95-99 Crystal Headlights
#81
everything is the same as far a bolting in and fitting, but the design is different. the lens, for instance, is different shape between 95/96 and 97-99. i mean you cant swap just the lenses. these glass lights are modled after a 95/96, but will fit all 4th gens.
#86
Originally Posted by Nick@CE.COM
Not yet but we are working on it.. Should be very soon.. I will keep you guys updated.
~Nick
~Nick
#89
So again, is this deal still on?
I need to replace my headlights because they both have a crack... I am a commuter and the daily highway drive at high speeds tends to attract a lot of stone chips to my headlights. If I buy these headlights to replace my OEM Nissan 95-96 headlights, will these shatter within a few months or are these housings at least as strong as the OEM Nissan 95-96 headlights?
#90
I'm not sure if the org member I did the retrofit for got it from this deal but I was impressed with the light because it is clear glass. It will hold up better for retrofits as well because it is glass and totally clear. 97-99 stocks has the lines going across that minimally affect beam pattern (not a big deal barely noticeable). And won't warp or cloud from the focused heat of the projector beam pattern. Pretty sturdy light, keep in mind though that it maybe more prone to condensation when doing a retrofit. I also believe the lights I worked on had an actual bulb shield not a bulb "halo". If you have a 95-96 I would jump on these even if you are not planning on a retrofit.
For speedemn and others worried about chips there is a film you can buy to protect glass headlights if that is the case.
doctorpullit
10-28-2019 10:58 PM
trsandrew
04-08-2016 06:45 PM
knight_yyz
11-01-2015 01:34 PM
trsandrew
10-25-2015 02:47 PM
