XENON HID issue
Old 10-05-2010, 05:39 AM
beerman1378's Avatar
XENON HID issue
I recently put Xenon HID's in my Max and they worked great for 4 months or so. Not until today I realized my driver side bulb was out. So I turned my lights off then back on and noticed the bulb tried firing for a split second, but didnt come on. I turned the lights off an on a few times then the bulb stayed lit. this has happened twice today. Any ideas on what it may be? If it were the bulb, it wouldnt try firing at all...correct?
beerman1378 is offline
Old 10-06-2010, 05:31 AM
BossMaxima's Avatar
Yea, if it was the bulb it wouldnt work at all. When I had HIDs in my explorer I had that same problem. Turned out the ballast was going out from being left on "auto".
The best solution is to make sure you are using a relay, replace the ballast, and dont use the "auto" function on the headlights.
BossMaxima is offline
Old 10-07-2010, 03:47 AM
AMaxima2Envy's Avatar
bad ballast most likely. if changing the bulbs doens't fix it,and it shouldn't new ballast time. I'd just buy a set of 55w HIDs and replace them both fwiw.
AMaxima2Envy is offline
Old 10-07-2010, 06:30 AM
You embarrass me.
zero2sixtyZ's Avatar
Swap the bulbs from side to side, and go from there.
zero2sixtyZ is offline
THawes's Avatar
My brother had a similar issue with his, and it turned out to be the ballast as well.
THawes is offline
Old 10-19-2010, 04:55 PM
Kouki-monster's Avatar
Sounds Like a ballast..
Kouki-monster is offline
Old 10-19-2010, 05:10 PM
lux97Max's Avatar
yea i could the ballaster shaking around alot if its not secure
lux97Max is offline
Old 10-20-2010, 03:52 PM
cheese123's Avatar
Did you touch the HID bulb???? You cannot touch the tips of these HID's when being installed. It has some type of material that can crack easily like if it was powdery
cheese123 is offline
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
Vistance
09-17-2015 05:17 AM
MidnightMaxima_22
09-12-2015 06:02 AM
mpbclutch33
09-08-2015 06:21 PM
Quick Reply: XENON HID issue
