Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-16-2008, 12:34 AM   #1
The Dirty Pearl
pmohr's Avatar
Nissan/Infiniti FSMs
FSMs are down...for now.
Nissan/Infiniti FSMs (Factory Service Manuals) (you can just view the individual PDF you need, instead of having to download the entire ~60MB archive):
http://www.boredmder.com/FSM/
Naming conventions explained at the bottom.
What it has so far:
Nissan/Infiniti PDF naming convention (alphabetical):
Earlier cars (fewer sections):
  • AT - Automatic Trans
  • BR - Brake System
  • BT - Body & Trim
  • CL - Clutch
  • EC - Engine Control System
  • EL - Electrical System
  • EM - Engine Mechanical
  • FA - Front Axle & Front Suspension
  • FE - Accelerator Control, Fuel & Exhaust Systems
  • foldout - Fuse/Relay boxes, harness pinouts
  • fwd - Quick Reference Index
  • GI - General Information
  • HA - Heater & Air Conditioner
  • IDX - Alphabetical Index
  • LC - Engine Lubrication & Cooling Systems
  • MA - Maintenance
  • RA - Rear Axle & Rear Suspension
  • RS - Restraint System
  • ST - Steering System
Newer cars (these depend on year and model, consult fwd.pdf for the specifics of the FSM you're looking at):
  • ACC - Accelerator Control System
  • ACS - Auto Cruise Control System
  • ADP - Autodrive Positioner System
  • ATC - Automatic Air Conditioner
  • AP - Adjustable Pedals
  • AV - Audio Visual, Navigation & Telephone System
  • BCS - Body Control System
  • BL - Body, Lock & Security System
  • BR - Brake System
  • BRC - Brake Control System
  • BRM - Body Repair Manual
  • CCS - Cruise Control System
  • CHG - Charging System
  • CL - Clutch
  • CO - Engine Cooling System
  • DEF - Defogger
  • DI - Driver Information System
  • DLK - Door & Lock
  • DLN - Driveline
  • EI - Exterior & Interior
  • EX - Exhaust System
  • EXL - Exterior Lighting System
  • EXT - Exterior
  • FAX - Front Axle
  • FL - Fuel System
  • FSU - Front Suspension
  • GW - Glasses, Window System & Mirror
  • HA - Heater & Air Conditioning System
  • HAC - Heater & Air Conditioning Control System
  • HBC - Hybrid Control System
  • HBB - Hybrid Battery System
  • HRN - Horn
  • INL - Interior Lighting System
  • INT - Interior
  • IP - Instrument Panel
  • LAN - LAN System
  • LT - Lighting System
  • LU - Engine Lubrication System
  • MA - Maintenance
  • MIR - Mirrors
  • MT - Manual Trans
  • MWI - Meter, Warning Lamp, & Indicator
  • PB - Parking Brake System
  • PCS - Power Control System
  • PG - Power Supply, Ground & Circuit Elements
  • PR - Propeller Shaft (Driveshaft)
  • PS - Power Steering System
  • PWC - Power Window Control System
  • PWO - Power Outlet
  • RAX - Rear Axle
  • RF - Roof
  • RFD - Rear Final Drive (Differential)
  • RSU - Rear Suspension
  • SB - Seat Belts
  • SBC - Seat Belt Control System
  • SC - Starting & Charging System
  • SCS - Suspension Control System
  • SE - Seat
  • SEC - Security Control System
  • SN - Sonar System
  • SR - SRS Airbag
  • SRC - SRS Airbag Control System
  • SRS - Supplemental Restraint System (Airbags)
  • STC - Steering Control System
  • STR - Starting System
  • TM - Transaxle & Transmission
  • VTL - Ventilation System
  • WCS - Warning Chime System
  • WT - Road Wheels & Tires
  • WW Wiper, Washer & Horn
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 12-18-2008, 12:16 PM   #2
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
you are my hero.
Torgus is offline   Reply With Quote
Old 12-18-2008, 01:51 PM   #3
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Eveyrtime I needed an FSM I just looked for your sig.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.478@102.3mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 12-19-2008, 05:40 PM   #4
Quote:
Originally Posted by pmohr View Post
Thought a sticky in General would be nice for this info (even better, across all the specific generation forums, but they're all pretty much cluttered up with stickies as it is):
Nissan/Infiniti FSMs (you can just view the individual PDF you need, instead of having to download the entire ~60MB archive):
What it has so far:
  • BR - Brake System
  • BT - Body & Trim
  • CL - Clutch
  • MA - Maintenance
Newer cars:
  • BR - Brake System
  • CL - Clutch
  • FAX - Front Axle
  • FL - Fuel System
  • GW - Glasses, Window System & Mirrosr
  • LAN - LAN System
  • MA - Maintenance
  • MT - Manual Trans
  • RAX - Rear Axle
  • RF - Roof
  • SB - Seat Belts
  • SE - Seat
All I can say is WOW!
