Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-07-2009, 05:04 PM   #281
Another question of my own... I have a 1998 I30 150k miles....today I pulled the cap off my coolant expansion tank and discovered a horrible smelling brown sludge instead of coolant. I will be flushing the system saturday, and Ill see what happens, but just wondering if any of you have run into the same situation. Im worried headgaskets are leaking oil into the coolant (the car does loose a LOT of oil, it seems to all be accounted for on the ground though) and the car is done for. However its never overheated, and the oil shows no signs of coolant, and there is no white smoke. Thoughts?
danI30 is offline   Reply With Quote
Old 10-09-2009, 08:32 PM   #282
Quote:
Originally Posted by n3985 View Post
How did you show her how easy it is was to swap everything out if you couldn't get the headlight out
Remove two 10mm bolt on top, then remove one push tab, 10mm bolt, one Philips screws from beneath the front bumper directly under the fog lights. Pull back undertray, remove 10mm bolt holding fog light housing, remove fog light housing, then you'll see the last and hidden 10mm bolt holding the headlight from bottom.
The bulb you need is D2R, I personally recommend sticking to OEM bulbs for maximum brightness. You'll need to remove the igniter cap, held in by 3 screws, then will have access to the bulb.
Hey man thanks for the reply. My Mom got scared when I started talking about bolts and decided to go to Infinti!
But hold your laughter... they wanted $1000 to replace the headlight!!
They said the ballast was broken... yeah, bull****. So I'm going to end up doing it for her. But I can't find the "D2R" bulb your are talking about on an Nissan genuine parts websites. Can you point me to a link?
Rev. Nathan is offline   Reply With Quote
Old 10-10-2009, 09:35 AM   #283
have a 96 i30 auto. any suggestions on recipe for 300 whp ? so far have a stillen high flow intake , warpspeed y pipe thinking of changing to cattman though .
ericks_i30 is offline   Reply With Quote
Old 10-19-2009, 05:24 PM   #284
brown sludge in coolant
Not 100%, but this was indicative of blown headgaskets when it occurred in my Supra, twice. Another indication - typically when you turn the car off it should draw coolant from the overflow bottle as it cools, with a blown gasket it will push coolant out of the bottle and onto the ground.
Napa used to sell a kit that went onto the top of the radiator and tested for hyrocarbons in the coolant.
__________________
2002 Maxima SE, stock
duanes7 is offline   Reply With Quote
Old 11-08-2009, 11:45 AM   #285
Hey just bought a 96 i30t was just wondering what my best bet would be on where to get an intake and complete ehaust less the manifolds thanks
P.S. I'm new to forums not to cars (infiniti tech) don't need how to's just where to get parts
Metalhead8722 is offline   Reply With Quote
Old 11-08-2009, 05:27 PM   #286
The Dirty Pearl
pmohr's Avatar
If you want more sound, than any intake will work. If you want the best overall power, stick with the stock intake. For aftermarket, the PR CAI is your best bet.
As for an exhaust, you can get them anywhere. Which one to get, that's personal preference. If you've got the money, Cattman is the 'premier' exhaust system out there, really.
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 11-09-2009, 06:02 PM   #287
sorry i should have been more clear by intake i meant intake tube unless you meant that the stock airbox will give me the best power?
Old 11-09-2009, 06:42 PM   #288
The Dirty Pearl
pmohr's Avatar
Best overall power, yes. The stock intake is pretty well designed.
Now if you want to talk about intake manifolds, the 00VI is king.
__________________
Old 11-14-2009, 08:57 PM   #289
Thanks man i appreciate the advice i do perfer the bigger sound of an aftermarket intake so ill probably go that route where can i find that PR CAI you were talkin about?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
