maxes with cams
maxes with cams
sup org,
i was just curious if anyone invested enough time and money in there max to put a set of cams in.
i would like to know of the power gains if any, and video clips cause it just sounds amazing
if theres dyno sheets post them if its too much and not worth it post
thanks org
edited for grammer
thanks org
edited for grammer
there was an old video on youtube where this 4th gen had cams loping really hard. and a 5.5 gen with cams also. got a friend here with cams on his 4.5 swapped 4th gen here in dallas but he isnt on the org
i saw a couple videos on you tube but i just dont think they do the car justice they were poorly shot
I've heard a 4th gen with S1 cams and if he didnt tell me he had them I would have never known. Also I've heard Jaypee99's 5.5 gen with BC stage 2 cams and the cam lope and very subtle. You'd have to really be listening for it to hear it.
http://forums.maxima.org/general-max...aders-vid.html
Had to dig deep to find the thread. unfortuantly the vids dont work anymore. Check VQpower it may still work on there.
i think his max barely idled...
i believe his screen name was "ironlungs". not sure if he was a member on the .org though, i think he was from the VQpower forums ...
EDIT: DAMMIT AJ, you beat me to it! lol
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
As far as I know, Jay_pee doesn't make any videos aside from others catching him at the track sometimes. With the BC S2 and the cattman 3", you would probably have a very hard time identifying any lope. Unless you can play with intake VTC and advance it a little at idle....
i saw that gold 4th gen on you tube i heard it with the full exhaust and the electric dump closed and, like most of you have mentioned, you cant really tell it has a set of cams. i wonder if the power gains of just the cams are worth the money
Peak gains aren't amazing... 15-20whp for a "normal" 260-264ish and 10.5-10.8 lift. However, It's gains under the curve by extending the power band after peak that make cams worth it.
so basically without a tune,and a 00vi you wont see much especially with the factory rev limit cams are not a cheap upgrade
Yes.
ARP rod bolts, Revup oil pump, and HR springs/retainers (double shimmed) = the way to go along with cams for a safe 7500ish RPM build not including internals. With proper balancing, 8000+. As Dandymax has proven, going upwards of 8000 rpms on a stock balanced rotating assembly can cause shattered oil pumps so I'll probably be aiming for a rev limit around 7500-7600 depending on what's optimal for my shift points. Guess I'll leave 2-3whp on the table by keeping the stock harmonic balancer crank pulley also, especially since I already have an aluminum flywheel instead of the dual mass stocker.
