Got Changer, Need Help 98 i30
Old 05-10-2006, 05:16 PM
96i30azn's Avatar
Hello folks,
I recently bought a 6disc changer for my 98 I30 and want to install it under the passenger seat. http://www.infiniti-parts.com/installation/clarion.htm stated that you cant install it under the seat with dual power seats. However, I know that the i30 limited have dual power seats with the changer under it. Any ideas? Pics would be wonderful.
96i30azn is offline
Old 05-11-2006, 09:56 AM
Donating i30 Owner
HomerMAC's Avatar
Originally Posted by 96i30azn
Hello folks,
well okay there are several routes you can take..well actually 2....
under the seat i paid a custom audio shop 20$ to make a braket and mout it to the seat so it moves with the seat.... i di this cause im finishing up the OEM navi install and i had ot use the single din bose headunit iwth only tape a nd cd changer controls.. thus i put under hte seat cause the able was cut short at junkyard but perfect size for under pass seat and i woudlnt have to go to the trunk each time... but soon i might just move it to the rear... cause im getting tierd of it..
now since you probably have the Cd player in ur dash.... why not just put it in the trunk... its already prewired... so jsut plug it in.. and make a braket form homedepot and put it int he trunk... i mean thats the logical thing to do..
HomerMAC is offline
Old 05-11-2006, 06:53 PM
96i30azn's Avatar
I tried to find the wires in the trunk but can't. I checked both sides, only found antenna and light power wires in different sides. In any case, I'll find out if it's prewired when I take the stereo out. But what was the disadvantage to having under seat? Does it rub the floor?
96i30azn is offline
Old 05-14-2006, 12:39 PM
Tim96I30t's Avatar
Just put the changer under the seat and check for clearance with brackets installed. I had a ten disk under my 96 I30 with heated power seats, but it was not oem.
Tim96I30t is offline
Old 05-15-2006, 08:26 PM
96i30azn's Avatar
Thanks for replies guys, I installed it under seat (in front of the seat motor) flush against the seat, no problems. Mine's not oem either, but its exactly the same dimensions (different mounting brackets) and plugs in w/o cable cutting. Took about 1 1/2 hours to install which includes pulling up the carpet, the seat, and the stereo. Pretty easy in my opinion.
96i30azn is offline
Old 05-19-2006, 02:33 PM
BlackulaI30t's Avatar
Could you , if you have time, send me a pm or email on how you did this install, I would like to do the same but I am not familiar with Nissa/infinit. I am a former acura guy who found a better car in my I30t! Nissan from now on! Thanks.
BlackulaI30t is offline
Old 05-19-2006, 02:35 PM
Also, what brand did you buy for the ten disc changer Tim, and does it work well?
Old 05-21-2006, 08:57 AM
96i30azn's Avatar
eh? how does the control on the stereo displays work out for a 10 disc?
96i30azn is offline
Old 05-21-2006, 06:49 PM
willy431's Avatar
I bought the factory 6 cd changer and install kit from Courtesy Nissan for about $175 shipped. It came with a 20 foot cable that ran from the trunk to the back of the bose, self tapping screws, bracket, and a template to show where to install in the trunk. The bose radio controls the cd changer. Works perfect, factory looks, and took me about an hour.
willy431 is offline
Old 05-21-2006, 10:06 PM
96i30azn's Avatar
heh I paid $50 shipped for my usa-spec scd-n66, didn't come with any useful directions except for the wiring diagram which shows how to plug the harness to the back of the bose. 16' cable brand new, works just like stock
96i30azn is offline
Old 05-31-2006, 02:56 PM
lumo.yi's Avatar
Hi, folks, mine is a 96 I30. The factory CD player does not work (can't read properly). Can I just install a CD changer? Currently I have to use a cassette adapter to play Ipod music. It is not that satisfactory. Thanks!
lumo.yi is offline
Old 05-31-2006, 11:03 PM
96i30azn's Avatar
If your stereo is functioning, Changer should work if installed. You may just need to clean the Cd laser reader thingy.
96i30azn is offline
Old 06-01-2006, 12:44 AM
tyler5619's Avatar
Cd ERR
hey all. i've got an i30t and the cd player is...well, moody to say the least. i stick a cd in, and it tries to read it for about 10 seconds, spits it out and displays "Cd ERR". i have done a little research as to what it might be, and they're all saying to resolder some resistor or something. i have tried the laser cleaner discs, but they don't help. after a while of trying to figure out why it won't read my cd's...i decided to check something. it doesn't even spin the cd when i put it in, as in it tries to read a cd that's not spinning, and that's why it says ERR. what the hell can i do to fix this, aside from taking apart my HU and resoldering a bunch of crap???
SOS!!!
-tyler
tyler5619 is offline
Old 06-01-2006, 07:56 PM
96i30azn's Avatar
Does the motor spin? If not, then check out why its not spinning. If it is spinning, check out why the motion has not made it to the disc.
96i30azn is offline
Old 06-03-2006, 02:10 AM
tyler5619's Avatar
the thing is...the motor works when it wants to. for instance, it was cold and rainy all day today. it worked off and on. yesterday, it was hot and humid. it didn't work at all. what i need to do is a) figure out why the weather matters, b) replace the motor, if thats possible, or c) ditch the !@#$%^&*( bose. i've heard lots of people complain about the bose. when i typed in Cd ERR into google, i got like 15+ pages.
(Bose = ? we may never know.)
RinconI30
06-11-2016 08:25 PM
RinconI30
11-10-2015 10:55 PM
uttadms31
09-30-2015 05:24 AM
jerrod99_se-l
09-25-2015 03:02 AM
Quick Reply: Got Changer, Need Help 98 i30
