Does anyone know how to program a key fob?
Old 05-28-2003, 06:57 PM
infinitiman96's Avatar
Does anyone know the procedure on how to program a new key fob on a 98 I30?
infinitiman96 is offline
Old 05-28-2003, 07:12 PM
Says.."No mo Maximas for me!"
max5spd's Avatar
Why pay $40-$50 for Nissan or Infiniti to program your keyless entry remote when you can do it for FREE? You can do it yourself with step-by-step easy to follow directions.
Reprogram Key Fob
QX4, 1997-2001 Q45, I30, 1999-up G20
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
Note:
Key should be withdrawn from ignition key cylinder completely each time.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Push any button on the new remote controller once. (The hazard warning lamp will then flash)
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
Note:
-If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 "Additional ID code entry" for each new remote controller.
-Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Reprogram Key Fob
J30, 1994-1996 Q45, 1994-1996 G20
2. From the door switch unlock the trunk.
3. Insert and remove the key from the ignition key cylinder six times within 10 seconds.
Note:
-Key should be withdrawn from ignition key cylinder completely each time.
-At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Manually unlock and lock the driver side door
5. Push any button on the new remote controller once.
If there is only one remote controller skip step 6.
6. Additional ID code entry
Repeat step 4 and 5
7. END.
Note:
-If you need to activate more than two additional new remote controllers, repeat the procedure on step 6 "Additional ID code entry" for each new remote controller.
How do you program a new ignition key with chip?
Unfortunately, that can only be done at the dealer. To program the key it is necessary to have a Infiniti Computer and a special program and password.
Using eBay for GOOD, not evil!
I hope that you find this information helpful - and that it keeps you from being ripped off by eBayers trying to sell you FREE information. eBay rules REQUIRE that I offer something to sell... so, to remain in compliance with eBay rules, if you bid on this auction and win I will email you a copy of these instructions... if you do do not agree with the Shipping and handling terms and price, please do not bid!!
max5spd is offline
Old 06-21-2008, 10:06 PM
Teecee's Avatar
I know this is an old thread but I am trying to do this on my '01 I30 with a keyfaub I bought off ebay that is suppose to work for this model. The key faub says Nissan on it. HERE is the ebay link. When I do step 4, nothing happens. I do not get the hazard flash like I thought I was suppose too. I have tried doing step 3 where I turn the key and only the radio is on and also turning the key and the dash lights come on but still no luck with step 4. I have replaced the battery in the remote also. Any thoughts.
Teecee is offline
Old 11-19-2008, 03:44 PM
bonanza's Avatar
Originally Posted by infinitiman96
Does anyone know the procedure on how to program a new key fob on a 2000 I30?
bonanza is offline
Old 11-19-2008, 03:45 PM
bonanza's Avatar
does anyone knows how can i program the key fob on my 2000 infiniti i30?
bonanza is offline
Old 11-22-2008, 08:39 AM
Tri-C's Avatar
See above - and make sure that you have the right key fob. Some of the ones offered on ebay are incorrect. The most common FCC number is KBRASTU10.
Tri-C is offline
Old 12-04-2008, 04:29 PM
Barada's Avatar
I got the same problem.. i cant get past step 4.. i have the right FCC.. it the original remote too.. the kid i bought it off (the car) said the remote lost the code needs a reprogram.. soo i need some help on this too. i got a 2000 i30t
Barada is offline
Old 03-14-2009, 05:00 PM
ridinwitha35's Avatar
These instructions worked for me; programmed 2 remotes using them.
ridinwitha35 is offline
Old 03-14-2009, 06:13 PM
NSMO240's Avatar
you dont have to unlock the doors, you just hit a button on the second or third key fob, the lights will flash for every different key fob programmed, up to 4.
NSMO240 is offline
Old 06-01-2009, 01:26 PM
infinitiandbeyond's Avatar
KEYLESS ENTRY
HELP?
Can you program an old QX4 key fob to an I30? If not how likely will a new Key Fob purchased from Ebay or online somewhere work? Any help will be nice. Thanks
infinitiandbeyond is offline
Old 06-01-2009, 02:05 PM
NSMO240's Avatar
Originally Posted by infinitiandbeyond
HELP?
no, because the QX4 key fob does not have the trunk open button, if you get one from ebay make sure it has lock on top, then unlock, then trunk open, then panic.
NSMO240 is offline
Old 11-08-2010, 05:17 PM
superior82's Avatar
Does anybody knows how to program a new remote on a maxima 2003 or idont know if its possible or will need to be done at the dealer.
superior82 is offline
Old 04-02-2012, 10:42 AM
F35-JSF's Avatar
Thx so much for the write up. The service man looked at me like i was crazy when i said i'd program it myself.
F35-JSF is offline
Old 04-20-2012, 01:36 PM
Thor4's Avatar
Reset on key fob
I picked up a 1998 key fob from a wrecker and was successful on resetting it to my 1998 Maxima using the reset directions. Thanks for the help.
Thor4 is offline
Old 08-22-2012, 01:42 PM
Ian02MAX's Avatar
2002??
