Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Thread Tools Display Modes
Old 06-10-2008, 12:37 AM   #1
Send a message via AIM to 2000MaximaSE
White Led's in Clock and HID's PICS
Got bored tonight so i snapped off some pics of my HID kit and clock after i put white LED bulbs in it..
The LED's are from autolumination, type b white led
The HIDs are a 6000k hit and the output is REALLY good with minimal glare
Its hard to get a good night time shot but they are really bright and you can see the color is pretty cool.. The fogs are 4 dollar amber h3 bulbs from autolumination.. They arent is300 yellow but they are more yellow than stock
__________________
Totalled the tricked out maxima now rocking an 01' I30, Almost stock. Im getting old.....
2000MaximaSE is offline   Reply With Quote
Old 06-10-2008, 07:21 AM   #2
I like the LEDs in the clock. Mine are actually out, so I need to replace them. How many LEDs does it take?
ZGadson is offline   Reply With Quote
Old 06-10-2008, 07:44 AM   #3
大 陆 弟
n3985's Avatar
2 LEDs, been too lazy to do the mod even though I already bought the bulbs haha.
So you pop off the center vents from the side, then just life the top piece up and remove clock right?
__________________
n3985 is offline   Reply With Quote
Old 06-10-2008, 08:47 AM   #4
essential1's Avatar
It looks like it was suppose to come that way. I've been meaning to switch to led interior lights for a while. But I know nothing about them what-so-ever and i've been too lazy/busy to research that.
__________________
essential1 is offline   Reply With Quote
Old 06-10-2008, 10:42 AM   #5
Im sold.. Those are 1000 times better looking than stock... Any tips on install??? I would really hate myself for scratching the vents up for swapping a bulb, lol...
__________________
03 I35: Transgo Shift kit, H&R front drop with Illuminas 2F-2R, Stage 2 LTB, Progress RSB, FSTB, Front Sway ES Poly Bushings, Spark advance, Hyperground kit, Clear front corners, G35 wheelies, Black n Tan Interior, LED rear conversion.
Norkoastal is offline   Reply With Quote
Old 06-10-2008, 11:28 AM   #6
I looked on the website but cannot tell which bulbs are required. Can you please let me know?
2001i30 is offline   Reply With Quote
Old 06-10-2008, 02:13 PM   #7
Someone asked in my navigation thread about how to get to the clock. Here's what I posted:
It's easier than it sounds to get to the clock, and you don't even have to take the nav screen out because its not connected to the dash piece at all - just make sure the screen is down when you work on it. Pry off the vent piece (works best to pry with a cloth/flat screw driver on the left side of the vent btwn the dash and vent piece). There are only two screws that hold the top cover on that hides the navigation screen. Unscrew them (they're right in the front and you'll see them when you pull off the vent) and the top dash piece should snap out if you pull it toward you and slightly up. The rest is self explanitory.
Old 06-10-2008, 03:17 PM   #8
Thanks for the info Z... For the folks looking for the bulbs here is the link.. http://autolumination.com/74.htm halfway down look for
Order Neo Wedge Based LED Bulbs (shown above): $2.99 ea.
__________________
Old 06-10-2008, 03:40 PM   #9
Thanks! They look great.
Old 06-10-2008, 05:30 PM   #10
hey! i was wondering about that! I asked somewher before and someone said that the clock didn't have bulbs! (Or LEDs for that matter). but My reading lights, the once close to the sunglass holder are out too. Is there a possibility of a fuse being broken?
McSteve is offline   Reply With Quote
Old 06-10-2008, 07:19 PM   #11
The clock lights are on the same fuse as the dash/gauge lights, and interior illumination (including the map lights) is on its own fuse. It's just a coincidence that they're both out.
Old 06-10-2008, 07:45 PM   #12
Send a message via AIM to dineth00i30
what color are the clock lights from the factory? i've never seen them in my car, when i fist got the car i thaught infiniti is really stupid for not putting a light in there but after a while i realized maybe the bulb is out. this sounds like a good little project for my right now. About hid's, for some reason our non-hid head lamps really dont glare as much as other cars that i ve seen on the road.i actually came straight towards my car and it didnt bother me at all but when im driving at night i can see from the side my car lighting up houses and stuff.
__________________
If gas prices get any higher, rappers will start drinking it!
35% Front/2 Layers of 20%Rear Tints,ActiveTuning Blue Grounding Kit , 3000k Custom Yellow H.I.D Kit For Fogs, 8000k H.I.D Kit For Headlights, Licence Plate L.E.D's, Hyper White L.E.D's for City Lights, Half Roof Spoiler , Clear Corners With L.E.D's, Roof Vinyl Lip Spoiler Might Come Soon???
