Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 05-28-2003, 06:57 PM   #1
Does anyone know how to program a key fob?
Does anyone know the procedure on how to program a new key fob on a 98 I30?
infinitiman96 is offline   Reply With Quote
Old 05-28-2003, 07:12 PM   #2
Says.."No mo Maximas for me!"
Points: 9,756, Level: 66
Points: 9,756, Level: 66 Points: 9,756, Level: 66 Points: 9,756, Level: 66
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to max5spd
Why pay $40-$50 for Nissan or Infiniti to program your keyless entry remote when you can do it for FREE? You can do it yourself with step-by-step easy to follow directions.
Reprogram Key Fob
QX4, 1997-2001 Q45, I30, 1999-up G20
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
Note:
Key should be withdrawn from ignition key cylinder completely each time.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Push any button on the new remote controller once. (The hazard warning lamp will then flash)
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
Note:
-If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 "Additional ID code entry" for each new remote controller.
-Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Reprogram Key Fob
J30, 1994-1996 Q45, 1994-1996 G20
2. From the door switch unlock the trunk.
3. Insert and remove the key from the ignition key cylinder six times within 10 seconds.
Note:
-Key should be withdrawn from ignition key cylinder completely each time.
-At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Manually unlock and lock the driver side door
5. Push any button on the new remote controller once.
If there is only one remote controller skip step 6.
6. Additional ID code entry
Repeat step 4 and 5
7. END.
Note:
-If you need to activate more than two additional new remote controllers, repeat the procedure on step 6 "Additional ID code entry" for each new remote controller.
How do you program a new ignition key with chip?
Unfortunately, that can only be done at the dealer. To program the key it is necessary to have a Infiniti Computer and a special program and password.
Using eBay for GOOD, not evil!
I hope that you find this information helpful - and that it keeps you from being ripped off by eBayers trying to sell you FREE information. eBay rules REQUIRE that I offer something to sell... so, to remain in compliance with eBay rules, if you bid on this auction and win I will email you a copy of these instructions... if you do do not agree with the Shipping and handling terms and price, please do not bid!!
__________________
1991 Charcoal Maxima GXE (Auto) - SOLD
1993 Black Emerald Maxima SE (5spd) - SOLD
1997 Bordeaux Pearl I30t (5spd) - SOLD
2002 Gray Lustre Maxima SE (6MT) - SOLD
2007 OBP Subaru Forester Sports XT (5spd)
Yes, it's not a Maxima
max5spd is offline   Reply With Quote
Old 06-21-2008, 10:06 PM   #3
I know this is an old thread but I am trying to do this on my '01 I30 with a keyfaub I bought off ebay that is suppose to work for this model. The key faub says Nissan on it. HERE is the ebay link. When I do step 4, nothing happens. I do not get the hazard flash like I thought I was suppose too. I have tried doing step 3 where I turn the key and only the radio is on and also turning the key and the dash lights come on but still no luck with step 4. I have replaced the battery in the remote also. Any thoughts.
Teecee is offline   Reply With Quote
Old 11-19-2008, 03:44 PM   #4
Quote:
Originally Posted by infinitiman96 View Post
Does anyone know the procedure on how to program a new key fob on a 2000 I30?
bonanza is offline   Reply With Quote
Old 11-19-2008, 03:45 PM   #5
does anyone knows how can i program the key fob on my 2000 infiniti i30?
Old 11-22-2008, 08:39 AM   #6
Points: 2,134, Level: 27
Points: 2,134, Level: 27 Points: 2,134, Level: 27 Points: 2,134, Level: 27
Activity: 0%
See above - and make sure that you have the right key fob. Some of the ones offered on ebay are incorrect. The most common FCC number is KBRASTU10.
__________________
'01 Millenium Jade Infiniti I30t w/Sport Pkg.
