Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 03-18-2007, 12:50 PM   #1
Points: 7,244, Level: 56
Points: 7,244, Level: 56 Points: 7,244, Level: 56 Points: 7,244, Level: 56
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Transmission Fluid
I heard from the Infinity service clerk in our area that I35 is using special transmission fluid and replacement could be done only with Nissan transmission fluid. Because drain and fill method replaces only 1/3-1/2 of it at one time they reccomend not to mix different fluids together. Do you have any experience with this and what type of replacement transmission fluid you used.
Really appreciate your reply. Thank you.
osetleo is offline   Reply With Quote
Old 03-18-2007, 01:47 PM   #2
大陆弟弟
n3985's Avatar
Points: 14,324, Level: 77
Points: 14,324, Level: 77 Points: 14,324, Level: 77 Points: 14,324, Level: 77
Activity: 0%
I had my tranny flushed (pan dropped and magnets cleaned) with Amsoil ATF, the shifts have never been smoother, I barely feel them. PM talkinghorse, he is an Amsoil dealer in the group buy section. Also look in the fluids section, there is a sticky about every fluid in our cars, and DIY steps.
n3985 is offline   Reply With Quote
Old 03-19-2007, 06:53 AM   #3
dot dot dot ...
NmexMAX's Avatar
Points: 43,626, Level: 100
Points: 43,626, Level: 100 Points: 43,626, Level: 100 Points: 43,626, Level: 100
Activity: 68.8%
Activity: 68.8% Activity: 68.8% Activity: 68.8%
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Use Nissan "D" Matic.
Infiniti > Infinity
__________________
03 SE 4AT 257whp/245wtq
95 SE 4AT 245k Miles
08 Pathy LE 5.6
Items FS:
FastCat/WB's/Bearings/Dual IM gaskets Rear Progress Springs
NmexMAX is offline   Reply With Quote
Old 03-19-2007, 01:36 PM   #4
Activity: 0%
Transmission Fluid
Quote:
Infiniti > Infinity
Thank you. How much fluit it takes for I35 drain and fill method?
Old 03-19-2007, 02:36 PM   #5
Points: 4,523, Level: 42
Points: 4,523, Level: 42 Points: 4,523, Level: 42 Points: 4,523, Level: 42
Activity: 0%
osetleo,
Im about to flush my tranny too .. . probably gonna email the Amsoil guy later today. Glad to see a fellow San Jose poster .. . there are I30s all over this area.
Chester86 is offline   Reply With Quote
Old 03-19-2007, 04:29 PM   #6
Activity: 0%
Quote:
Originally Posted by Chester86
osetleo,
Chester86,
I don't do flashing in my cars. May be I am conservative but if the tranny in a good condition, I believe, it is easy (and safer) to perform drain and refill vs flashing. You obviously need the second person for flashing to watch the drain (if you are doing it yourself and not in the shop), stop the engine at some time and refill the same amount. Then do it again. So, unless you fluid has a burned smell and dirty, I would not do it.
Do you know where to buy Matic-D ATF online or somewhere else. I hate to go to the dealer.
Old 03-19-2007, 06:54 PM   #7
Activity: 0%
I might go check Winchester Auto over near Hos***ter and Capitol. Ill let you know if they have it.
Old 03-19-2007, 08:34 PM   #8
Activity: 0%
Thank you.
Old 03-31-2007, 10:19 PM   #9
Points: 4,436, Level: 42
Points: 4,436, Level: 42 Points: 4,436, Level: 42 Points: 4,436, Level: 42
Activity: 0%
Kinda late with this, but I found Nissan Matic D fluid at the Nissan dealer in Gilroy at a reasonable price. Most Nissan dealers have it cheaper than Frontier Inf.
__________________
Not as easy as originally perceived.
Malibu Jim is offline   Reply With Quote
Old 04-02-2007, 05:10 PM   #10
Activity: 0%
Quote:
No problem, I changed it past weekend. Bought at Frontier with 15% discount coupon, about $5 per quart. How much it is in Gilroy? I will prepare for the next year. With prices on gas/oil going that high it will be around $10 next year.
Old 04-03-2007, 03:39 AM   #11
Activity: 0%
Sounds good. . i might go check up on this too. Wow a lot of I30 owners in San Jose,CA
Old 04-03-2007, 03:40 AM   #12
Activity: 0%
Been having problems with my suspension . . might have to meet up with one of you guys on a free weekend and see how smooth your cars are running!
Old 04-24-2007, 05:28 PM   #13
Maxima.org Sponsor and Donating Maxima.org Member
Points: 11,615, Level: 70
Points: 11,615, Level: 70 Points: 11,615, Level: 70 Points: 11,615, Level: 70
Activity: 7.1%
Activity: 7.1% Activity: 7.1% Activity: 7.1%
The Nissan-branded ATF (Nissan-matic D, etc) you buy from the dealer is a petroleum-based fluid. Dextron III ATF can also be used as an alternative for 'matic-D.
If you want a synthetic-based ATF, AMSOIL is specifically labeled as meeting Nissan-matic D, J and K specifications. As with engine oils, there's absolutely comparison between a high quality synthetic ATF and their petroleum-based counterparts.
talkinghorse is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
