2000 I30T - disconnect battery
2000 Infinity quit on the road - the dashboard went black and the engine stopped.
Mechanic changed the battery and tells me it would be fine. I disconnected the battery on a running engine and it dies. Should the car continue to run when battery is disconnected?
Originally Posted by HomerMAC
but isnt the power comming from the alternator..? once the enine is running..?
On my old 98 SE, my brother in law dented the rear. When I got it repaired, the shop did not tighten the battery which I found out when I hit a speed bump. The cable lost its connection and the car died. After I found the problem and tightened the battery cables, the car started right up.
HOW IS THIS POSSIBLE???
One time the alternator in my girls car died so what we did was drive another car behiind her, put a fresh batt. in her car when her car died just changed the batt with the good car's batt while still running and never died, we kept doing this until we got home.
Your dashboard going off and then shutting off is a common symptom of your alternator going bad. You might want to check it.
TKHanson
11-24-2018 01:39 AM
bigfrank
10-01-2015 12:51 PM
maxima297
09-30-2015 03:32 PM
