Proof, that thinner tires should be used for winter driving >>
Old 03-27-2002, 01:11 PM
Albertt's Avatar
Look closely at the width of the tires...
Albertt is offline
Old 03-27-2002, 01:19 PM
I'm needing a caw
Jeff92se's Avatar
Common sense really. But it's funny to see those skinny tires. I think they are studded to hell also. Ever see Ralley when they do at it on the dry pavement? Fat as hell wheels are tires. Makes the awd cars look much better.
Jeff92se is offline
deezo's Avatar
Re: Proof, that thinner tires should be used for winter driving >>
That's right!!! They dig in to get the good stuff.
deezo is offline
Old 03-27-2002, 01:25 PM
Frezny's Avatar
uh, yeah
traction is just a matter of putting as much tire onto the most stable surface. Thinner tires "cut" through water and snow to give better inclement weather traction. Now, when you have dry weather, the wider the tire, the better.
Frezny is offline
Old 03-27-2002, 01:47 PM
Weasel's Avatar
I remember watching that rally, the tires are so heavily studded that when they hit pavement they make little rooster tails of sparks! Cool as hell to watch. Using skinny tires just makes sense from a pressure standpoint.
Weasel is offline
Old 03-27-2002, 02:29 PM
Albertt's Avatar
My reason for posting >>
I find that a picture (especially here on this forum) is worth 1.2 million words. I can spew technical info all day and still NOT get my point across. One pic, and I can figuratively hear the "Oh's" and the "Aha's" from the reply posts.
Albertt is offline
Old 03-27-2002, 02:39 PM
Nine7Max's Avatar
Forget putting my stock rims back on this winter.. bring on the donuts!
Nine7Max is offline
Old 03-27-2002, 02:42 PM
emax02's Avatar
So you mean that's why my 245's sucked in the snow the other day
emax02 is offline
Old 03-27-2002, 04:22 PM
Albertt's Avatar
Emax: Is it still snowing in NH? >>
It snowed here in CT on the 20th...the first day of Spring my ****.
Albertt is offline
Old 03-27-2002, 08:57 PM
emax02's Avatar
Re: Emax: Is it still snowing in NH? >>
Yep we got the same mess here in R.I. It was really hard keeping my car on the road that day
emax02 is offline
Old 03-27-2002, 10:03 PM
Badaxxima's Avatar
Re: uh, yeah
What if they're bald? If you're moving, sure they act like rudders on a boat or airplane, but forward or reverse acceleration (braking) you're SOL. Just a thought I've been chewing on lately.
Badaxxima is offline
Old 03-29-2002, 06:41 AM
Frezny's Avatar
Re: Re: uh, yeah
I'm sure there is some formula somewhere that will actually calculate this for you, but it's a matter of weight, or "pressure" that the car puts onto the surface. Although it's a different application, that's why ice skates work. A large amount of weight, focussed on a tiny surface area creates heat, heat causes the ice to melt, and the skate glides on a thin layer of water over the ice.
For a winter tire, you try to focus as much weight on as many small points (tire treads) so that they will cut through the snow (or even water in other applications) to get down to the true surface. If the tire were "bald" yet thin enough, you could get some good results, but you may compromise in a different area.
Frezny is offline
Roymg
09-03-2018 05:10 AM
MplsMadMan
09-04-2015 02:23 PM
homeyclaus
09-03-2015 06:15 PM
Ispeedbyu
Wheels/Tires
08-21-2015 02:40 PM
Quick Reply: Proof, that thinner tires should be used for winter driving >>