Thanks!
Boomer Sooner is offline   Reply With Quote
Old 12-20-2008, 08:13 AM   #5
You can't friend yourself
Kevlo911's Avatar
I would sticky this but I don't know if it is legal
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 12-20-2008, 09:05 PM   #6
I'm watching you, boy...
SilverGLE's Avatar
Quote:
Originally Posted by Torgus View Post
you are my hero.
I have a FSM from a 4th gen, but not 5th.
__________________
Old: 2000 Maxima GLE, Sold
New: 2007 Subaru STI Limited, "The Gentleman's STI"
SilverGLE is offline   Reply With Quote
Old 12-21-2008, 05:03 AM   #7
The Dirty Pearl
pmohr's Avatar
Quote:
__________________
Old 12-21-2008, 08:34 AM   #8
Send a message via AIM to black_maxed95
pmohr, your index pages are so boring...make it look more like a myspace page and i bet youll get more hits!
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
Quote:
Originally Posted by ironwork View Post
i am knew to this forum am i am amazed at how costructive your arguments are. no flameing and well thought posts.
black_maxed95 is offline   Reply With Quote
Old 12-21-2008, 08:36 AM   #9
The Dirty Pearl
pmohr's Avatar
Quote:
Heh so 65 gigs of flash, java, and animated gifs?
__________________
Old 12-21-2008, 11:58 PM   #10
Resident Mass. Brownie
zero2sixtyZ's Avatar
Thanks for the links! Bookmarked.
__________________
zero2sixtyZ is offline   Reply With Quote
Old 02-17-2009, 05:34 PM   #11
What are the sources of these FSM's?
Do you happen to have a physical 95 FSM?
I could use one.
Rob_0126 is offline   Reply With Quote
Old 02-17-2009, 09:01 PM   #12
The Dirty Pearl
pmohr's Avatar
I could use one.
Random places, why?
No.
Classifieds, or eBay...
__________________
Old 02-18-2009, 03:26 PM   #13
Random places, why?
No.
Just making sure nissan is ok with it.
A physical book would be good, so i dont have to stare at a screen for hrs at a time, like i already do.
Old 02-19-2009, 06:22 PM   #14
Send a message via AIM to Drockb418
__________________
1998 318 ti,s50 swap, m3 brakes, green house control arm bushings,H&R race springs with bilstein struts,ASA wheels,Magnaflow catback ,sparco seats,two 10” JL audio subs,3.73 rear end,euro headlights and more to come![/center]
Drockb418 is offline   Reply With Quote
Old 02-19-2009, 08:56 PM   #15
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
He's not selling it for a profit...so its legal.
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
DrunkieTheBear is offline   Reply With Quote
Old 02-21-2009, 08:39 PM   #16
Send a message via AIM to MIK3
Seriously...myspace....?
You do not mix automotive and poorly scripted social network pages together, ever, period. I'd much rather have an index page aimed at auto enthusiasts than a 16 year old she-him who can't decide on the color of eye shadow to wear and is torn by letting the world know if they are smitten or quixotic...
__________________
MIK3 is offline   Reply With Quote
Old 04-24-2009, 04:47 PM   #17
Well this is just awsome. Just wanna say Thanks pmohr for putting this together. You Rock!
Murdoc is offline   Reply With Quote
Old 04-25-2009, 09:16 PM   #18
Send a message via Yahoo to blktalon456
pmohr is the man with advice, harsh words and? hmm LOL. Thanks man.
__________________
97 Maxx SE
Mecc Rep
blktalon456 is offline   Reply With Quote
Old 04-26-2009, 05:59 AM   #19
KRRZ350's Avatar
Send a message via AIM to KRRZ350
Quote:
I think it mentions something about any reproduction of any kind in any format is illegal, but I might be wrong. Hopefully the man doesn't come beating down his door because I've used those fsm's several times a week for months, I'd be fubared without them.
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
Cheap VIAS block plates
Dual-mass 6-speed flywheel resurfacing available!
NX wet kit w/digital gauge $400 shipped
KRRZ350 is offline   Reply With Quote
Old 04-26-2009, 06:04 AM   #20
The Dirty Pearl
pmohr's Avatar
Quote:
I didn't reproduce them
What it does say:
Oh well.
__________________
Old 05-04-2009, 01:52 PM   #21
Licensed to Spell
ptatohed's Avatar
Thanks pmohr. Would it be asking too much to include the FSM cover too?
__________________
Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
1996 GLE, Pearl/Black - Superchargerless
1993 SHO, Pearl White/Gray - Stock
Super Charger install instructions
ptatohed is offline   Reply With Quote
Old 05-04-2009, 02:44 PM   #22
The Dirty Pearl
pmohr's Avatar
Quote:
Cover?
I'm also working on modifying pdf2html, so I can put the FSM up for completely online viewing. The current one doesn't work all that great, so all the more coding for me.
