04-23-2008, 07:00 PM
Maxima.org Sponsor
$100 DIGITAL SLIM HID KITS 35W - NOT ANALOG
NO MORE GIGANTIC BALLASTS
NO MORE REPLACEMENTS
NO OVERPRICED ANALOG BALLASTS
NO UGLY BOXES WITH NONSENSE SLOGANS ON THEM
NO UNNECESSARY PARTS YOU PAY FOR BUT STILL THROW AWAY
Why Digital?
The days of the old humming, magnetic core & coil-type ballasts have come to an end. The digital (electronic) ballast is the latest in ballast innovation. Digital ballasts are more efficient, quieter, cooler, and softer/easier on the bulb all the while allowing for a much smaller and neater package. Digital ballasts do not have any of the usual transformers or capacitors, instead these ballasts have electronic circuitry doing the same job, only much more efficiently using significantly less current.
They have the capability of self diagnostic and reset, including specific protection circuits to detect various lamp- and ballast-fault conditions allowing to safely shutdown or reset the ballast. when the ballast fires the bulb it sends full power to the cold bulb, Over time, this shortens the bulb life and reduces the output and life span of the bulb, Digital ballasts start by sending a low amount of power to the bulb and steadily increases the power over the next few seconds until the bulb has reached full brightness, This is also known as soft starting, which minimizes the damage to the bulb and increases its life. After one year of use the usable light coming from bulbs that are run on digital ballasts has decreased significantly less where as the same bulb being used in the coil type ballast would have lost over 10% more usable light over the same period of time.
Where can I use this kit?
Anywhere! It works for your fogs, halogen low beams, high beams if you so desire...anywhere a true HID kit works. This is a complete system that allows unmatched flexibility in mounting and installation due to the unique slim wafer ballasts.
So what does the kit include?
2 bulbs, integrated ballast/ignitor, all the connections to make it work and a 2 year guarantee on any defects related to the product excluding normal wear and tear or bulb failure. You save money by not getting an ugly box that has weird writing on it.
FAQ:
Q: What bulb type should I choose?
A: http://www.sylvania.com/ConsumerProd...de/default.htm
sylvania
Q: What color is best?
A: It really depends what you're looking for. Please realize that Kelvin Scale (K) does *NOT* denote brightness! The Kelvin scale is used only as a measure of COLOR output! Although "bluer" headlights may appear brighter, higher Kelvin applications actually produce less visible light on the road! It is for this reason that OEM applications use 4300K (Yellow/White) bulbs! You should choose a color that matches your needs aesthetically, but realize that Higher Kelvin = Lower Lumen. It is for this reason that we do not offer any color above 8000K!
35W
!! $100.00 !!
* Digital Ballast
* Integrated Ignitor and Ballast with Flexible Connections
* Wafer Thin Design
* Bullet Proof Reliability
* 2 Year Warranty
DELIVERY & PAYMENT INFORMATION
First come first served.
If you order today, we ship if we have stock but more stock is arriving in 10 days and if we are out, we ship when new stock arrives and you are informed of the back order.
All orders will ship via flat rate service. Usually 2-3 days.
If you are in CA, we are in CA, click on the CA Tax Paypal Link
If you are interested in insurance, please click on the Insured HID Link
If you want additional parts like mounting hardware, brackets, etc., please contact us - they are not necessary as these are true Slim Digital Kits.
If you are international, anywhere, please add $15 for shipping.
Slim Kit Special 35W Digital - Domestic 50 States + USVI + PR + *some APO*
Slim Kit Special 35W Digital - Domestic 50 States + USVI + PR + *some APO* WITH INSURANCE
04-23-2008, 07:03 PM
Maxima.org Sponsor
And 50W
50W
!! $150.00 !!
PRODUCT INFO:
Water Proof
Real Digital Slim Ballasts - 33% more output than 35W
All Kits are True 50W, not some sticker on a ballast.
PNP - except dual beam kits which require a little more work.
Install Information:
2 year warranty bulbs and ballasts
2 Real 50W Slim Kits
2 Real 50W Bulbs - not 35W bulbs overdriven
2 Adapters as required/necessary
Slim Kit Special 50W Digital - Domestic 50 States + USVI + PR + *some APO*
Slim Kit Special 50W Digital - Domestic 50 States + USVI + PR + *some APO* WITH INSURANCE
Photos of product
Maxima.org Sponsor
More photos of install as needed.
04-23-2008, 07:42 PM
How will these work if I wanted to replace my fog lights on my 08 SE? I'd like the same 'color' / 'brightness' as I get with my HID headlights. How can I ensure I get the same for both HID's and your product? Which would I need, the 35w or 50w??
04-23-2008, 10:35 PM
Maxima.org Sponsor
No problem, we have every possible combo you want.
Color is not affected by 50W or 35W.
Take your pick
04-24-2008, 12:14 AM
SHIFT_In2D
You'll just need to find the size of your fog light bulb using the Sylvania bulb chart.
If you are running stock HID bulbs in your '08 headlights they will be 4300k for the color. So pick 4300k for the fogs so that they'll match.
The difference between 35w and 50w is the light output or how bright the bulbs appear. 50w appears brighter in a side by side comparison to 35w.
For your fogs I would go with the 50w for those rainy days or very dark roads.
Best of luck!
Hey umnitza! Nice to see more products.
