Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Thread Tools Display Modes
Old 05-11-2008, 06:24 PM   #1
Send a message via AIM to dineth00i30
help mee!! (this thread is also open in the 5th gen section)
well i have asked this question before and really didnt get a straight answer from anyone so here i go again.my car(auto) does this wierd thing when im coming to a stop. when im coming to a stop i can see my idle go up and down a couple of times and settle at the normal idling speed on drive.also it idles high(aroung 1200-1500) if i let the car sit for a while eaither at a stop light on drive or on park for a while. few months ago i had a MAF Sensor replaced too. did any of you guys had this problam before and if so what is the problam i am asking from you guys is bcus my mechanic really dont know whats wrong and you guys seem to have more knowledge.
p.s. before i had the MAF replaced it did 50mph at 1500rpm and now it does 50mph at around 1800rpm.
all my modding will be stopped till she is back to normal too. :-
__________________
If gas prices get any higher, rappers will start drinking it!
35% Front/2 Layers of 20%Rear Tints,ActiveTuning Blue Grounding Kit , 3000k Custom Yellow H.I.D Kit For Fogs, 8000k H.I.D Kit For Headlights, Licence Plate L.E.D's, Hyper White L.E.D's for City Lights, Half Roof Spoiler , Clear Corners With L.E.D's, Roof Vinyl Lip Spoiler Might Come Soon???
"my motto is, just the tip, just for a second to see how it feels" quoted by Feldman
dineth00i30 is offline   Reply With Quote
Old 05-11-2008, 08:28 PM   #2
It could be a vacuum leak from a cracked hose...but I doubt it.
This sounds like a gunked up or bad Idle Air Control Valve or one of the connections to it. You should also check to make sure your fast idle cam is fully rotated out of the way with the engine warm.
BTW, the MAF will have little or actually no effect on what RPM's you run at different speeds. If you are truly running higher RPM's at freeway speeds change your ATF. If that doesn't help then have it checked by a technician. Mine runs about 1800 RPM's at 50 MPH.
__________________
1995 Maxima 167k miles
1996 I30 95k miles
maximomo is offline   Reply With Quote
Old 05-11-2008, 08:47 PM   #3
^^^^^ thank you. i decided to leave my car at home as much as possible till im done with finals. then i will do the idle re-learn (as n3958 told me)and also i will check what you said.
btw, i did change the tranny fluid, actually i dropped the pan and changed the filter too but, this problam didnt occur after that it was happening way before but wasnt really bothering me much. but if your car does 5omph at 1800rpm's then i guess its normal.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
