comp tunes
Old 04-25-2007, 06:17 PM
Osburn2027's Avatar
comp tunes
what are you running mand how mutch of a diff did it make
Osburn2027 is offline
Old 04-25-2007, 06:31 PM
¯\(°_o)/¯
Greeny's Avatar
What? .
Greeny is offline
Old 04-25-2007, 07:18 PM
Nissan 6's Avatar
hahhaa???????????
Nissan 6 is offline
Old 04-25-2007, 10:53 PM
andrei3333's Avatar
HUH ?
this is the weirdest thread i have seen in a long time -- it scares me
andrei3333 is offline
Old 04-26-2007, 12:53 AM
Theyears02's Avatar
wtf are you asking? you need to explain the question better
Theyears02 is offline
Old 04-26-2007, 03:12 PM
niceguy's Avatar
Are you asking about compression or computer 'tunes'?? Not even sure why I asked....
niceguy is offline
Old 04-26-2007, 03:35 PM
97MaximaSE97's Avatar
Well I use about 5 gallons of comp tunes until the barrier reef has been obtained. To further push the limits of my car I then mix it with spluge in order to create the vernal equanox effect in the combustion chamber. The Nismo oil cap is very necessary or else the flux capasitor inside the AC unit will overheat causing the ecu to read out temps in btu's which will fry the MAF sensor and the right heater 02 bank to become damaged...
97MaximaSE97 is offline
Old 04-26-2007, 09:27 PM
Osburn2027's Avatar
computer tunes sorry didnt think about compresson sorry for not explainin g it better that one trully is my fault sorry yall. but the stupid reply is not need to show my ignorance.
Old 05-06-2007, 09:50 PM
VQ30 DE T
accordingtou's Avatar
accordingtou is offline
Old 05-07-2007, 06:48 AM
dot dot dot ...
NmexMAX's Avatar
Computer tunes. Ok, .....what?
NmexMAX is offline
Old 05-07-2007, 08:28 AM
Drug Money
MaxBoost925's Avatar
ok, let me make a CRAZY ASSUMPTION here...
1. You can be talking about using Consult II to advance the timing.
2. You can be talking about using a piggyback controller on the ECU.
3. You can be talking about using a standalone ECU.
and 4. You can be talking about downloading pr0n onto the ECU and getting a virus.
MaxBoost925 is offline
Old 05-07-2007, 10:24 PM
01SEspDaGHOst's Avatar
what r u asking
01SEspDaGHOst is offline
Old 05-08-2007, 06:58 PM
maximamaximus's Avatar
i dont even understand
maximamaximus is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
Socalstillen
09-26-2015 12:01 PM
zzznightmarezz
09-21-2015 06:32 PM
Maxboy23
09-04-2015 06:04 PM
Quick Reply: comp tunes
