Instructions on installing the rear def winshield
Old 03-13-2009, 04:27 PM
vqmaxman's Avatar
I was thinking about changing out my rear window because the rear window windshield Is not working. I will clearly like to know what should I do and what tools will I use. What parts of the car will I have to remove interior and exterior wise.
Thank you.
vqmaxman is offline
Old 03-13-2009, 08:53 PM
Leo_Koneval's Avatar
You mean the defrosting elements? But I imagine its going to be a tough process, probably requiring two people. But hope you get your answers soon! I really want to know this too.
Leo_Koneval is offline
Old 03-13-2009, 09:28 PM
nsnrider's Avatar
1. you have to remove the rear interior "C" pillar trims.
2. disconnect the wires that hook up to the glass heating elements (and antenna if applicable)
3. with a long hand utility knife (LOOK HERE), cut the windshield urethane
-cut as close to the frame of the car to get most of the urethane in one step
-i spray some windex all around the inside of glass on the urethane to help the blade slice through a bit easier
4. remove back glass
5. clean up any left over urethane
6. apply special primer (sometimes a one step, other times a two part system depending on what you use)
7. prepare the glass you are setting in
8. apply a nice 1/4 inch bead of windshield urethane around the perimeter of the opening
9. with someone help, set the new glass in and align it.
-if installing new glass, it probably comes with the reveal moulding
-for used glass, you might need to purchase a new reveal moulding that usually runs around $60 at the dealership
10. reconnect wires
11. reinstall trim
I would not recommend this for someone who has not done this or at least seen it done before.
Cutting the glass out is somewhat difficult especially if it has been re glued before
If you're getting rid of the glass, maybe just break it to avoid to have to cut it.
also, check with your local glass shop, in my area, some glass shops can cut your glass out and install your new glass for about $60-100 (depending who does it)
Good luck and hope this hekps.
nsnrider is offline
Old 03-14-2009, 02:49 PM
vqmaxman's Avatar
I've called up the dealership and asked the price on my windshield and they told me that it is going to be $700 for just the glass and for the installation is around $300-$600= a whopping $1000+ job. I am going to go somewhere better like a banner glass or a carlite. I have another question Is banner glass good and is there glass O.E.M. like as they are telling me.
vqmaxman is offline
Old 03-16-2009, 06:35 AM
njmaxseltd's Avatar
Why don't you simply repair the rear defroster? It's actually pretty easy to do.
Find the break with a multi meter and then get a repair kit or just use a solder iron and bridge it back together. Once the circuit is complete again, your defroster will work.
Much easier and much cheaper to do.
njmaxseltd is offline
Old 03-16-2009, 06:59 AM
Ad·min·is·tra·tor
DanNY's Avatar
10. reconnect wires
11. reinstall trim
wouldn't using a the wire to cut through the sealant be a little easier?
DanNY is offline
Old 03-16-2009, 06:03 PM
vqmaxman's Avatar
I tried fixing the lines but the lines are completly shaved off the window,so I will have to replace the window.
vqmaxman is offline
Old 03-19-2009, 10:41 AM
Maxgig's Avatar
You can also buy a replacement heating element, cut it to size and apply it.
Maxgig is offline
Huttig2009
09-25-2015 03:31 PM
Maxboy23
08-20-2015 09:33 AM
Dman1989
19
08-17-2015 03:44 AM
kirkhilles
08-08-2015 10:53 AM
Quick Reply: Instructions on installing the rear def winshield
