Go Back   Maxima Forums > Classifieds > Group Deals / Sponsors Forum
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-02-2006, 08:46 AM   #41
matty's Avatar
Send a message via AIM to matty
Quote:
Originally Posted by dukelubas
Ok, I just got my bushing today. I'm laying under the car trying to get one of the nuts to budge and remembering all the nuts that I've tried to undo in the past. 99% of the time the stud shears completely off leaving me with nothing left to attach to. I'm seriously afraid its going to happen again this time. How are these to be replaced? From the top near the shifter? I'm almost tempted not to go forward in fear that I'll just end up with a nice bushing with no place to mount it to. Any suggestions?
I went to Meineke to have it put it. They had to totally sheer the stock stud off the car, couldnt torch it cause it was too close to the body. Well after alot of noise, and sparks, it was installed. New Bolts and all. There is no WAY I would have been able to do it
-matt
matty is offline   Reply With Quote
Old 05-02-2006, 11:58 AM   #42
mforrest100's Avatar
Send a message via AIM to mforrest100
Just did a 5 speed swap last year so mine should come down with ease. I never realized how bad that area gets. Friend of mine bought a 1995 5 Speed just to get teh swap parts and the same thing you guys are scared of happening happened to him. At least that was on the junk car. I would suggest just taking it to shop like Matty did
mforrest100 is offline   Reply With Quote
Old 05-02-2006, 12:02 PM   #43
Paradox Systems Vendor
TJ_Max's Avatar
Send a message via AIM to TJ_Max
Quote:
How much did the shop charge you Matty?
__________________
TJ_Max is offline   Reply With Quote
Old 05-02-2006, 12:25 PM   #44
Boss Chen Industries
Larrio Motors's Avatar
It is surprising how bad that area gets considering it is covered by the heat shield
Larrio Motors is offline   Reply With Quote
Old 05-02-2006, 10:37 PM   #45
i will take one on the next batch!
DUKEE is offline   Reply With Quote
Old 05-02-2006, 10:54 PM   #46
matty's Avatar
Quote:
$40
-matt
Old 05-03-2006, 04:36 AM   #47
Org Lurker
Well I accomplished it. Planned for destroying the bolts and did pretty much that. Used bolts from Home Depot as replacements for mounting the bushing to the frame but the 14mm bolt was still fine to reuse.
I do notice a difference in the shifting now. Only took it for a quick test drive so I haven't seen the full impact. Initially I'd say it wasn't as drastic as I was hoping it would be or that others have made it out to be. It's definitely a good part to replace and a rebuilt piece. I don't know if it was worth the pain in the butt that it was to replace it but that could be an isolated case involving built up rust like we have here in the NE.
dukelubas is offline   Reply With Quote
Old 05-03-2006, 05:20 AM   #48
Send a message via AIM to 98MistSE
I am surprised to hear so many problems with rust in that area. My car is a 98 and I live in NY. The bolts were a little rusted but, I just sprayed it with a little liquid wrench and it came right off. The only thing I can say is that the car has always been garaged. One other thing I always do whenever I take off a new bolt, especially under the car, is to put a little anti-seize on it before it goes back in.
__________________
_____________________________________________
PR CAI, Stillen RSB, Stillen FSTB, Cattman Y-pipe, Cattman Catback, B&M STS,
KYB AGX's and Progress Springs, ACT Stage 1/Fidanza Flywheel, ES Bushings All Around,
Audi S4 Projector Retrofit , Definitive Racing UDP(Removed, back to stock).........
98MistSE is offline   Reply With Quote
Old 05-03-2006, 09:45 AM   #49
Most people that raved about dramatic increase have a STS an changed there gear oil to MT-90 or Amsoil. Mostly, if you have a stock shifter, you won't see a big improvement like when you have a STS which is very notchy.
Old 05-05-2006, 03:21 PM   #50
ZHP
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
Finally installed mine. Will be shipping out the old one tonight!!
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
4DRSpeed.com - It's coming!
4DRSpeed is offline   Reply With Quote
Old 05-06-2006, 09:39 PM   #51
Team Ramrod
lilaclucymaxima's Avatar
Send a message via AIM to lilaclucymaxima
I'm definitely grabbing one from the next batch.
lilaclucymaxima is offline   Reply With Quote
Old 05-06-2006, 10:57 PM   #52
ZHP
4DRSpeed's Avatar
Actually I have still have my stock shifter, and I can definetly feel a total improvement. I am using Amsoil gear lube. It is a TON more direct, and it feels heavier which I actually like.
Couldn't be happier.
__________________
Old 05-07-2006, 08:08 PM   #53
Org Lurker
I have a CE STS. and when I switched to MT-90 gear selection actually got worse.
Old 05-08-2006, 12:00 PM   #54
TJ_Max's Avatar
Guys, i'm trying to get that bracket off the parts car I have and I successfully broke 2 of the four studs underneath the car, Can't break the last 2. I guess I should just keep trying to bend them from side to side until they snap? Any tips, tricks?
ALSO, once this bracket is out, will it be pretty obvious how this mounts up?
Old 05-08-2006, 02:59 PM   #55
Which bracket are you referring to?
