General Maxima DiscussionThis a general area for Maxima discussions for all years. For more specific questions, visit one of the generation-specific forums.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I've seen these in other cars.
1) Would it help Maximas to get beefier ones? How so?
2) Should it be adjustable?
3) Does it matter if the heim joint is sealed or covered with a rubber boot like the stock one?
4) Would you be interested in buying if I had them made?
5) How much would you pay?
[mist max2000] informed me below that 3rd and 6th gens already have upgraded links. So the ones I'm thinking about will target 4th and 5th gens. Thanx mist max2000 for the clarification.
i think you need to be more specific towards which generation crowd your talking to.. FWIW- matt blhem (blhemco) made endlinks for 3rd gen.. not sure about 4th,..i know alot of 5 gen guys use moog endlinks,.. and i know 6th gen guys have racingline endlinks available to them,...
Good point, I didn't kno there were endlinks for other gens. I'm shooting for 4th and 5th gens. The moogs are OEM, and not really upgraded, am I correct?
Dr J
__________________
Dr J
ICQ/AIM/MSN/YIM/Google/Skype: ThurzNite
Email: ThurzNite@Yahoo.Com
MCC member #27
Show your support! Custom MAXIMA.ORG lanyards! Link
well.. they are beefier in bushing size compared to OEM,.. yet are stated as an oem replacement,.. so take that for what its worth,..they also have a greese gun fitting so you can keep them fresh...
feel to educate me on how better endlinks would help in terms of suspension?,..in terms of,.. if the SE sway bar is only 23mm,.. isnt there only so far that can be pushed with better endlinks with out being upgraded to a bigger size(which doesnt exist) ? or am i completly wrong..
on that note the moog endlinks are ~30 for the set,.. i know aftermarket would be significantly more,.. but are oem endlinks that big of a design flaw to justify an aftermarket set in terms of performance..
...dont get me wrong the more aftermarket availability the better as long as its justified
EDIT II: might want to look at this thread and maybe contact this member about building if you dont have a contact already.. seems to have a good know-how yet busy with a current project.. Making some traction rods, who wants some?
I honestly don't see how those links made that much of a dif. in the way the car handles. Placebo effect perhaps? There can't be much, if any flex in the OE link.
The 4th gen is also configured much differently. We have a bushing set up vers the full ball joint set up on the 6th gen. The greatest improvement for our links is to simply install a harder bushing at the end of the link that connect to the sway bar. It would also make sense to upgrade the sway bar bushings to firmer rubber as well. All this is currently available to us already. I can't see how changing the diameter of the rod could possible change anything. Adjustments? What's to adjust? The only way to dial in the amount of sway or anti sway is to change the diameter of the actual sway bar.
A lot of us are lowered, which would change the geometry of the sway bar. It'll be more vertical than stock. Do you think it would change handling if shorter endlinks were installed?
And just thinking abstractly right now... is there a way to pre-tension the sway bar? Like if I know an auto-x course runs clockwise, with a fast tight right turn in the middle of the course, would pre-tensioning the sway benefit?
Just throwing ideas around for discussion, with the possibility of getting some mass produced if there's a demand.
Dr J
__________________
Dr J
MCC member #27
You have a few good points there. A shorter link might just put the sway bar at a more ideal position. I would think the flatter the bar sits on the chassis, the better it will perform. As far as auto-x goes, again that makes sense for adjustability.
Offer the firmer bushings as well for a complete package.
I'm on the border about the bushings. From what I remember the stock links don't have bushings. I was leaning towards using a spacer, or have a specially made stud.
I pulled this pic from another site
Dr J
__________________
Dr J
MCC member #27
That 6th gen info was a good read, Mist_Max. And those Racingline endlinks look sexy and far more serious than OEM. Some good pictures there.
For our 5th Gen on the FSB endlinks, I'd like to see a picture or photoshop mock up of the proposal. The MOOG endlinks seem plenty sturdy, and I'm thinking there's not so much length to the device as to warrant a beefier design. Plus, at only $15... well, that's barely the cost of lunch.
Anyway, put me down as skeptical but interested.
__________________
NWP phenolic intake spacers, Cattman y-pipe, Cattman 2.5" cat-back, Frankencar short-ram intake, Apexi pop charger, UR crank pulley, ES motor-mount and sub-mount bushings, Racingline FSTB, Progress RSB, STS mod w/ES bushings, Brembo blanks, Hawk ceramic pads, Goodyear Eagle F1's -- 54,000 original owner miles
Link to the 6th gen information? FYI the Z and G guys already have adju end links available from spl etc.. Not cheap though. But you have to use a sealed unit and use a quality end link. Or else dirt will ruin them and they will start to clunk and rattle.
Coincidentally, there's an end-link thread going on in the 5th gen forum.
Check out this picture of the OEM end link next to the MOOG endlink. Interesting.
this might be a really stupid idea but i'm going to throw it out there even though i'll probably get flamed. But what if you cut the Moog endlink in the middle took out a little chunk and thread both ends and put one of those joining kinda nuts like what the Torque link from NWP setup is like...wouldn't that make it adjustable
__________________
NWP Spacers,Vias Block,Engine Torque Link/Injen short ram/Stronger 2k1 MAF/Injen Filter/ES UMMB/UR Underdrive Pulley/Stillen Grounding Kit/Technosquare Reflash/Spec Stage 2+/Fidanza Flywheel/Cattman Headers/O2 Sim/True Dual 2.5” Exhaust/Progress Springs, RSB, Custom Maxima FSTB/Stillen RSTB/Tokico Blue Struts/Ksport BBK/Hella supertones
MAXUS 09' VIDhttp://videos.streetfire.net/video/M...-09_698281.htm
Hey Rochester, that picture is copyrighted. My attorney will be in contact with you......
