What type grit to use to sand fog housing?
So I used touch up spray paint on my bumper and left some paint residue on the fog lights housing, which is the glassy part. What type grit should I use to remove the paint without scratching the glass? 200? 400?
If it's really glass and not plastic, a new razor blade will work perfectly. Sanding will scratch glass & plastic, no matter the grit number.
If it's actually plastic, I would try a rag with a little gasoline on it first. Test a small area of the lens first to see if there are any negative effects and then it should do the trick.
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Calabar
10-05-2015 09:57 PM
