Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Thread Tools Display Modes
Old 07-16-2008, 03:38 PM   #1
LED's playing tricks with me..
Installed LED's into the tails (4) license plate (2), front lights (2), rear sidemarkers (2), dome, and 3rd led brakelight. All goes well after install.. Looks great..
A couple weeks back my HVAC display starts flickering when I apply my brakes.. This flicker makes it up to the nav screen.. WTF.. Today I hear a light/faint click sound everytime the brake is applied from around the shift console and notice my radio dimming when the brake is applied...
After that issue I have been swapping bulbs and adding load resistors to two of the 4 bulbs in the brakelights.. Im still experimenting with wires to tap but has anyone else had this issue? I know I'm a led feak, but ive only been adding these bulbs two at a time... It seems there might be a tipping point before the car freaks out.
__________________
03 I35: Transgo Shift kit, H&R front drop with Illuminas 2F-2R, Stage 2 LTB, Progress RSB, FSTB, Front Sway ES Poly Bushings, Spark advance, Hyperground kit, Clear front corners, G35 wheelies, Black n Tan Interior, LED rear conversion.
Norkoastal is offline   Reply With Quote
Old 07-16-2008, 10:27 PM   #2
You will hear a click if the car is in park, pressing the brake unlocks the gear shift button. Its pretty loud though so that might not be it. I'm lost on the display dimming, sorry.
__________________
My Cardomain
USA-Spec Ipod Integration, I35 Grille, Rear Spoiler, 32% 3M Tint all around, MTX ReQ5, Profile 1000watt amp, Dual MTX 12's, Directed electronics HD radio, 19" axis wheels, Clear front side markers, OEM side skirts, Complete interior led renovation, Some stickers
trent.davis23 is offline   Reply With Quote
Old 07-16-2008, 11:35 PM   #3
I think thats the noise.. Now I need to swap all the stockers back 1 at a time to solve this mystery.
__________________
Old 07-18-2008, 05:40 PM   #4
Just curious: how hard is it to replace the interior lights (the door & dome) with LEd's? I just replaced the clock LED's last night, and would like to do LED's throughout the cabin.
I'm an LED newb, I know that I will need a resistor, but that's about it
__________________
he Internet wasn't designed for ridicule. It was invented so researchers could share comman data sets at University. It was I tell you.........it was. --Homer Simpson
Keepin it real for the SA!
AcuraLegend is offline   Reply With Quote
Old 07-18-2008, 05:47 PM   #5
Well it sounds pretty obvious that when the LEDs are activated, it's draining the battery voltage enough to cause other battery operated components to be affected as well.
OK.Eric is offline   Reply With Quote
Old 07-18-2008, 06:41 PM   #6
Hmm... I thought actually the opposite. The lack of draw trips the computer into thinking there isnt anything plugged in causing the madness I have been experiencing.. Tonight all the bulbs will be swapped to stock to test.
__________________
Old 07-18-2008, 06:43 PM   #7
Quote:
Thats really the best test you could do.
Old 07-18-2008, 08:08 PM   #8
front 192 leds in headlights were the culprit... They were starting to melt and must have shorted something.. All is well so far..
__________________
Old 07-18-2008, 09:30 PM   #9
Got Projectors?
MetaOrbit's Avatar
Send a message via AIM to MetaOrbit
Yeah, the LEDs in the headlights don't last long. Too much heat. LEDs in the license plate lights don't last long either...that's either heat or voltage spikes. Though my home-built license plate lights with in-line voltage regulator have lasted a long time now.
__________________
:: John ::
2002 Infiniti I35 Sport
"Teach a man to fish..."
MetaOrbit is offline   Reply With Quote
Old 07-19-2008, 11:14 AM   #10
Well thats good that you fixed it. I'm surprised because I thought that LEDs didn't generate much heat.
Old 07-19-2008, 03:18 PM   #11
Got Projectors?
MetaOrbit's Avatar
Quote:
LEDs generally don't (though some LEDs do generate a great deal of heat), but in the headlights you also have to contend with the large amount of heat already being produced by low beams, high beams, running lights, etc.
__________________
:: John ::
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