__________________
Old 05-04-2009, 06:40 PM   #23
Licensed to Spell
ptatohed's Avatar
Cover?
You know, the black FSM cover.
__________________
Old 05-04-2009, 06:48 PM   #24
The Dirty Pearl
pmohr's Avatar
No idea what you're referring to, really. Whatever Nissan published as an ESM is what I have.
__________________
Old 05-05-2009, 02:04 PM   #25
Licensed to Spell
ptatohed's Avatar
The front cover of the FSM.
If one had a genuine, hard copy, Nissan Maxima FSM, it would be bound, right? It would have a front and back cover (and a spine). I have a '96 FSM and it has a black cover. I think all 4th gen years have black covers. The FSM doesn't start with the index page, it has a cover. It would be nice to be able to print out the electronic copy of the FSM(s) that you provided but I'd like to have a cover to place at the front. Not a big deal, I just thought it would be nice.
__________________
Old 05-05-2009, 02:30 PM   #26
Carbon Fiber addict
Yeah, because printing out a FULL page of black ink with a little bit of white writing really makes sense. People should/could make their own "cover" in Word in 20 seconds and save a ton of ink.....
Great work Pmohr!!
EDIT: (and don't say you'd print it out at work Ptatohed....LOL)
__________________
99 Max SE 5 spd, SC'd, MEVI, Cattman Headers, LED tails, R34's with S2000 projectors, 13.1" Brembo BBK, EU.....381 HP/323 TQ
The Wizard is offline   Reply With Quote
Old 05-05-2009, 02:40 PM   #27
The Dirty Pearl
pmohr's Avatar
Yea, Nissan never made a 'cover' page for the electronic FSMs, no real need. I wouldn't either, just one more page you have to go through before getting to what you need to know.
__________________
Old 05-05-2009, 02:42 PM   #28
The Dirty Pearl
pmohr's Avatar
Quote:
Great work Pmohr!!
IBblackconstructionpaperandwhiteink
__________________
Old 06-05-2009, 01:22 AM   #29
The Dirty Pearl
pmohr's Avatar
Updated, '09 FSMs added as well as lengthened out the naming convention explanations a bit, but since they change so much you really should view fwd.pdf for the newer ones.
'09 FSMs should finish uploading in a few hours.
__________________
Old 06-05-2009, 12:09 PM   #30
Is there a reason this isn't stickied yet??
gizzsdad is offline   Reply With Quote
Old 06-05-2009, 06:40 PM   #31
lol. And i dont blame em either
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 06-06-2009, 03:13 PM   #32
wow! that's some really decent specs on that infiniti.
londonmoon is offline   Reply With Quote
Old 07-06-2009, 07:17 AM   #33
Send a message via AIM to NismoCefiro
Random places, why?
No.
20 bux, 24 hour pass, all you can download. He is doing it for free so
__________________
2000 Infiniti I30 ::VQ30DE-K:: | 01 AE 5 Spd w/ LSD Conversion | FrankenCar Intake w/ Apexi Filter | Cattman Full Header | O2 Sims | TEIN S-Tech | Tokico Blues | Alutec FSTB | Stillen RSTB | Brembo Sports Slotted Rotors [Carbon/Iron] | Goodridge SS Lines | 12% All Around 5% Sunroof 3M | 8K 50W Digital Ballast HID | 2x Infinity Kappa Perfect 12 VQ SVC @ 2 Ohms | JBL BP600.1 |
NismoCefiro is offline   Reply With Quote
Old 07-06-2009, 10:57 AM   #34
The Dirty Pearl
pmohr's Avatar
Quote:
Do what?
__________________
Old 07-06-2009, 12:46 PM   #35
Oh my God! Someone sticky this!!!!
Haha great work, I am never going to even open my passenger compartment to look for my manual again. In fact I am going to throw that piece of unread educational material out right now
Oh and concerning the legal issue, I think all Pmohr needs to do is cite his sources and things will be fine. It worked for a college paper that I BSed, why not service manuals eh? hahahah!
Leo_Koneval is offline   Reply With Quote
Old 07-08-2009, 07:26 PM   #36
These FSM's have helped me out so much over the last year I sleep with a hard copy of the 97 and 01 FSM with me under my pillow at night.
__________________
|1997 Maxima SE|5sp|Pebble Beige|Sec.&Conv. package|SE Leather package|Cold weather package|
|00vi|VAFC2|Warpspeed B pipe|fenderwell CAI|KYB AGX/Tein S.Techs|I30 headrests & autodim|Hardwired Passport 8500|6000K 35w HIDs|
modenaf1 is offline   Reply With Quote
Old 11-02-2009, 03:34 PM   #37
Jedi Knight Academy
Send a message via AIM to maxprivate
when are these going back up? I need the fsm for the 4th gen cluster and 5th gen cluster so I can wire my 5th gen cluster in. help!
maxprivate is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
