Needle goes to "H" 2000 GLE
Old 07-25-2010, 10:14 AM
gtmassive75's Avatar
Notice yesterday(100+)" driving fr about 30mins in local traffic the temp needle approach "H".....all coolant is fill. Fan is spinning, after reading some post on overheating can be different problems...can someone direct me what 1st should I check?
My AC doesn't work, tried the can that Pep Boys sell, temp shows its fill with freeon.
This morning i start the car for 1hr and needle stays in the middle...
gtmassive75 is offline
Old 07-25-2010, 12:17 PM
chrome91's Avatar
you would get more help in the 5th gen section, and also try searching first
http://forums.maxima.org/5th-generat...eded-asap.html
the threads a few years old so you have to paste in the link by quoting my post or else it wont come up. Soonerfans post-
im going with (in this order) -
clogged radiator
bad thermostat
chrome91 is offline
Old 07-25-2010, 08:16 PM
Thx...will look there.
Old 08-01-2010, 01:38 PM
black b14's Avatar
Make sure you've done a coolant flush, if the car can't cool the motor under load, that could be issue. Or actually, I'd also check the water pump. Not totally sure how difficult it is on this car. Also, check the thermostat or stats. Other than that. Your compression could be going bad on the car. Doubt it, but possible.
black b14 is offline
Old 08-15-2010, 08:06 PM
jgilbs's Avatar
Does using your heater solve the problem? If so, look in front of your radiator(between ac condenser and radiator) on mine there was all sorts of crud. Removed the fan shroud, blasted it with a garden hose, and now I'm good as new! Total cost: $0
jgilbs is offline
Old 08-22-2010, 08:31 AM
musictech55's Avatar
try bleeding your coolant system could have a large air bubble in there
musictech55 is offline
mclasser
22
11-12-2020 01:58 PM
AaronL
08-08-2020 10:31 AM
TKHanson
11-24-2018 01:39 AM
Unclejunebug
04-02-2016 05:42 AM
Need help
23
10-02-2015 08:56 AM
Quick Reply: Needle goes to "H" 2000 GLE