Will these work on a 2002 maxima?
Ian02MAX is offline
Old 09-20-2012, 07:26 PM
jcbl426's Avatar
it should work on your maxima with out issues..
jcbl426 is offline
Old 11-11-2012, 08:16 PM
linsdeyb76's Avatar
i have tried this numerous times and i checked the part number on the key pad and it is a nissan keyfob is there any other way to program the key pad without paying
linsdeyb76 is offline
Old 11-11-2012, 09:01 PM
MaxMike93's Avatar
Didn't want to make a new thread for this question, but does anyone know if like the I35 remote would work for an I30? Like for a 2002+ Maxima. Just in case I need a new remote in the future and I kinda like that one more than the ones I have.
MaxMike93 is offline
Old 11-12-2012, 11:55 AM
DennisMik's Avatar
Just because it is a Nissan key fob remote doesn't mean squat. Nissan changes the key fob remote frequency from time to time, so what works with one year doesn't always work with the next year car.
For reasons like this, it is MANDATORY that you tell us the year and model of your car.
DennisMik is offline
Old 11-12-2012, 12:06 PM
DennisMik's Avatar
Unfortunately, the answer is no.
There are 2 different remotes for the i30, one for 96 to 99 and another for 2000 & 2001. In 2002, a 3rd remote was used for the i35 and Maxima.
Old 11-14-2012, 02:05 PM
D I R T Y I 3 0's Avatar
I have a fob that works on and off, I replaced the battery too and that did nothing. I'm guessing this will make it work?
D I R T Y I 3 0 is offline
Old 11-14-2012, 02:10 PM
Amerikaner83's Avatar
if it works on and off, then your problem is likely cold solder joints on the fob itself. If you know how to solder, re-flow all the joints and give it a good cleaning
Amerikaner83 is offline
Old 11-14-2012, 03:01 PM
DennisMik's Avatar
Amerikaner could be right but another thing that can happen is that muck and yuck builds up beneath the plastic membrane that has the buttons and the switches on the printed circuit board. Cleaning with rubbing alcohol and a tooth brush will usually fix this, but I've has some where the crud destroyed the switches.
Old 11-14-2012, 03:06 PM
Good point, Dennis. I forgot how dirty those things can tend to get.
Old 11-14-2012, 07:46 PM
So I don't know how to solder...I'll give this a shot anyway. If not, do you have any suggestions?
Old 11-14-2012, 07:53 PM
take it apart and clean it off first like Dennis mentioned...that's the absolute easiest
Old 05-09-2015, 11:35 AM
Skicrazer's Avatar
Not working
Resurrecting this thread - my 2003 Maxima GLE won't go into "Programmable mode" after the 6+ key inserts/removals within 10 seconds. I.e. the hazards don't flash.
I also noticed the FCC id on the remotes I purchased is KBRASTU15, not 10. The model # is ASTU15, if that's relevant. Manufacturer Calsonis Kensel Corp.
Skicrazer is offline
Old 05-09-2015, 01:48 PM
DennisMik's Avatar
The FCC ID for the 2003 i35 is KBRASTU15, the number you have. KBRASTU10 is for the 2000 & 2001 i35.
I can't say why the remote isn't working. Are you sure it has a battery in it? Are you sure the battery is good?
Why did you but a new remote? Did the old one stop working?
If the remote is good (something you have to verify functionally, not just say "well, it's new") then there may be a problem with the car. The antenna may not be picking upthe signal or the SECU module is bad.
But, just in case, here is the programming procedure that is definitely correct.
To program the remote(s) follow this procedure.
1. Unlock all doors and get in car.
2. Close and lock all doors with power door lock switch on driver's door.
3. Insert the ignition key and completely remove it at least 6 times
within 10 seconds. The hazard warning lamps (both turn signals) will
then flash twice and all previous codes will be cleared.
4. Turn ignition key to "ACC" position.
5. Push any button on the new remote control key fob once. At this time,
the car learns the new ID code. The hazard warning lamps (both turn
signals) will then flash twice.
If you are programming just one remote, go to step 10.
If you need to activate additional remote controllers, continue with Step 6.
6. Manually unlock the driver's door only then lock again with door lock
7. Push lock button on the additional remote controller once.
8. Hazard warning lamps (both turn signals) will then flash twice and
additional remote is programmed.
9. For additional remotes, go back to step 6.
10. When done, open the driver's door to exit programming state.
NOTE: A maximum of 4 remotes can be programmed to any ONE car.
Old 05-13-2015, 09:01 PM
Skicrazer's Avatar
OK - believe it or not, I was doing the 6 in-and-outs too fast. I emailed the fob vendor and they said something about not too slow or too fast, so I slowed down and the flashers blinked. So...I'm good now.
Got the new remotes because new batteries in the old one didn't work.
Very happy to be able to get the windows down before getting in the car on hot sunny days.
06-06-2017 02:01 PM
Fbana41
08-29-2016 12:18 PM
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
maxinout93
10-16-2015 02:53 AM
QueensMAX
09-15-2015 04:14 AM
Quick Reply: Does anyone know how to program a key fob?