Tri-C is offline   Reply With Quote
Old 12-04-2008, 04:29 PM   #7
Points: 2,624, Level: 31
Points: 2,624, Level: 31 Points: 2,624, Level: 31 Points: 2,624, Level: 31
Activity: 0.3%
Activity: 0.3% Activity: 0.3% Activity: 0.3%
Send a message via AIM to Barada
I got the same problem.. i cant get past step 4.. i have the right FCC.. it the original remote too.. the kid i bought it off (the car) said the remote lost the code needs a reprogram.. soo i need some help on this too. i got a 2000 i30t
Barada is offline   Reply With Quote
Old 03-14-2009, 05:00 PM   #8
These instructions worked for me; programmed 2 remotes using them.
Click the image to open in full size.
__________________
No more I35
ridinwitha35 is offline   Reply With Quote
Old 03-14-2009, 06:13 PM   #9
NSMO240's Avatar
Points: 3,637, Level: 37
Points: 3,637, Level: 37 Points: 3,637, Level: 37 Points: 3,637, Level: 37
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Send a message via MSN to NSMO240
you dont have to unlock the doors, you just hit a button on the second or third key fob, the lights will flash for every different key fob programmed, up to 4.
__________________
99' Maxima SE-L-VQ30DEK S/C
01' Pathfinder SE-VQ35DE
13' Optima SX-G4KH
Quote:
Originally Posted by aackshun View Post
This man knows what he's talking about, he owns a SE-L.
NSMO240 is offline   Reply With Quote
Old 06-01-2009, 01:26 PM   #10
KEYLESS ENTRY
HELP?
Can you program an old QX4 key fob to an I30? If not how likely will a new Key Fob purchased from Ebay or online somewhere work? Any help will be nice. Thanks
infinitiandbeyond is offline   Reply With Quote
Old 06-01-2009, 02:05 PM   #11
NSMO240's Avatar
Activity: 1.8%
Quote:
Originally Posted by infinitiandbeyond View Post
HELP?
no, because the QX4 key fob does not have the trunk open button, if you get one from ebay make sure it has lock on top, then unlock, then trunk open, then panic.
__________________
13' Optima SX-G4KH
Old 11-08-2010, 05:17 PM   #12
Does anybody knows how to program a new remote on a maxima 2003 or idont know if its possible or will need to be done at the dealer.
superior82 is offline   Reply With Quote
Old 04-02-2012, 10:42 AM   #13
Points: 1,739, Level: 24
Points: 1,739, Level: 24 Points: 1,739, Level: 24 Points: 1,739, Level: 24
Activity: 0%
Thx so much for the write up. The service man looked at me like i was crazy when i said i'd program it myself.
__________________
Mods.. DDM 6000k H.I.D. kit, Custom S.R.I.
Quote:
Originally Posted by MoncefA33 View Post
Modding is whatever you define it as.
Some people wanna boost, some people need 10 TVs, and some of these homos feel compelled to LED their cars front to back.
Maxima sold 8/18. Bitter sweet day.
F35-JSF is offline   Reply With Quote
Old 04-20-2012, 01:36 PM   #14
Points: 1,033, Level: 17
Points: 1,033, Level: 17 Points: 1,033, Level: 17 Points: 1,033, Level: 17
Activity: 0%
Reset on key fob
I picked up a 1998 key fob from a wrecker and was successful on resetting it to my 1998 Maxima using the reset directions. Thanks for the help.
Thor4 is offline   Reply With Quote
Old 08-22-2012, 01:42 PM   #15
Points: 520, Level: 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
2002??
Will these work on a 2002 maxima?
Ian02MAX is offline   Reply With Quote
Old 09-20-2012, 07:26 PM   #16
Points: 86, Level: 1
Points: 86, Level: 1 Points: 86, Level: 1 Points: 86, Level: 1
Activity: 0.8%
it should work on your maxima with out issues..
jcbl426 is offline   Reply With Quote
Old 11-11-2012, 08:16 PM   #17
Points: 10, Level: 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Activity: 0.3%
i have tried this numerous times and i checked the part number on the key pad and it is a nissan keyfob is there any other way to program the key pad without paying
linsdeyb76 is offline   Reply With Quote
Old 11-11-2012, 09:01 PM   #18
Points: 2,388, Level: 29
Points: 2,388, Level: 29 Points: 2,388, Level: 29 Points: 2,388, Level: 29
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
michael.m.criscione miccris93
Didn't want to make a new thread for this question, but does anyone know if like the I35 remote would work for an I30? Like for a 2002+ Maxima. Just in case I need a new remote in the future and I kinda like that one more than the ones I have.
