
__________________
2001 Infiniti I30 Luxury
www.cardomain.com/id/mattbg20t
MattB85 is offline   Reply With Quote
Old 07-21-2008, 04:35 PM   #2
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Many variables, tune-up status needs to be given since a bad fuel filter or plugs could be the culprit. 2 bits of knowledge that may help you: Engines require more fuel when cold, on your car this info is based off of the ECTS, and 2nd: The o2 sensors can't work until they reach a certain temperature, so the ECU will always be in open loop mode where it relies on the MAF sensor.
__________________
PM or call 774-766-7462 for SSIMS.
3-bay garage in Massachusetts servicing all your maxima needs
Quote:
Originally Posted by 99BlackMaxMS View Post
I really would hit it, she has nice legs 'n stuff.
KRRZ350 is offline   Reply With Quote
Old 07-21-2008, 05:03 PM   #3
Quote:
Interesting that you should mention a tune-up...the car has 78K and I have no records of a tuneup being done. Maybe it's time for new plugs. However I know that the transmission and coolant have both been flushed on schedule and all other recommended maintenance has been done on time including 5K oil changes with Mobil 1 full synthetic oil. I've also asked about the fuel filter and been told by dealers that it isn't something that's designed to be replaced. Are they wrong? The other thought I had was maybe a dirty IAC valve since as soon as I give the car gas it's fine and the problem doesn't occur on warm starts.
Literally other than this issue this car looks and drives as new. I keep this thing maintained as well as I can so I would hope this is just a minor issue.
__________________
Old 07-24-2008, 05:17 PM   #4
Took the car into the dealer today...the culprit was a bad MAF sensor.
__________________
Old 07-24-2008, 09:27 PM   #5
I was going to say O2 censor and maybe Ignition Coils
__________________
Why mod a POS?
C P Squared is offline   Reply With Quote
Old 07-25-2008, 01:02 PM   #6
Must be the MAF
I had the exact same problem. Turned out to be the MAF. Tried cleaning it, changing the plugs, filters and all, but it did not work. If you know how to use a screwdriver, call DaveB and he'll hook you up with a new MAF for an unbelievable price. Easy to change. Drives like a baby again..
flyingbanana is offline   Reply With Quote
Old 07-25-2008, 06:07 PM   #7
Quote:
I just had the dealer fix it, but I appreciate the information on where to get one cheap.
__________________
Old 08-13-2008, 10:15 PM   #8
This is a very common problem with Maximas. You should search their posts on this subject. For the best prices on anything call Dave Burnett (also known as Dave B.). Do a search and you'll find his contact information.
Teddie18 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