"my motto is, just the tip, just for a second to see how it feels" quoted by Feldman
dineth00i30 is offline   Reply With Quote
Old 06-10-2008, 08:17 PM   #13
hey i have a green i35 and i put green led in my clock
Max-it-up is offline   Reply With Quote
Old 06-10-2008, 09:55 PM   #14
I have the alien glow thing going on
and this is a pic of my dash, i modified the trim i had in my maxima
Old 06-10-2008, 10:08 PM   #15
Actually make sure you look for
Neo - Wedge LED Instrument Panel Bulbs Type A, B & C
(Note to choose the correct bulb, measure the diameter of the base)
Choose type B and whatever color you want.. I went with super white..
The install is really easy. I found it easier to turn the vents down and put my fingers in there and yank strait out After that you will see 2 screws to remove the top trim. There is no need to remove the clock from its trim. Just turn it around and the bulbs will looks like 2 grey screws.. When you install the new leds make sure you try them out before you re assemble the dash.. There is a 50/50 chance they wont work the first time as the led contacts are polarity specific. If it doesnt work the first time just turn the bulb around.
__________________
Old 06-11-2008, 08:14 AM   #16
Purple might look cool. Im all for things no one else has done.
Red LED = too Pontiac
Blue LED = too ricer
Teal LED = too Chrysler 300m (those even have an analog clock in the dash, too).
Now purple LEDs for the clock, there's an idea!
Old 06-11-2008, 12:49 PM   #17
HHhhmmm... so what you guys are saying is my I35's clock shouldn't be pitch black at night? I guess I am in need of a light source in there. any suggestions.
dragongirl is offline   Reply With Quote
Old 06-11-2008, 12:59 PM   #18
Quote:
Go White LED . Im biased since my license plate and almost every other bulb on my car has been swapped to LED's.
__________________
Old 06-12-2008, 07:53 PM   #19
+1 for white leds in the clock!!!
__________________
SHIFT_Infinitely
Mods:
-Retrofitted Maxima HIDs
-20% tints including sunroof
-White climate control and stereo displays
-Painted grill with silver graphite paint, left infiniti symbol chrome (looks hott)
-Clear front signal markers and headlights.
-791XV with r/s and trunk pop
LOOKING FOR SIDE SKIRTS AND I35 GRILLE!!!
Nakulbhatt87 is offline   Reply With Quote
Old 06-13-2008, 10:21 AM   #20
Does anyone know if these bulbs will work to replace the lights in the reading lamp by the sunroof?
Teecee is offline   Reply With Quote
Old 06-13-2008, 10:33 AM   #21
Quote:
Nope.. I heard thats a custom job... I want to pop the bulb out to see why a standard 194 wont fit... Someone in the 5.5 crowd was selling kits that fit up in the map lights and the courtesy lights ont he doors.. HE hasn't got back to me on the map lights so I dont know if he is stocking anymore.
__________________
Old 06-13-2008, 10:46 AM   #22
^^^ i think paradox systems are selling LED's for our dome lights. im not 100% sure but i think i saw them.
__________________
Old 06-16-2008, 05:05 PM   #23
Ordered the bulbs, followed the instructions found in this thread and installed the LEDs. With the exception of removing a stuborn bulb it was an easy mod. Thansk for the advice and input.
Old 06-17-2008, 08:56 AM   #24
essential1's Avatar
Quote:
So as far as swaping the actual bulb. Is it a direct swap?
__________________
Old 06-17-2008, 10:21 AM   #25
Quote:
Yup.. Once the light is free the new bulbs screw right in.. The rubber cover on the stock bulb is not needed for the led's. They look awesome..
I am thinking I might also try to swap the bulbs in the climate control/radio to match up the clock and the shifter...
__________________
Old 06-17-2008, 11:53 AM   #26
Yes. They look exactly the same as the OEM bulbs. Very straightforward. I had to remove the clock b/c one of the bulbs was sticking and it was easier to get out that way. Otherwise, very easy.
Old 06-18-2008, 10:47 PM   #27
I just did mine. Took 5-10 minutes. Wow, what a difference. Thank you for this post.
Old 08-26-2008, 07:13 PM   #28
Send a message via AIM to AznTran517
weird my lights don't come on but my gauges and dome lights do. I tried puttin new bulbs in but they still not comin on. can anyone help?
AznTran517 is online now   Reply With Quote
Old 08-26-2008, 07:26 PM   #29
Got Projectors?
MetaOrbit's Avatar