Sorry, man. That's a great picture, nicely demonstrating the differences in design between the OEM end-link and the MOOG. I've been wanting to know what the difference is, and BAM! you go an post that picture.
I snagged it because, well, photobucket stuff doesn't exactly last forever.
__________________
Hope you know I was only kidding, bro. You are right about photobucket, you never know these days which one is the next web site to go kaput.... (I always give mental compliments of your sig picture, BTW)
I pretty much thought you were kidding.
"Mental complements" on my sig picture? Thanks! You just made my day. Random acts of kindness are priceless.
Guys, how often should those MOOG end-links get repacked? Annually, or based on miles?
__________________
PS: Don't take this post seriously; I've got a thread in the 5th gen section contemplating on whether or not the Moog aftermarket end-links are too beefy! Sounds like it's just me though.
__________________ 137k miles
To-do: Belts, Fix suspension problem Major probs fixed: Lower oil pan | Radiator | EVAP canister/valve| VIAS Control Valve | Rear VC | MAF (2k1 w/swapped thermistor)
In for outcomes, curious about the product to be designed.
As the title states, the thread's a feeler, wanna see if people are interested. If so, how much would they spend, and then I can go hunt for a good deal on good parts. I won't start production unless I get serious buyers lined up. PM me if you've got any other ideas on new maxima part with ample demands worth my effort to create. Thx!
Dr J
__________________
Dr J
MCC member #27
what do you think you would be able to produce these for a set where it would be worth your time and parts,..just ball park it,.. give or take x amount...u know?
Like I said, if there's no demand, I won't bother with this. It started out with 1 orger asking me about upgraded end links. I asked around non maxima owners what they were doing and found that heim joints were the key, paired with some good tubing. However, I was informed that in our application of low stress (compared to off-road) and minimal necessity for adjustments (does length really matter? can we pre-tension the swaybar?) sorta made upgraded endlinks pointless.
The original org member insists on having these made. I was wondering if there's a demand in upgraded end-links. If no demand, then I'm dropping this. If there's a demand, I'll do the research.
The minimum run I'll do is 10. I'd like to do 20. These will be pre-pay, in part or whole, depends on how many people want them. The reason is cuz I still haven't broke even on the .org lanyards (check my sig).
Edit: I'm gonna call up a few places and price them for 10 and 20 sets. I'll also need a local 4th and 5th gen to take measurements from. Finally, I'd like to hear from people to see if shorter or longer end links make a difference.
Dr J
__________________
Dr J
MCC member #27
Dr J
...that sounds like a politician's answer
...so we'll skip your background with cars if you can make them you can make them...
any idea on price? lets start here,... north or south of 75 for the set?(estimated)
oh.. and i am def interested thats why i keep trolling this thread.. just need to know a very rough ball park price before i put my name on anything..
hey just an idea,.. you should get some threads going in the 4g and 5 g sections that direct link traffic over here to get a better feel for feedback,.. i dont think alot of people check the general section,.. only time i do before i found this, is when the 5g section is really boring lol , . . .just my .02
LOL, yes, it's very generalized and I didn't say much. This's a crowd-source project, orgers will dictate the quality and prices they want. I've been here long enough to see that many will get a $20 ebay FSTB, some will do a $100 Stillen FSTB, and a handful will go for $150 Cattman's Titanium FSTB. The 6th gen links going for $75 seems high for the materials they're using. I'll do them for less than $75, I'm pretty sure I can source same or better heims for less. I'll say $75 shipped is the cap. However it's gonna be tough doing better than the $30 Moogs, assuming the above post means $15/side.
Adjustable sway bar end links would be nice. They are on my list of things to do for my car. For some reason the sway bar on my '96 has alot of preload in it that needs to be dialed out. On tight turns at some roadcourses I suspect the front sway bar is binding from to much preload. With new sway bar bushings that were ground down a little bit on the passenger side I was able to remove some preload but not all of it. I could use shims on the other bushing or get adjustable endlinks to fix the problem once and for all.
IMO only the more hardcore setups would benefit from adjustable end links. People get a benefit from changing the worn out OEM end links with aftermarket ones with stiffer bushings and as such feel some performace gain.
I think the 5th gens MIGHT be able to use the 300ZX front adjustable endlinks from SPL. If they can't Whiteline sells universal adjustable endlinks in that 5th gen style. 4th gen endlinks are a bit more goofy and would need something custom to work, SPL might have something that would work I'm not sure yet. I've contemplated making a 5th gen sway bar fit on my '96 so I can easily get adjustable end links.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
Thanx for the info, that's what I was looking for, some validation. I will look into cross referencing across models and generations. I've got a couple of leads from prior research, just never hit the 'Go' button on them cuz wasn't sure how many people would be interested.
Dr J
__________________
Dr J
MCC member #27
Ok, I've looked around at other cars to see what they were doing, and I am looking at parts sources. 4th gens, I'm gonna try to get them done for $50shipped. The toughest part is gonna be sourcing good quality bushings.
5th gens, about $60 shipped? Will update more after lunch and calling around.
Dr J
__________________
Dr J
MCC member #27
A short history and overview of the BMW M1. (C)1994 Andrew E. Kalman.
Basic Facts (and some rumors): The M1 went through several preliminary designs (e.g. the BMW turbo (2 units made), not to be confused with the 2002 turbo) before the design was finalized. Project E26 (1976) was really the first look at what would become the production M1. Lamborghini was originally supposed to do much of the production, but their financial woes ultimately prevented this, so BMW got a bunch of companies together (T.I.R., ItalDesign, Ital Engineering, Baur) to do design, fabrication and assembly.