Quote:
__________________
***Named X5-452***
Birthday: 03/11/03 (Purchase Date)
2003 Maxima GLE - Gray Luster AMD - Atlanta Maxima Drivers
| Smoked Lights | Cleared Signal | 19" A34 Nismo/Falken 452 | BC Racing Coilovers | H&R TRAK 15mm | Ichiba 5mm |
| Stillen Classic Lip | Stillen FSTB | Injen | NWP IM Spacers | Cattman Y-Pipe | Custom 2.5" & Flowsound Exhaust | Magnaflow Tips |
| 28% Tint | 20th Ann. Pedals + Door Sills | Super White Bulbs | KV3 Eyelids |
04-24-2008, 12:15 AM
Maxima.org Sponsor
We also have Predator ION bulbs - hyper bright high output LED turn signal bulbs available now.
And, we'll be introducing a completely different line of angel eyes soon.
04-24-2008, 08:53 AM
Mirror's Edge
do you offer 3000k d2rs for the 50w kit
__________________
"Life's a bitch and I'm her pimp"
"Ichigo" Maxima : This is my Zanpakuto
Full Mod List :: Newest Mod:|Mad tYtE Taprootz sticker|
I <3 3.0 || 3.5s are for chumps
04-24-2008, 11:31 AM
Maxima.org Sponsor
We can put together a D2S 3K kit for you, but because of additional adapters, it would be about $200 for it.
04-25-2008, 09:24 AM
Maxima.org Sponsor
most kits are in stock, with more coming in soon.
04-25-2008, 01:06 PM
Maybe you can help. Im looking into upgrading into a bixenon hid kit for an infiniti i30. Not too handy so what do i need to buy and do please.
04-25-2008, 01:08 PM
Maxima.org Sponsor
hmmm, bixenon? as in a bi-xenon projector retrofit with D2S bulb?
04-25-2008, 01:25 PM
RIP Cashj2002
Wow, gotta love techology! Those ballasts look awesome! Im gettin a digital ballast whenever my old analog Hella ballast finally dies.
04-25-2008, 01:46 PM
Quote:
Yes................is it possible?
04-25-2008, 02:20 PM
any output pics/color?
edit: nevermind, I finally had time to really read through and realize it's just the ballast.
Question is, are these specifically for fog lamp bulbs or can the be used to add HID to my 2k max?
04-25-2008, 02:57 PM
I don't know the exact color definition I just want it icy white with light shade of baby blue.
04-25-2008, 03:30 PM
SHIFT_In2D
That would be 5000k or 6000k for a bluer hue
__________________
***Named X5-452***
04-26-2008, 06:39 AM
Best of luck!
If I don't want to pull the bulb or pull the headlight out, is there a way by looking at the headlight to verify the 4300k bulb?
Before I order the 50w bulbs, I wanted to ask if there were plug and play? Take the old bulb out, put the new bulb in sort of speaking. I know the 'lens' will not come out, so I am sure I'll have to be on my back to change these. Is there also a way to have these on without having the headlights on. On the 08's (not sure of other years), to have the fog lights on, you have to have both parking light and headlight on. I'd like to run the fog lights by them selves or with just the parking lights on. Looks like I'll be going with the 50w 4300k kit when I do order. Once I get my LED tail light problem fixed, you'll be getting an order from me. Thanks Jess for the info.
04-26-2008, 10:59 AM
Maxima.org Sponsor
04-26-2008, 11:03 AM
Maxima.org Sponsor
Quote:
Hella ballasts are among the most reliable in the industry, so you'll be waiting a bit.
Quote:
Yes, it's definitely possible, we have D2S in stock.
The HID pictures as you have discovered will not change. These can be used for anything. Literally.
6000K with 50W is your best bet.
The cheap eBay hids are 35W analog - yesterdecade's technology.
35W digital are great kits but - they aren't the maximum output....
So...here's something that helps
35W:
3000K = Yellow = 3500 lumens - roughly.
4300K = White with yellow = 3200 lumens - roughly.
5000K = White very little yellow = 3000 lumens
6000K = White with blueish tones = 2600 lumens
8000K = White with purplish hard bluish tones = 2200 Lumens
35W:
3000K = Yellow - REALLY Yellow = 4600 lumens - roughly.
4300K = White with a little yellow yellow = 4300 lumens - roughly.
5000K = Pure White = 4000 lumens
6000K = White with very little blue tones = 3500 lumens
8000K = White with bluish hard bluish tones = 2900 Lumens
They are plug and play.
If you want to run the parking lights with the fogs, I suspect you'll have to do some rewiring.
04-26-2008, 11:55 AM
SHIFT_In2D
No need to pull it out  factory HID is 4300k
It's a little more complicated than just changing bulbs. For the 08 depending how the fogs are set up under the bumper, you will need to remove the plastic lining to get to the fogs.
Switch the bulbs with the HID bulbs, wire it correctly as shown in the wiring chart, mount the ballasts...and you're good to go.
Here is a link to re-wire the fog lights to come on without headlights for a 5.5 gen. Concept should be the same.
http://www.innerbean.com/housecor/fog_rewire.html
__________________
***Named X5-452***
04-26-2008, 12:54 PM
Can you get a 3000k h3c (or whatever size the smaller h3 is) for foglights?
__________________
04-26-2008, 01:07 PM
