Eletircal expert needed please!
I have some interior leds that I added as courtesy lights,when the circuit is closed, its still bleeding out around 2.4volts to my leds, which is not enough to light an incandescent bulb, but is giving the led a very very low amount of light output (when it should be off), How can i stop the 2.4v from reaching the leds?
I understand LED's but I don't understand your post. Can you put up a schematic of your circuit?
Adding a larger resistor will only decrease current flow through the LED... meaning unless it is sufficiently large the LED will still have a glow even if very faint.
Alternatively you can also add several diodes in series such that the turn on voltage is higher than whatever the 2.4 volts you are talking about.
boomerbrian
11-08-2015 05:10 PM
TonyJr
08-20-2015 12:14 AM