Once the heat shield is removed from the bottom, it should reveal this:
The bushing is on the left side of the picture. IIRC, two 12mm bolts hold it up to the chassis while a 14mm nut hold it through to the shifter mechanism
Old 05-08-2006, 03:02 PM   #56
ZHP
4DRSpeed's Avatar
I believe you don't have to remove the brackets. Just unbolt, the 2 bolts show in the picture above, and then the bolt that goes through the bushing.
Air tools made this extremely easy!!
Old 05-09-2006, 09:23 AM   #57
TJ_Max's Avatar
Oh, ok, nevermind. THanks for the info guys. Now to get my money back for my 5spd parts. I think the guy sold me a 3rd gen control rod.
And Zack emailed this to me, thought it would help also:
__________________
Old 05-09-2006, 02:18 PM   #58
The Definitive AE Master
Larrio's Avatar
Sorry fellas. I will work on a install sheet with pictures in the next week or so.
Larrio is offline   Reply With Quote
Old 05-09-2006, 02:21 PM   #59
TJ_Max's Avatar
Actually i'm not sure ppl even need one Larrio. But hey, won't hurt. My friend needs a bushing ASAP. When you get them please be prepared to take an overnight order. As a matter of fact, overnight price quote to 11234 please. SO he knows what to give me so I can paypal you.
Old 05-09-2006, 04:48 PM   #60
ZHP
4DRSpeed's Avatar
Hey Larrio let me know when you receive my core. Just so I know it made it there.
Old 05-09-2006, 07:20 PM   #61
Larrio's Avatar
$57 dollars overnighted via express mail
4DRSPEED: I will let you know.
__________________
AP Racing BBK, TS ECU, ES everything, HIDs, Frakencar b-pipe, 18x9 F, 18x9.5 R
Stillen Intake, Y-pipe, STS, FSTB, and RSB, Fidenza Flywheel, SPEC Alum. PP, AP Racing Clutch
5spd Urethane Shifter Bushings!
click HERE !!
Old 05-12-2006, 11:02 AM   #62
1st post updated. I have THREE shifter bushings available. First come, first serve. Thank you very much.
Old 05-12-2006, 11:04 AM   #63
TJ_Max's Avatar
Larrio i'll take one for the $57 overnight. Hold that for me til at least 5pm. Thanks buddy! Mike should have also called you about it.
Old 05-12-2006, 11:06 AM   #64
Mike aka mforrest100 already paid for a overnight bushing yesterday. Is this the same one?
It was sent to a fellow named Justin in Brooklyn. I had to call a few junkyards and pull some strings to get a core and rush a emergency fill and cure all night to send out a emergency bushing for him.
__________________
Now offering professional parts cleaning services -engine/tranny parts, etc. Please PM inquiries
Old 05-12-2006, 11:08 AM   #65
Anymore left?
sharkulator is offline   Reply With Quote
Old 05-12-2006, 11:13 AM   #66
Hello! 1st post shows I still have two available! Thank you!
Old 05-12-2006, 11:33 AM   #67
TJ_Max's Avatar
Nevermind then! Thanks, that's him.
__________________
Old 05-12-2006, 11:43 AM   #68
i sent pm!!!!
Old 05-12-2006, 12:17 PM   #69
PM returned. There is an additional charge for international shipments. Please let me know if this works for you
Old 05-12-2006, 02:58 PM   #70
Only two left!
Old 05-12-2006, 02:59 PM   #71
i sent payment!
Old 05-12-2006, 03:28 PM   #72
Quote:
Originally Posted by DUKEE
i sent payment!
payment received! thank you.
__________________
Old 05-12-2006, 10:42 PM   #73
Thanks Larry.
TJ, you not on your job boy....(LOL) Had to take over responsibilities. Plus I didn't want to give Justin mines for nothing....(LOL)
Old 05-13-2006, 07:01 AM   #74
Team Ramrod
Money sent. Thanks!
Old 05-13-2006, 07:12 AM   #75
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
Quote:
-matt
Tip fo you guys when i installed mine. What i did was drill out the top of the stuff from inside the car. Then take a chisle and tap the stud out. Took a little patience but because we are in the North East and rust is a fact of lice i couldn't see any other way to do this.
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Zack342 is offline   Reply With Quote
Old 05-13-2006, 09:15 AM   #76
Quote:
Originally Posted by lilaclucymaxima
Money sent. Thanks!
payment received, thank you!!
I have one left pending payment.
__________________
Old 05-14-2006, 09:50 AM   #77
Send a message via AIM to MDeezy
Let me know when you get have more instock for sale.
MDeezy is offline   Reply With Quote
Old 05-14-2006, 11:57 AM   #78
Larrio's Avatar
Quote:
I will let you know if the current buyer falls through on Monday or when I get more bushings in. Thank you
__________________
click HERE !!
Old 05-17-2006, 11:26 PM   #79
hey larrio, PM me when you have some available.
konak85 is offline   Reply With Quote
Old 05-18-2006, 12:15 AM   #80
Sorry guys, i've been out of town. I will inform all potential buyers when I get more cores back for production. Thank you
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
