I30 Brakes
I30 Brakes
Hello everyone,
I have a 96 I30 and Im on my second set of front rotors which have warped on me. I am strating to wonder if the diameter of those rotors is too small for the weight of this car which causes excessive heat. Now my brakes are not sharp, they are the worst of all cars I had even tho I have drilled rotors. My rear rotors barely brake at all, is there a way to adjust brake bias in 96' ?
My quiestion is, which rotors and brake pads are you guys driving on? which should I get next because its time to change them, they shake the car too much during braking.
any info would be appretiated
regards, Bart.
regards, Bart.
**** dude i would take it to the dealer, they'll def know whats going on. i thought i had brake probs, big tado wound up just being my neons confusing the abs. Besides that i had a whole in my master cylinder, very small, i would just take it to the dealer. u may have the wrong pads on or the wrong rotors, very possible. they would def know though.
Don't go to the dealer...and please don't get neons either.
No, we cannot adjust the bias on our cars.
I have never warped a rotor on my car and I have never seen anything to suggest that the size of them is not large enough for our car. The drilled rotors might be your problem.
hey man when it comes to sumthing as serious as the brakes to me itds worth the extra cashi of having it checked out by ppl who know the car best. BUT i wouldnt get work done by them. Rip off like no tomorrow
I actually agree that getting it looked at by a shop is a good idea sometimes, but getting the work done is another thing....especially if it is the dealer. **Most of the time there will be extra work recomeneded that does not really need to be done, trust me I used to work sales an an automotive repair shop
Originally Posted by skorpio
Hello everyone,
regards, Bart.
regards, Bart.
no problems at all for me in my 96 I30.
it did get firmer. my brakes felt weird to me b/c i had been used to the brakes in my moms car. she has a volvo s80, so that thing has a sensitive *** break and stops so fast.
I hate the brakes on my car so much. when the OD is on the breaks are all pressure sensitive. i know you are thinking like duh, but i was reading the manual on my car cause i was bored, and it said that the brakes are like diff. my ABS kicks in my faster with OD on then OD off. When my OD is off its like normal breaks, but with OD on, the pedal goes to the floor much faster when stopping per foot then with OD off. i dont know it seems very weird to me, and i dont like it. ill have to look again to see exactly what it says.
I agree the dealer is a rip off, sumtiem they ssay they replace parts when they only clean up thre parts and fix em and put em back in. thats why u should always ask for the parts that they have replaced.
Originally Posted by SuBXeRo
it did get firmer.
thanks for reply
regards, Bart.
Spongy pedal and rear almost doesnt work. To engage ABS on dry surface is almost impossible.
regards, Bart.
well i can floor my pedal if im stopped int he drieway withthe czar off and then i pump it and pressure builds, and when the car is on i can bottom out the breaks while in park, i hate that i bottom it so easily to, try with ur OD on and your OD off youll notice a diff int he brakes
My dear SKORPIO,
as for me, i'm using 2002 I30 (in Thailand tho). I know, for real, that the original breaks that equiped with all NISSAN's/INFINITI's $uck!!! PPL all over Thailand know this fact. and you should amid this fact too. the good way to solve this problem is very simple but not "THAT" simple. here is the way i do it. I got sick of my breaks too, so i went out to second-hand-market (THAILAND) and search for a better solution. I found out that the NISSAN SKYLINE GTR R32 break set would do the job!!! see, our "INFINITI's" are nothing compare to the GTR (japanese spec would be originally 280 hp out of the voom). So i got the whole set! with a little mod and it will fit perfectly! you don't have to go "BREMBO" nor "ENDLESS" all those expensive stuffs. that's kinda wasting ur $. biger rotor w/ bigger grills on the rotor's rim would release the excess heat perfectly! REMEMBER, i said the whole set, meaning w/ calipers. these calipers are monsters! once u floor the break pedal...u might fly thru ur windshield. I'm using it and happy with it. try it. it's worth the try. for me i got this set for only 500 bucks!!! and it's great!!!! (in THAILAND, u can get any good cheap parts. ONLY IN THAILAND!!!)
SKORPiO,
If I stepped on my brakes and they went to the floor I would have them looked at by a good mechanic. It dosen't have to be the dealer just a reputable shop should be able to do a good job on brakes. Don't take any chances with brakes.
Vince
Vince
regards, Bart.
Originally Posted by vincel
SKORPiO,
Vince
Vince
I can bottom out the pedal after Ill apply quite a bit of force. It is rubbery enough to bottom out, but just like Ive said, I need to really step on it. I have never had a car where something like this took place. Maybe its just me wigging out or maybe there is a problem..... but Im a cheap m**f**er and Ill probably never gonna see a car mechanic. Ill probably waste a lot of time and figure it out by myself
regards, Bart.
Originally Posted by SKORPiO
From what I understand, its not exactly a bolt-on installation. What does it take to install this set? Are there any custom brackets necesary? What about abs sensors? Does master cylinder and abs module stay the same?
regards, Bart.
regards, Bart.
another thing is the hand break, see, our cars are FF not FR. so replacing the break set in the back will take away the handbreak thingy too.. what u do is to buy an add-on hand break set. and that's it.
For the ABS....i don't know about u and the law there. but for me, i don't need that thing. cuz in panic u don't steer away any way. u just ram!!! so....ABS or no ABS...don't make any different for me.... but know this, all the RACE cars on the track don't have that system
OH if u have this set on (GTR r32+) you have to change ur wheels to anything bigger than 17"
yes there will be some custom parts. that would be (i don't really know how to call it in english tho) the arms holding the calipers. the original one won't be long enuf. for me i have the steel outlet (in Thailand) made just for me in aluminum. that is how u hold it in place since the rotor is bigger and all.
Thank You for all the info, I really appretiate it.
regards, Bart.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
