Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-04-2004, 04:20 PM   #1
1996 I30: How many Oxygen sensors do I need?
I have 96 I30 and it looks like the oxygen sensors are bad. Two weeks ago, I had check engine light cleared, now, it came back. Even worse, I can feel the mileage is bad. Went to AutoZone today, they said I need one front and one rear for 79.99 each. Then I call advanced autopart, they told me there are two front sensors and one rear sensor. On http://www.oxygensensorwholesale.com..._1996_i30.html, it lists four oxygen sensors for this car. I am confused now. How many O2 sensors does car have? Is it easy to replace them?
Thanks for your advices.
jj_online is offline   Reply With Quote
Old 12-04-2004, 05:40 PM   #2
I believe there are three oxygen sensors. One is in the front, sort of visible from the hood, another is closer to the firewall, and the third is in your cat.
Oxygen sensors affect your emissions and nothing else. That being said, if you are noticing bad mileage it shouldn't be a result of a bad O2 sensor, it's probably something else. There's no reason to put off replacing it, but the only time it is absolutely necessary (as far as I know, and I could be wrong so someone else can feel free to correct me) to replace it is when you are getting an inspection where your emissions will be tested. I don't know if it is the same in your state as it is here in MA, but emissions are tested every other year during an inspection, or upon transfer of ownership or re-registering the vehicle.
As far as I know, it is fairly easy to replace these sensors though I have never done it myself. I think for at least one of the sensors, you may need a jack or something because it is hard to get at. Also, try to find out which sensors you need, you might not need all three though many people replace them all at the same time regardless. Good luck!
infintishock is offline   Reply With Quote
Old 12-04-2004, 06:26 PM   #3
3 sensors total, 2 fronts and 1 rear.
and like infinitishock said you should find out which one(s)
maxmiles is offline   Reply With Quote
Old 12-04-2004, 06:48 PM   #4
I30tMikeD's Avatar
Points: 23,095, Level: 93
Points: 23,095, Level: 93 Points: 23,095, Level: 93 Points: 23,095, Level: 93
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to I30tMikeD Send a message via Yahoo to I30tMikeD
3 total. one on each bank of the y-pipe and one on the cat. I doubt they are all bad. Just replace the ones that are bad.
A bad o2 sensor can affect gas mileage. But it will not effect performance in open loop operation (throttle above 50% of so). It will only affect the car in closed loop operation. That is the only time that the ECU uses the o2 sensors to adjust the air fuel ratio.
The front 2 sensors are fairly easy to replace. If you have an aftermarket y-pipe they are even easier. I suggest getting the OEM replacement ones from oxygensensors.com
I30tMikeD is offline   Reply With Quote
Old 12-04-2004, 06:50 PM   #5
I30tMikeD's Avatar
Activity: 0%
Screw was in the wrong spot
Old 12-08-2004, 08:23 PM   #6
Ok, as I understood there are three sensors on this car, two are in front of catalyst converter, one after it. Using OBD scanner, I got P0130 (front O2 sensor, bank 1), P0136 (rear O2 sensor, bank 1) and P0325 (knock sensor). which is which? I am still confused. Should I replace both sensors in front of catalyst converter, or the one after it and one before it? Please advice.
Old 12-08-2004, 09:02 PM   #7
I30tMikeD's Avatar
Activity: 0%
you need to change one of the front o2 sensors and the rear o2 sensor that is on the cat. Don't mess with the knock sensor until the o2 sensors are fixed, the knock sensor code may go away
Old 12-08-2004, 09:07 PM   #8
Points: 7,984, Level: 60
Points: 7,984, Level: 60 Points: 7,984, Level: 60 Points: 7,984, Level: 60
Activity: 0%
Send a message via AIM to anton9881
I got a "Bank 1 Sensor 2". Is this the one on the left of the y-pipe or the right?
anton9881 is offline   Reply With Quote
Old 12-09-2004, 07:14 AM   #9
I30tMikeD's Avatar
Activity: 0%
I believe bank one is the rear bank. Left or right is subjective to how you look at it....the rear bank is the part of the y-pipe that goes to the rear manifold.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
