Blinker is blinking very fast
Old 03-31-2005, 10:10 AM
KNYFE's Avatar
Hey, I changed out my rear blinker bulbs for LED's and now it is blinking VERY fast. Anyone know why or how to change it?
KNYFE is offline
Old 03-31-2005, 10:24 AM
skeetch's Avatar
Edited for too much Blah Blah Blah.....DMvd pointed out below (need to match your current draw with the stock bulbs).
More info here;
http://www.bettercarprices.com/corve...206166060.html
skeetch is offline
Old 03-31-2005, 11:34 AM
MaDMvD's Avatar
Did you use resistors? 'Nuff said.
MaDMvD is offline
Old 03-31-2005, 12:59 PM
Conecarver
BEJAY1's Avatar
I know nothing about LED's but my wife's Jeep had that problem with bulbs and it was a short between the bulb and the harness.
BEJAY1 is offline
Old 04-01-2005, 06:33 AM
Dr.Monkey1313's Avatar
BEJAY1: I did the same and here is what I id to correct the problem and get the LED bulbs back to the normal speed. Very easy to do. Buy one for each side and install. Problem solved.
www.superbrightleds.com
RL-650 Load Resistor kit
6 Ohm, 50 Watt load resistor kit
Solves most LED turn signal problems
Connect one across each LED turn signal bulb to simulate filament bulbs
$ 4.95
Dr.Monkey1313 is offline
Old 04-01-2005, 07:17 PM
illmortal's Avatar
LEDs dont draw as much power.... so it doesn't have to build energy for it to light up an LED... I wouldn't mind having a fast blinking turn signal, as long they are LEDs (fast on and off, instead of phasing out and on)
illmortal is offline
Old 05-22-2012, 10:04 AM
corbryant's Avatar
$ 4.95
You just install a load resistor on each side of the car? Or each bulb? I replaced front and rear signals with LEDs and the website is telling me to add a resistor at each bulb. Is that right? Or do I just install a resistor on each side at only one bulb?
corbryant is offline
Old 05-22-2012, 11:23 AM
VQ'rInWLA's Avatar
Resistor on each bulb
VQ'rInWLA is offline
Old 09-08-2012, 10:46 AM
corbryant's Avatar
Thanx. I finally got the lights out of the back and I just got back from Radio Shack with resistors. Didn't want to wait for em to come from the online store. Don't know wtf I was thinking, but I came home with .50 Ohm 5 watt resistors instead of 50 watt 6 Ohm. Wired one up and the light didnt blink at all. LOL Duh.
On my way back to Radio Shack. I'll eventually get this done.
06-06-2017 02:01 PM
220k+ A32
09-23-2015 03:38 PM
pears
09-18-2015 05:25 AM
BrandonCause
09-14-2015 10:41 PM
dcardello
09-03-2015 11:44 PM
Quick Reply: Blinker is blinking very fast
