Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 05-31-2002, 10:02 PM   #1
Send a message via AIM to bmxsteve
Car has trouble turning over, can you help me?
Alright, I've notice about every other time I start my car it takes it like 3 seconds or more to turn over. And when it does, it barely turns over, like the instant it turns over the rpms fall low and instantly catch themselves and go up to proper idle. What could it be? I have new battery, plugs, clean tb...I wont rule out the alternator, b/c my orginal died but I got a used one from a junkyard. Would this be a sign of a dying alternator, or maybe a starter? The starter has been replaced and hasnt really made any weird noises. Any ideas? thanks
__________________
1995 Nissan Maxima SE 5spd
JWT Pop charger hybrid intake, WSP y pipe, WSP test pipe, FSTB, Tockico Struts/Eibach springs, 17x8 Konig Tantrums on Falken 235/45/17's, clear/red tails, clear bumper lenses, and bunch of other "stuff"
bmxsteve is offline   Reply With Quote
Old 05-31-2002, 11:28 PM   #2
Send a message via AIM to Iron Lung
Re: Car has trouble turning over, can you help me?
Quote:
To see if its your alternator, start your car and then pull off the positive terminal on your battery. If it does not run then its your alternator.
__________________
Iron Lung is offline   Reply With Quote
Old 06-01-2002, 05:42 AM   #3
Points: 12,548, Level: 73
Points: 12,548, Level: 73 Points: 12,548, Level: 73 Points: 12,548, Level: 73
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
A number of people have had problems with the engine coolant temp sensor. You might want to investigate that as a problem for bad starts...
Mishmosh is offline   Reply With Quote
Old 06-01-2002, 05:54 AM   #4
Do you mean you turn the key to start, hold it, and three seconds later the engine slowly starts to crank?
Someone mentioned the test for the alternator, which can work, but you could also have the battery and alternator tested for free at most auto parts stores. Even though the starter doesn't make any noise, the solenoid could still be bad and not having it engage when it should.
If the scenario I mentioned in the first paragraph is what happens, I would lean towards a switching problem, like possible in the ignition switch itself or at the other end at the solenoid in the starter. If the engine starts to rotate as soon as you turn the key, especially if it turns slowly, then lights off and idles I would lean towards an electrical problem. You battery might be new, but if the alternator is slowly dying, it will not be recharged as it should and that could lead to your problem.
__________________
Yes, I am an Amsoil Dealer and Discounts Are Available
http://www.mdvsynthetics.com
Please use PM or Email for Discount Info
iwannabmw is offline   Reply With Quote
Old 06-01-2002, 07:48 AM   #5
Points: 11,927, Level: 71
Points: 11,927, Level: 71 Points: 11,927, Level: 71 Points: 11,927, Level: 71
Activity: 0%
Re: Re: Car has trouble turning over, can you help me?
my mom's 95SE is starting to have similar starting problems as well. however something else happens. when i turn the key to start, the lights dim but the starter does not even crank the engine. sometimes it takes more than 5 tries to get it to crank. this happens moreso when the engine is warm. what do you guys think?
VQdriver is offline   Reply With Quote
Old 06-01-2002, 01:52 PM   #6
Re: Re: Re: Car has trouble turning over, can you help me?
Quote:
That sounds like the solenoid attached to the side of the starter. Does the car turn over at a normal rate once the starter engages?
__________________
Old 06-01-2002, 05:57 PM   #7
Activity: 0%
Re: Re: Re: Re: Car has trouble turning over, can you help me?
yes it turns over at a normal rate once the starter engages. my thoughts exactly. sometimes if i turn the key hard and fast it catches and turns over strongly. but for some reason, after driving the car for some miles. i won't turn over in the similar fashion as when cold. sometimes i have to try repeatedly up to 5x.
Old 06-01-2002, 06:10 PM   #8
Re: Re: Re: Re: Re: Car has trouble turning over, can you help me?
If I had to put money on it, I would go with the solenoid is going bad and doesn't react well to heat, which is why it's worse after being driven. You can either replace the solenoid if you are comfortable disasemmbling the starter itself, or you could just replace the whole thing.
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