__________________
2000 Infiniti I30 ; Aspen White Pearl exterior / Beige interior
OEM All-Weather Mats, LED Conversion, LED Taillights, Infiniti I35 wheels, Nissan Cefiro Dash Piece,
Pioneer AVIC-Z140BH, OEM Rear Spoiler, Klearz Clear Side Markers, DDM Tuning 5000k HIDs
Instagram: miccris93
MaxMike93 is offline   Reply With Quote
Old 11-12-2012, 11:55 AM   #19
Points: 14,491, Level: 78
Points: 14,491, Level: 78 Points: 14,491, Level: 78 Points: 14,491, Level: 78
Activity: 58.8%
Activity: 58.8% Activity: 58.8% Activity: 58.8%
Quote:
Just because it is a Nissan key fob remote doesn't mean squat. Nissan changes the key fob remote frequency from time to time, so what works with one year doesn't always work with the next year car.
For reasons like this, it is MANDATORY that you tell us the year and model of your car.
DennisMik is offline   Reply With Quote
Old 11-12-2012, 12:06 PM   #20
Activity: 58.8%
Quote:
Unfortunately, the answer is no.
There are 2 different remotes for the i30, one for 96 to 99 and another for 2000 & 2001. In 2002, a 3rd remote was used for the i35 and Maxima.
Old 11-14-2012, 02:05 PM   #21
Points: 4,563, Level: 43
Points: 4,563, Level: 43 Points: 4,563, Level: 43 Points: 4,563, Level: 43
Activity: 8.8%
Activity: 8.8% Activity: 8.8% Activity: 8.8%
UPSXPRESS
I have a fob that works on and off, I replaced the battery too and that did nothing. I'm guessing this will make it work?
__________________
96 I30
Ebay Headers + Y-pipe
Cattman Cold Air Intake
Tokico HP Blues/Eibach Pro kit
25mm Eibach Pro-Spacers
D I R T Y I 3 0 is online now   Reply With Quote
Old 11-14-2012, 02:10 PM   #22
evil voices in your head
Amerikaner83's Avatar
Points: 6,128, Level: 50
Points: 6,128, Level: 50 Points: 6,128, Level: 50 Points: 6,128, Level: 50
Activity: 99.7%
Activity: 99.7% Activity: 99.7% Activity: 99.7%
Quote:
if it works on and off, then your problem is likely cold solder joints on the fob itself. If you know how to solder, re-flow all the joints and give it a good cleaning
__________________
Quote:
Originally Posted by Galactica View Post
LED's are God's little bright gift to man.
LUNA: Dropped on Tokico Illumina ILK246 kit / 20% tint all around / LED interior / ebay FSTB / Addco RSB / Cattman SS Y-Pipe / Carnal_c subframe collars / Shinjiduo grounding kit / ebay red-smoked tails / Ionic rear window spoiler / clear corners
Amerikaner83 is offline   Reply With Quote
Old 11-14-2012, 03:01 PM   #23
Activity: 58.8%
Quote:
Amerikaner could be right but another thing that can happen is that muck and yuck builds up beneath the plastic membrane that has the buttons and the switches on the printed circuit board. Cleaning with rubbing alcohol and a tooth brush will usually fix this, but I've has some where the crud destroyed the switches.
Old 11-14-2012, 03:06 PM   #24
Activity: 99.7%
Quote:
Good point, Dennis. I forgot how dirty those things can tend to get.
__________________
Old 11-14-2012, 07:46 PM   #25
Activity: 8.8%
UPSXPRESS
So I don't know how to solder...I'll give this a shot anyway. If not, do you have any suggestions?
__________________
96 I30
Old 11-14-2012, 07:53 PM   #26
Activity: 99.7%
take it apart and clean it off first like Dennis mentioned...that's the absolute easiest
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
