Potential Problem
Potential Problem
Okay, so my wife had the car today and when she returned the:
Check Engine Soon
SLIP
TCS
light came on she said it came on as soon as she exited the highway and turned the overdrive off. When I turn the car off and on the SLIP and TCS light come off but turn back on minutes later. Do anyone of you guys/ladies know what the problem could be?
Thanks in advance
Check Engine Soon
SLIP
TCS
Thanks in advance
I'm almost 100% sure that your coil packs are bad. I have the same problem and I just ordered new ones yesterday. Expect to pay about $300 for all 6, or if you have more time than money you can test and replace only the bad one(s). Look at the 5th gen forum for a write-up.
Thanks for the help.. im goin to run codes and see whats up. Ill see if my mechanic can get the coils.
If my coil packs are bad hop long can I drive untill changing them.
http://forums.maxima.org/showthread.php?t=338587
Well I have an app for monday @ 10a.m to change it out. There was a misfire on cylinder 5 so she was shaking and losing power. Im changing out that coil, the spark plugs, and gettin an oil change also.
HerpDerp1919
09-29-2015 02:02 PM
