Group Deals / Sponsors ForumFind out more information on group deals that are going on for Maxima parts from our Sponsors.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
NWP Engineering Thermal Intake Spacer Kits for the 00-01 Maxima!
NWP Engineering is proud to finally announce the release of the 00-01 Nissan Maxima Hardware Kit! This kit will allow you to install the 95-99 Maxima Thermal Intake Spacers on your 00-01 Intake Manifold.
Applications:
- 2000 Nissan Maxima (5th generation 3.0L DOHC V6 VQ30DE-K with EGR system)
- 2001 Nissan Maxima (5th generation 3.0L DOHC V6 VQ30DE-K w/o EGR system)
Note: The 95-99 Maxima Upper Intake Spacer included in this kit requires modification in order to be installed. Please refer to the installation instructions for full modification requirements.
As mentioned above, modification of the UIM Spacer is required to allow the bolt holes to properly line up on the 00-01 Maxima Intake Manifold. But, the intake ports are a perfect match! The two Lower Intake Manifold Spacers fit flawlessly without any modification required. No throttle body spacer is included.
Includes:
- QTY 2 1/16" High Quality CNC Machined Phenolic Lower Intake Manifold Spacers
- QTY 1 1/4" High Quality CNC Machined Phenolic Upper Intake Manifold Spacer from the 95-99 Maxima Kit
- No Throttle Body Spacer is included
- QTY 6 Lengthened Zinc Plated Grade 8 Upper Intake Manifold bolts and washers
- QTY 2 Lengthened Zinc Plated Grade 8 Upper Intake Manifold offset studs
- QTY 2 Lengthened Zinc Plated Grade 8 EGR bolts and washers (only included with purchase of EGR Extension Kit)
- 1/4" High Quality CNC Machined Steel EGR Tube Extension Spacer (only included with purchase of EGR Extension Kit)
- QTY 2 High Quality CNC Machined Steel EGR Bolt Extension Spacers (only included with purchase of EGR Extension Kit)
- Printed Detailed Upper Intake Manifold Modification and EGR Extension Kit Installation Instructions with Photos
- Kit does not include full detailed instructions on how to install these spacers on your 00-01 Maxima. Please refer to the instructions for the 95-99 Maxima for specific spacer installation guidelines.
- Two Die Cut Silver Vinyl NWP Engineering Decals
ok, as the guinea pig for the kit, i was the one challenged with figuring out how to get them to fit.... the fitment issues are very minor and require about 15 minutes of safe dremeling. please please remember that when you cut the plastic make sure your wearing some sort of certified safety goggles, as the plastic you will be cutting is VERY HOT and tends to fly.
DYNO info, there is not any certifiable dyno info yet but i will say that throttle response is alot nicer as well as the fact that the difference in temperature on the manifold itself is reduced significantly to the touch. i noticed smoother pulling up top.
if you have any questions feel free to email or pm me.
__________________
********OFFICIALLY THE 1ST 5TH GEN WITH NWP ENGINEERING IM SPACERS INSTALLED!!!!********
PR CAI / Exedy Stage 1 / Pacesetter STS / Larrio's Shifter Bushing / Fidanza / Cattman Headers & Exhaust / Custom Enterprise Test Pipe / All ES Bushings / SS Brake and Clutch / S-techs with Illuminas / Blehmco 300zx Brake Upgrade / FSTB / RSTB / RSB / Walbro / Autometer / Emanage Ultimate / Innovative Motorsports LM-1 Wideband / AE VLSD Tranny / Rev-up Oil Pump / Scan Gauge II / Home Depot Catch Can / JB Welded VI / KOYO Rad./ 350Z Thermostat / 19" Forged G35 Rims
also, forgot to mention i recommend that you buy a new UIM gasket, its only like 10-15 dollars and the new one will protrude more than the one you have now allowing a more secure seal on the UIM spacers.
__________________
So you do not need to buy the 4th gen kit separately. Everything is included for you to install the spacers, except for the TB Spacer. The LIM Spacers fit perfectly without any modification. The UIM Spacer is the only one that needs modifying. The 4th gen TB Spacer will not fit though.
The sale price is affected by the limited production run. As soon as the the first batch runs out, the sale is expected to end and go back to the retail price. We plan on stocking this product permanently though. Only 10 kits were produced with the EGR Extension Kit included.
__________________
NWP Engineering Phenolic Thermal Intake Spacers 10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Thank you. In the past few months, people have shown a lot of demand for this hardware kit. I am sorry it took so long to be released. But it's a very nice kit and will definitely work in the 00-01 Maxima if you don't mind cutting up our beautiful UIM Spacer. And if you happen to mess something up during the modification process, I will be more than happy to work with everyone on the price of a replacement part.
NWP Engineering strives to offer the best customer service you've ever experienced!
Thanks again for everyone's support!
__________________
man... right as i wrecked my 00... here comes spacers for it... congrats non the less
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
As soon as I see the dyno gains then Im gunna have to use some of a paycheck on these. How are these with a wet nitrous system? tThey wont cause pooling in the intake will they?
__________________ SHIFT_spray
~Bad clutch slip in 3rd on the dyno
~132k
~11 bottles 75 shot (no smoke & good compression)
Still made 240hp 315tq
Aaron, thanks again for releasing the kit, I'll send you my money shortly. Do you guy ship by USPS or any faster way to get the kit ? I will hopefully drop the engine next week-end if my Nissan parts are here in time.
A+
AA
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
They work great with wet nitrous kits. I've been testing these spacers for the past year with a wet nitrous kit and they hold up great. The material is a very high durable phenolic laminate that is resistance to almost all chemicals and will easily outlast the life of your vehicle.
The spacers will definitely not cause any pooling.
Quote:
A+
AA
All our packages are shipped via insured 2-3 day USPS Priority Mail. We can ship via Express Mail, which is 1-2 days. But contact me ahead of time for a shipping quote.
Most orders ship within 1 business day. And if you get the order in before 2pm EST, it will usually ship the same day.
Thanks. And good luck with your project. I am liking the progress you're making!
__________________
It's all good Aaron, I have to leave now but I'll send my payment when I'm back later today.
I have worked until 3:00 am this morning and I'm making good progress, need to take care of the tranny but that what I'm taking off now. Just need to get the last few parts from Nissan this week and if it happend then the engine will go in this coming saturday morning.
Cheers
AA
__________________
2004 BMW X5 4.4i
Cheers
AA
Thanks. Please let me know if you have any questions when placing your order.
__________________
