Hot Headlight=Burnt Connections?
My left headlight went out the other day so i check it, the whole connection from the bulb to the wires is burnt, not burnt like hey i can fixi t burnt, i mean a pile of melted plastic burnt. all the connections are done for including the bulb, tell me what i need to fix this. Thanks.
This happened to my car when I used some crappy Nokya bulbs off ebay. They lasted a day and a half before they melted the bulb base and harness. I ended up replacing the harness with a better one and got different bulbs.
The stock wiring is not meant to handle the high voltage of the start-up for your HID kit (assuming from your sig). After you replace your stock wiring use relays and wire your HID's directly to the battery.
This will allow you to control the lights with the stock switch, but draw power from the battery instead of through the stock harness.
jmlee44
10-02-2022 02:13 PM
tarun900
19
12-20-2021 06:57 PM
doctorpullit
10-28-2019 10:58 PM
