Transmission Fluid
Old 03-18-2007, 12:50 PM
osetleo's Avatar
Transmission Fluid
I heard from the Infinity service clerk in our area that I35 is using special transmission fluid and replacement could be done only with Nissan transmission fluid. Because drain and fill method replaces only 1/3-1/2 of it at one time they reccomend not to mix different fluids together. Do you have any experience with this and what type of replacement transmission fluid you used.
Really appreciate your reply. Thank you.
osetleo is offline
Old 03-18-2007, 01:47 PM
大陆弟弟
n3985's Avatar
I had my tranny flushed (pan dropped and magnets cleaned) with Amsoil ATF, the shifts have never been smoother, I barely feel them. PM talkinghorse, he is an Amsoil dealer in the group buy section. Also look in the fluids section, there is a sticky about every fluid in our cars, and DIY steps.
n3985 is offline
Old 03-19-2007, 06:53 AM
dot dot dot ...
NmexMAX's Avatar
Use Nissan "D" Matic.
Infiniti > Infinity
NmexMAX is offline
Old 03-19-2007, 01:36 PM
osetleo's Avatar
Transmission Fluid
Infiniti > Infinity
Thank you. How much fluit it takes for I35 drain and fill method?
osetleo is offline
Old 03-19-2007, 02:36 PM
Chester86's Avatar
osetleo,
Im about to flush my tranny too .. . probably gonna email the Amsoil guy later today. Glad to see a fellow San Jose poster .. . there are I30s all over this area.
Chester86 is offline
Old 03-19-2007, 04:29 PM
osetleo's Avatar
Originally Posted by Chester86
osetleo,
Chester86,
I don't do flashing in my cars. May be I am conservative but if the tranny in a good condition, I believe, it is easy (and safer) to perform drain and refill vs flashing. You obviously need the second person for flashing to watch the drain (if you are doing it yourself and not in the shop), stop the engine at some time and refill the same amount. Then do it again. So, unless you fluid has a burned smell and dirty, I would not do it.
Do you know where to buy Matic-D ATF online or somewhere else. I hate to go to the dealer.
osetleo is offline
Old 03-19-2007, 06:54 PM
Chester86's Avatar
I might go check Winchester Auto over near Hos***ter and Capitol. Ill let you know if they have it.
Old 03-19-2007, 08:34 PM
osetleo's Avatar
Thank you.
osetleo is offline
Old 03-31-2007, 10:19 PM
Malibu Jim's Avatar
Kinda late with this, but I found Nissan Matic D fluid at the Nissan dealer in Gilroy at a reasonable price. Most Nissan dealers have it cheaper than Frontier Inf.
Malibu Jim is offline
Old 04-02-2007, 05:10 PM
osetleo's Avatar
No problem, I changed it past weekend. Bought at Frontier with 15% discount coupon, about $5 per quart. How much it is in Gilroy? I will prepare for the next year. With prices on gas/oil going that high it will be around $10 next year.
osetleo is offline
Old 04-03-2007, 03:39 AM
Chester86's Avatar
Sounds good. . i might go check up on this too. Wow a lot of I30 owners in San Jose,CA
Old 04-03-2007, 03:40 AM
Chester86's Avatar
Been having problems with my suspension . . might have to meet up with one of you guys on a free weekend and see how smooth your cars are running!
Old 04-24-2007, 05:28 PM
Maxima.org Sponsor and Donating Maxima.org Member
talkinghorse's Avatar
The Nissan-branded ATF (Nissan-matic D, etc) you buy from the dealer is a petroleum-based fluid. Dextron III ATF can also be used as an alternative for 'matic-D.
If you want a synthetic-based ATF, AMSOIL is specifically labeled as meeting Nissan-matic D, J and K specifications. As with engine oils, there's absolutely comparison between a high quality synthetic ATF and their petroleum-based counterparts.
talkinghorse is offline
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
Pied
09-26-2015 03:29 PM
Quick Reply: Transmission Fluid
