HID Plug and Play Kits $160 SHIPPED Head Lights, Fog Lights!
#2002
Final score:
Indianapolis Colts - 37
Houston Texans - 17
The Colts are not an easy team to play against and Manning is a freaking machine. They definitely exposed some of the Texans weaknesses and what they need to work on in the future.
That works out to a $60 off list (that's $80 shipped for those bad at math) for the HID kits this weeks "Texans" coupon.
Houston Texans - 17
#2004
Last Sunday's game...
Jaguar's - 31
Texans - 24
Ok, I take it back, being 4-5 now officially sucks. Someone give me a crowbar I need to rig next week's game...
This set's the "Texans" coupon code to $86 for a kit.
Jaguar's - 31
Texans - 24
#2005
#2006
I don't want blue, yet at the same time don't want to be Silverlight white ... what's the recommended temperature then ? I'm very much inclined to place the order but wanna hear from folks who got 5k or 6k and how you arrived at a decision ... thanks
#2009
I have a 6k setup (low and high beam) on the wife-mobile. The reason I went that route was based on the number of lumens (read: amount of light output) the 6k had. Bear in mind, I could have gone 5k or 4k which would have given me 400 more lumens but the 2800 lumens of my 6ks work fine (Especially on pitch black Arizona roads)
#2011
Guys, I am having a problem with ballasts again. The low beam ballast on the right side went bad on me and I replaced it with the new slim ballasts you sent me almost 2 months ago. Ever since, my right low beam has been flickering like mad and just went out. However, the left low beam has the slim ballast and it works fine.
#2012
#2013
I bought a 6K for my maxima and love em. I wanna get a set for my Tundra. Can you email me at tim_cloud2005@yahoo.com
#2014
Ravens - 34
Texans - 28
My god, if you missed last night's game, the Texans almost... ALMOST pulled one out of the rear in the last quarter. Hell of a game regardless.
Coupon code sets the kits at $88.
Ravens - 34
Texans - 28
#2015
The D2R HID bulbs on your website the 4300k's are those the Phillips ones or some aftermarket type? I need a new bulb since my passenger side went out last night and want to replace them with the same type that were in there before.
#2018
#2019
I'm interested in purchasing a kit and I've been researching for hours...but can someone clear up what I would need for a 2004 Maxima?
Aren't there 2 lights in each headlight enclosure? People keep referring to the Maxima's "Fog Lights". I know my car has cornering lights--is this what people are calling fog lights or are they referring to the inner (non-projector) bulbs in the headlights?
Everyone seems to recommend the 9006 kit, but there's no highbeams with this kit? Has anyone installed an HID kit with working highbeams or is it not necessary?
#2020
Assuming your '04 is like my '05 SE, you currently have a 9012 bulb that does both high and low beam. It is just one bulb, and there is some type of deflector that moves to give you high or low beam. To go to an HID kid, you need to get 9006 bulbs ( one kit ), and you will need to modify the 9006 bulb casing a bit to allow it to fit into the 9012 socket. Whether the foglight is on the inside or outside, I can't remember, but you are correct that the foglight is built into the headlight assembly.
#2024
You only replace 1 bulb per side for hi and low. Check the 6th gen forum for conversions. The shutter is slightly different.
#2026
Best thing to do for nasty weather are 4300k or 3000k bulbs for the fog lights. In HID form both will be yellow (4300k light up more of a halogen yellow, 3000k are the JDM yellow) and will light up more of the road versus lighting up the fog.
#2027
*bump*
Current coupon code price: $85 shipped next day air to all physical shipping address (excludes Canada, Alaska, Hawaii)
Reworking the pricing on the website (www.3bspec.com) for all of the headlights, tail lights, etc to accommodate for local pick-up. When we're done, we'll be able to set up a coupon code for free shipping in the lower 48-States.
#2029
10k
http://shop.3bspecialties.com/images...139101309.jpeg
12k
http://shop.3bspecialties.com/images...337710377.jpeg
15k
http://shop.3bspecialties.com/images...124758399.jpeg
-- This one was odd out of all of them. Compare it to the 10k and it only really shows up in the projector versus the reflector headlight.
30k
http://shop.3bspecialties.com/images...263624139.jpeg
Since I'm here; Purple
http://shop.3bspecialties.com/images...605181889.jpeg
#2030
damn i just realized you are in htown, i'm from the southwest side, by sharpstown mall. anyways i'm in orlando now for college. i have a few questions
now that i realized your kits come with a harness i'm def ordering from you
1. how does your 50w kits differ from the 35w kits is the brightness noticeable?
2. which is the brightest lumes you have in the 50watts range
3. do you have the hids for reverse yet?
#2031
0) The relay harnesses are optional, you just have to select it when ordering. Otherwise we default to the plug-and-play harness.
1) The 50w's are a double edged sword. Yes they are brighter, but you mostly notice it when you live in the sticks. If you live in an urban area, you don't notice that they're brighter. The other catch is, the 50w ballast tend to eat the bulbs faster.
If you want a really bad idea... I've got a 9006-6k/75w kit here that I am legitimately afraid will melt a headlight housing. Trying to see if I can get those in an H1 for some retrofits...
2) The brightest white (excluding the 4300k) is going to be a 5000k. The 4300k, is going to come off as a halogen yellow and that may detract some people from the "white" that they're going for.
3) We're slowly filtering them in and trying them out locally. Primarily it's an issue of how do we warranty the parts, assuming that they really are warranty-able. Other than that, they're cool, but freaking expensive.
#2032
Migrated everything this way...
http://forums.maxima.org/group-deals...-off-list.html
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
ViciousVQ30
08-05-2015 05:40 PM
