Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Thread Tools Display Modes
Old 06-11-2008, 02:45 PM   #1
Minor Spring Mods!!!?@!@#!!11!!
I just got done putting on the Lamin-X and letting the clearcoat on he sidemarkers settle so I put them on and snapped a couple of pics. Comments are welcome!!
__________________
Why mod a POS?
C P Squared is offline   Reply With Quote
Old 06-11-2008, 03:00 PM   #2
Not feelin it.
I like the clear sidemakers more, i guess the S-RT fogs looks a lot better.
Yellow/Amber lights remind me of:
__________________
RobertA32 is offline   Reply With Quote
Old 06-11-2008, 03:17 PM   #3
I'm also taking out the orange dome this weekend. It looks ugly. I'm going to replace them with bulbs that look silver but blink amber
__________________
Why mod a POS?
Old 06-11-2008, 03:21 PM   #4
essential1's Avatar
It's just my opinion, but I dont like it at all. It takes away the class from the car and makes it look tacky. It doesn't flow well. I say, ditch the yellow fog tint and get some capsules or 3000k HIDs. Just smoke the side markers some, and paint the headlight housing and grill to tie it all together.
Again though, it's not my car and if you really like it, keep it and be proud. You might have some other changes coming that will tie what you have done so far together.
__________________
essential1 is offline   Reply With Quote
Old 06-11-2008, 03:25 PM   #5
Send a message via AIM to dineth00i30
i kind of like that idea. i already have 3000k on my fogs but my cornering light is still that ugly oem color and if this make it look yellow i would do this. BTW did you buy a bulk or pre-cut? and how much and where did u get it from?
__________________
If gas prices get any higher, rappers will start drinking it!
35% Front/2 Layers of 20%Rear Tints,ActiveTuning Blue Grounding Kit , 3000k Custom Yellow H.I.D Kit For Fogs, 8000k H.I.D Kit For Headlights, Licence Plate L.E.D's, Hyper White L.E.D's for City Lights, Half Roof Spoiler , Clear Corners With L.E.D's, Roof Vinyl Lip Spoiler Might Come Soon???
"my motto is, just the tip, just for a second to see how it feels" quoted by Feldman
dineth00i30 is offline   Reply With Quote
Old 06-11-2008, 03:34 PM   #6
Quote:
I order it Bulk. They only had precuts for the I35 and it costs almost $200+ for film for the whole front end. I order a piece 16x7. I fit perfectly so I can handle it around the edges and not have to worry about finger prints. It costs $50 shipped for 2 sheets.
__________________
Why mod a POS?
Old 06-11-2008, 05:40 PM   #7
大 陆 弟
n3985's Avatar
Good job, polish the headlights too, looks hazy.
__________________
n3985 is offline   Reply With Quote
Old 06-12-2008, 11:36 AM   #8
Does anyone have pictures of an A33 I30 with 19'' rims?
Thanks,
Chuck
__________________
Why mod a POS?
Old 06-12-2008, 11:48 AM   #9
Sorry man...I'm not feeling the yellow fogs at all. I like the look of clear side-markers as well. I'm glad you like it though. Thats all that matters.
__________________
Quote:
Originally Posted by i30ds
Did you stick your fingers in it?
clayman88 is offline   Reply With Quote
Old 06-12-2008, 02:48 PM   #10
Quote:
I'm trying to make my car as blacked out as possible without smoking the lights or black rims. I just don't like how much the orange/clear sidemarkers standout
__________________
Why mod a POS?
Old 06-13-2008, 11:29 PM   #11
Does anyone have a DIY on taking out the Orange domesin the front lights?
Thanks,
Chuck
__________________
Why mod a POS?
Old 06-14-2008, 07:52 PM   #12
Quote:
Thanks,
Chuck
Similar concept..
http://www.innerbean.com/housecor/clear_HIDs.html
__________________
03 I35: Transgo Shift kit, H&R front drop with Illuminas 2F-2R, Stage 2 LTB, Progress RSB, FSTB, Front Sway ES Poly Bushings, Spark advance, Hyperground kit, Clear front corners, G35 wheelies, Black n Tan Interior, LED rear conversion.
Norkoastal is offline   Reply With Quote
Old 06-15-2008, 07:28 PM   #13
The first thing I did when I got my I35 was take out the corners because I hate orange lights on cars. Its not exactly a simple task, but it can be done by a beginner if done correctly. I should mention that I haven't been able to find amber color LEDs that are bright enough to be seen in daylight, nor have I been able to find regular amber color bulbs that fit in that light slot, but here ya go:
1) Remove headlights (2 bolts on top, and one on the bottom which may require removal of plastic wheel well shields to access screw)
2) Remove the screw on outter end if each headlight (you'll know it when you see it). Heat lights (without bulbs) in oven on cookie sheet to make sealant between clear lense cover and black housing pliable. 300 degrees in the oven for NO LONGER THAN 45 SECONDS TO 1 MINUTE AT A TIME should be sufficient.
3) CAREFULLY pry lense away from housing at outter end (this may require repeated heating if sealant gets hard too quickly).
4) You don't have to completely remove the lense from the front of the housing - pry it away just enough so that you can pull out the amber corner insert. You may have to actually break the plastic amber piece to remove it if its stubborn.
5) Put light back in oven to warm up sealant enough to press lense back onto housing (this also may require heating several times). Put end screws back in place.
6) This is optional, but you should do it to prevent fog build up inside lense in the future: Drill 4-6 small holes in bottom of lense where it meets the housing - be carefull not to drill too far in, as you'll bust through the chrome in the lights themselves. This will allow for water to drain/evaporate in the event that the sealant doesnt completely seal.
Any questions? Zach@gadson.com if you want. I'd be happy to help.
And no, I do not still have the blue bulbs in the headlights. It looked too Honda Civic like...
ZGadson is offline   Reply With Quote
Old 06-15-2008, 09:32 PM   #14
Awesome man, thanks a lot
__________________
Why mod a POS?
Old 06-16-2008, 12:17 AM   #15
These should do the trick for the amber corners... lol at price though
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
You will also need a load resistor to prevent hyperflashing.. 1 for each side..
__________________
Old 06-21-2008, 04:45 PM   #16
Post night time pictures
__________________
2001 Infiniti I30 Luxury
Stock/Elegantly Kept /35% SolarGuard Tints / KYB Struts/Mounts / Megan Racing Springs 1.75 drop / Eurorotor F1 Pads
WTB: [I35 Grille] [I35 17' Alloys]or[18' G35 Coupe Alloys]
Toronto, Canada
PM PLEASE
Quote:
Originally Posted by BadBlackMaxSL View Post
Nissan already has Honda's upscale brand, Acura, and its TL covered. Its called the Infiniti G35x. 306 hp and AWD. Ok, discussion now over.
ShippedOut is offline   Reply With Quote
Old 06-21-2008, 08:38 PM   #17
Quote:
I will after I get the yellow blubs, you can't really tell that they're yellow at night.
__________________
Why mod a POS?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
