Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-23-2009, 11:59 AM   #81
S_H_I_F_T_
Quote:
Originally Posted by vastmax View Post
this may sound like a dik statement, but have you looked in the FSM? EVERYTHING you need to know to wire these up is in there.
Here's a hint, see what has common ground or a switched ground. Also, since i'm a nice guy, EVERYTHING except the folding function can be tapped in the SECU. That's all the help i'm going to give. I have the exact pins that you need to tap but since this thread has lasted ~2 years, you guys need to figure out how to read a wiring diagram.
That actually does sound like a "dik" statement. if you know how to wire them then why not just help the poor guy instead of giving "hints"?
and you dont need to tap the SECU at all, although it is an option. i have these installed over a year now. wired them myself, puddles come on when any door opens. siganals are functional as well as full power mirror and fold.
the downside is i never was able to find any write-up on them and never did one myself so i wouldnt know where to start without ripping into my doors. point is its do-able without tapping the SECU unless you want to spend the time. and have a clue what you are looking at!
Actually if memory serves the blinkers are tapped at the heads. power for the fold is tapped from front cig lighter. and puddles tapped at the door light located on the door panel. about a 4 hour job if that. hardest part is fishing the extra wires for fold and puddles through the door to the cabin/engine bay.
__________________
R.I.P. 11/14/2009
NJMAX2KSE is offline   Reply With Quote
Old 08-23-2009, 05:41 PM   #82
Send a message via AIM to vastmax
here we go...
sure it's doable without going to the SECU. My point is instead of running wires all over your car, wouldnt it be easier to run them to central spot? Running stuff to the cigarette lighter, sure you can do that, but you have so many other more "correct" options than that.
You really ran the blinkers all the way up to the headlights? wow... Wouldn't you think the signal cables are somewhere IN the car? Did you check in the steering column or anything?
I already gave enough info in the other post, if you dont learn and stuff is always given to you, how are you going to get any smarter?
__________________
vastmax is offline   Reply With Quote
Old 08-24-2009, 12:10 AM   #83
Send a message via AIM to din9lebeRrY
here we go...
Instead of arguing, why not actually help people out? Don't want to waste countless keystrokes explaining? You're doing that already.
__________________
din9lebeRrY is offline   Reply With Quote
Old 08-24-2009, 08:12 AM   #84
大陆弟弟
n3985's Avatar
I understand where vastmax is coming from, many people ask for step by step instructions rather than searching the topic and learning themselves. However, this topic is not something as commonly discussed or easy DIY like "how do I install an intake, change brake pad, retrofit my headlights...".
Most casual modders like me know what an FSM is, but don't know technical details to completely understand it (like the pic I posted on page 2, it's all Greek to me). Therefore in the interest of contributing to the community I would appreciate it if anyone would simply post the pins to tap in the SECU.
(I personally want the wire for the dome light so I may add a relay to it and when I unlock it'll turn on my angel eyes and possible LED puddle lights.)
__________________
n3985 is offline   Reply With Quote
Old 08-24-2009, 08:39 AM   #85
burnurass's Avatar
Send a message via AIM to burnurass
What I did on mine was this: It's not ghetto but it works.
Puddle lights...I just ran the ground and positive wire straight to the puddle light. Running it to the Door lights will not do anything but turn on when your doors are open. This won't give you the puddle light effect when you unlock your doors. KEY: you must run BOTH + and - wires
__________________
03 POLISHED TITANIUM TE/SE 6-speed w/HLSD SOLD
06 OBSIDIAN BLACK G35 Sedan 6speed
burnurass is offline   Reply With Quote
Old 08-24-2009, 08:44 AM   #86
大陆弟弟
n3985's Avatar
Exactly, which is why I need the dome light wire so the puddle lights turn on and off with it, rather than when I open the doors. Not too worried about finding a place for the - wire, but that + trigger I need is essential.
__________________
Old 08-24-2009, 09:03 AM   #87
this is what i meant by my original post. the dome light uses a switch ground. in other words, it has a constant 12v, the ground wire is what switches it on and off. that's why you need to run both positive and negative.
__________________
Old 08-24-2009, 09:36 AM   #88
burnurass's Avatar
That's what I meant, just run both wires UP to the dome light. it'll get the job done and is not very hard to run at all. Run it up the side pillars, then over by the dome light. Around the sunroof to the dome light.
__________________
Old 08-25-2009, 02:25 AM   #89
Send a message via AIM to ZGadson
Is there a way to wire it so that when you lock the car the mirrors fold up, and fold out when you unlock the car? Or do they already do that automatically?
Mod is awesome, but imagine remote control mirrors! How frickin' cool - but pointless - but really cool would that be!!??
__________________
ZGadson is offline   Reply With Quote
Old 10-13-2009, 12:38 PM   #90
Wow....those look pretty sweet!
__________________
-Brian
2002 Trans Am WS.6
355rwhp 368rwtq
BBaker025 is offline   Reply With Quote
Old 10-15-2009, 10:25 AM   #91
for those of you who still cant figure this out, I made something just for you:
Folding Mirror Pinout (The answer you've been looking for)
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
