What did you do to your Maxima/I-series today?
Old 04-29-2013, 04:35 PM
  #41
Noir's Avatar
I've only had my 99 SELimited for almost 2 months, but I've replaced my spark plugs, knock sensor, headlight housings, bumper lights, rear driver brake caliper, rear o2 sensor, hood struts, a tire, windshield, all the seals around the passenger door, map light cover, coil packs, driver inner tie rod, e brake boot, rearview mirror (auto dim from i30), door handles (i30 chrome), swapped to a variable intermittent wiper arm, and sewed myself a new shift boot.
I've also rewired the bird's nest the PO had behind the radio, done the "lazy cruise control mod", rewired my bumper lights so the whole thing blinks, and wired my fogs to a 12v switched..
Now I'm piecing together a 6 speed swap to fix my machine gun of an IPS bearing...
Noir is offline
Old 04-30-2013, 08:08 AM
  #42
DennisMik's Avatar
Replaced the left axle & oil seal on my 2K. I had an oil leak at the differential and when I crawled under the car, I discovered that I could wiggle the axle. I panicked and thought the differential was screwed, but calmed down and discovered that the axle joint next to the differential had all the play in it. I had vibration at highway speeds that I hope is gone now, I haven't driven on the expressway yet.
DennisMik is offline
Old 04-30-2013, 08:56 AM
  #43
dwapenyi's Avatar
Originally Posted by squirrelpig
that is awesome
dwapenyi is offline
Old 04-30-2013, 06:54 PM
  #44
jholley's Avatar
Basecoated and clearcoated right doors and rocker panel.
jholley is offline
Old 05-01-2013, 12:51 AM
  #45
DennisMik's Avatar
Bought and installed a brake hardware kit on my 2K in hopes it will stop the squeaking. Who ever did the brakes threw away all the springs and shims. What an a-hole.
Old 05-01-2013, 09:47 AM
  #46
Leo_Koneval's Avatar
About to do a good old oil change for my 4th gen!
I also had a wierd dream, I dreamt that I was driving around town and for some reason kept seeing short ram intakes on the ground. Some were the fancy metal kind and some were the black plastic kind and I didnt pick any of them up, darn.
Then I saw that I had my dash apart and found treasure hidden in my car, but had to call someone to extract it. Then there were little mini baby alligators and naked women.
And that was my day, thank you.
Leo_Koneval is offline
Old 05-01-2013, 08:35 PM
  #47
DennisMik's Avatar
What the hell are you on????
Old 05-01-2013, 08:39 PM
  #48
Max139617's Avatar
Ive had a similar dream minus the trees and aligators, I was just on some NyQuil though.
Max139617 is offline
Old 05-01-2013, 09:03 PM
  #49
BlackThornDemon's Avatar
Seats. Starter clean/re-grease. Replaced broken tb hose thing.
lol made my day
BlackThornDemon is offline
Old 05-01-2013, 09:40 PM
  #50
norcallump's Avatar
I started mine after 4 months sitting collecting dust.
norcallump is offline
Old 05-02-2013, 07:24 AM
  #51
dot dot dot ...
NmexMAX's Avatar
Same, more like 2 months. And installed ZT-3 WB.
NmexMAX is offline
Old 05-02-2013, 08:52 AM
  #52
itspeat's Avatar
Made and installed my O2 Sim.
Bought New Master, Slave, and SS Clutch Line.
Simulated Knock Sensor until I can replace it.
Put some Redline 75W-90 in my MT
Changed oil to synthetic at 100,000 miles. Hopefully I don't find any surprise burning or leaks with it.
itspeat is offline
Old 05-02-2013, 09:56 AM
  #53
CMax03's Avatar
Wifey got stranded (1st Time) since owning the car brand new....Cam sensor (bank 1/right bank) decided too retire....Met my wifey in a parking lot and took care of the situation @ the 1845-2000 hr....Had to get the part from O'riellys and cost about $62 after tax.....This was the original sensor, I'd replaced the bank 2 sensor about 9 yrs ago....I must say that we've really had good reliabilty from our 2003 TE SE....That lil "B" is starting to get old!
CMax03 is offline
Old 05-02-2013, 05:56 PM
  #54
Rods03Max619's Avatar
Well go on and toss me that TS ECU....
Rods03Max619 is offline
Old 05-02-2013, 08:33 PM
  #55
How do you like the ZT-3? Are you finding it to be accurate? Get a gauge/display too? I just installed one along with the hacker/tweaker display (and a EMU) into a buddies Max last weekend. I'm thinking of picking one up myself.
The Wizard is offline
Old 05-07-2013, 03:40 PM
  #56
tigersharkdude's Avatar
Changed my plugs to some NGK Platinums.
tigersharkdude is offline
Old 05-07-2013, 03:43 PM
  #57
Mounted this silly little thing called a supercharger to the timing case on my daily driver Max.....almost done.
Old 05-07-2013, 04:00 PM
  #58
in4pics
Old 05-08-2013, 05:41 AM
  #59
^^Name:  inbeforethewiz_zps8d6fb672.jpg
Old 05-08-2013, 10:26 AM
  #60
LOL. Soon grasshoppa, soon.
Old 05-08-2013, 03:36 PM
  #61
dot dot dot ...
NmexMAX's Avatar
I had the PLXR300, and TurboXS tuner.
Decided I no longer need all the logging capability with those 2. Although it was fun checking 0-60 times with the PLX.
I haven't done anything more than street and/or dynotuning in a long time and decided the ZT-3 with the cool blue display was for me. Still need some type of WB with readout now with the 440's and 4", so this suited me well.
Efficient and accurate. Although it seems to take a little while to "warm up" as in feedback speed just after starting. After that it seems just fine.
I also like the potential of the ZT-3, as in if I do need that logging capability, it's available if/when needed.
Also, the display is nice and small, and tidy looking on the dash, vs either the PLX or TSX were a but bulky and clumsy looking.
NmexMAX is offline
Old 05-08-2013, 06:39 PM
  #62
Kevlo for President
Kevlo911's Avatar
I went WOT and scared some people
Kevlo911 is offline
Old 05-11-2013, 07:44 AM
  #63
AznRyan's Avatar
Basic maintenance - changed oil, ordered some plugs, new battery
I also washed it 2 days ago, and so of course.. it's rained for the past 2 days -_-
AznRyan is offline
Old 05-13-2013, 11:43 AM
  #64
dot dot dot ...
NmexMAX's Avatar
Installed 4" intake, cleaned up the wiring mess in the cabin, changed the oil, cleaned the K&N.
NmexMAX is offline
Old 05-17-2013, 07:47 PM
  #65
SILVER1000's Avatar
Painted the roof trim pieces black...installed EBC slotted rotors and red stuff pads on all four corners....and detailed her all up. Next weekend I'm installing the BC Coilovers..... :-)
SILVER1000 is offline
Old 05-17-2013, 09:02 PM
  #66
DennisMik's Avatar
Installed that plastic button on the seat belt that keeps the seat belt clip from sliding to the floor when the seat belt is not being worn.
Old 05-17-2013, 09:12 PM
  #67
milo2223's Avatar
Like every day drove her 66miles ;-)
milo2223 is offline
Old 05-19-2013, 10:46 AM
  #68
Beleg's Avatar
found that the reason the only fog light on the car doesnt work isthe bulb was burnt out. took the assembly out for now so she doesnt look snaggle toothed.
cleaned and vacuumed the inside am as soon as im done posting will clean the outside.
Beleg is offline
Old 05-19-2013, 11:07 AM
  #69
JWatZ's Avatar
DR mod and a "This is my 50+ hp sticker!" sticker.
JWatZ is offline
Old 05-19-2013, 11:16 AM
  #70
HYPEsoon's Avatar
Drove my AE to work lol looking to drop her soon!
HYPEsoon is offline
Old 05-19-2013, 03:37 PM
  #71
Just hit 150K miles!
And hopefully another trouble free 150K miles in several years.
Old 05-19-2013, 04:52 PM
  #72
MaxxedOutt's Avatar
Last weekend was my first Saturday off in a looking time, so I replaced all my torn leather seats with some immaculate, dark cloth seats from a '03 SE. Much more comfortable, and not embarrassed to open the doors anymore! I also had to replace one of the seat motors, cuz the guy that took the seats off at the junkyard prolly dropped the seat on the floor, and had broken the plastic piece. It took 3 motors to make one! Lol! Right now, I'm about to go replace my fog light ballasts, hopefully replace the power steering return hose, and if time allows, install my rear coilovers. I got her vacuumed and washed yesterday!
MaxxedOutt is offline
Old 05-19-2013, 04:59 PM
  #73
MaxxedOutt's Avatar
Oh, I also installed AE pedal pads off a '04 350Z. I still have to mod the dead pedal. I also picked up a set of '04, 350Z front seats, but the airbags were blown, so I still have to repair the side panels and do some bracket modding... But, that's for another day. Still have a wingless trunk to paint (black for now), and all kinds of other stuff.
Old 05-19-2013, 06:30 PM
  #74
B!tch We Got a Problem
Gismo-T's Avatar
Installed Shinjiduo grounding kit on my 5.5 A/T....
Gismo-T is offline
Old 05-19-2013, 08:27 PM
  #75
saig's Avatar
Install 4 new MiJ OEM struts/shocks. At 210M she found new legs and is happier so is me.
saig is offline
Old 05-19-2013, 08:57 PM
  #76
Yesterday installed Progress RSB, and today installed Carnal Sub Frame Collars...
Old 05-19-2013, 08:58 PM
  #77
Old 05-19-2013, 09:00 PM
  #78
cheech_11's Avatar
ordered a new hid bulb for my right headlight
cheech_11 is offline
Old 05-21-2013, 11:47 AM
  #79
Beleg's Avatar
installed my new fog light bulb. it works!! which means its not the wiring. Took it out again now i just have to find the driver side assembly.
Beleg is offline
Old 05-21-2013, 12:42 PM
  #80
MaxxedOutt's Avatar
Changed out kicker panels and center door post panels. Went from tan to black, so the dark seats don't look too out-of-place, although they don't look that bad anyway. Sanded and polished my foglight lenses, and installed coilovers in the rear. Didn't get a chance on Sunday...
Just got a txt that my motor mounts from rockauto just came in. Just in time for the holiday weekend!
Don't forget y'all, this weekend is sale weekend at pick-your-part, and prolly ecology too...
Quick Reply: What did you do to your Maxima/I-series today?
