Dynos
Old 01-03-2006, 08:48 AM
maxihari77SE96's Avatar
Dynos
I have a 4th gen, but I guess I am asking anybody for a link to a dyno that shows (or not) improvements for 2 things.
Lightened Flywheel
UDP
any car. been looking for a while, but i can find it.
Bear in mind, I am just looking to compare some dynos, regardless of opinions.
thx
maxihari77SE96 is offline
Old 01-03-2006, 08:54 AM
dot dot dot ...
NmexMAX's Avatar
No one has ever proven that a UDP shows gains on an A32.
NmexMAX is offline
Old 01-03-2006, 09:02 AM
..on any car, any maxima gen.
then the flywheel...
thx though
Old 01-03-2006, 09:43 AM
dot dot dot ...
NmexMAX's Avatar
I said A32, but on an A33B, I've seen only one dyno where it showed gains... But it could've been just a variance since it has since happened. Also, they are essentially the same engine, and the UDP does the same thing on each engine, so I call on the UDP.
I can't speak for flywheels since I don't have one.
NmexMAX is offline
Old 01-03-2006, 09:50 AM
nismology's Avatar
<----UDP antagonist #1
You won't find any dynos with gains from an UDP simply because they don't exist.
nismology is offline
Old 01-03-2006, 10:22 AM
s0ber's Avatar
I gained 5whp from installing the UDP.
s0ber is offline
Old 01-03-2006, 10:29 AM
nismology's Avatar
Were the before and after dynos done on the same machine?
Old 01-03-2006, 10:30 AM
s0ber's Avatar
I was just playing
s0ber is offline
Old 01-03-2006, 10:35 AM
nismology's Avatar
I was just playing
In that case........
Old 01-03-2006, 10:59 AM
Thanx guys...
I think I've read enough personal opinions on each of the mods.
I am just looking for a dyno, any dyno that will show me the results.
I already have Fidanza flywheel installed and definitely feel the difference from before and after.
thx
Old 01-03-2006, 01:46 PM
ZanatechRacing's Avatar
a flywheel won't really give you any power..... just give you the power you have more easily.... ie faster reving etc...
ZanatechRacing is offline
Old 01-05-2006, 04:12 AM
Old Maxima Legend
Ceasars Chariot's Avatar
that would be a tough dyno to find.
Ceasars Chariot is offline
Old 01-05-2006, 05:35 AM
It sure looks like it.
thx anyways
Old 01-05-2006, 08:44 AM
I just found something else though.
An article in which a magazine claims that dynoed a 350Z for a flywheel modification and it shows an increase...
http://199.199.151.63/october03/350z_fly/
what do you guys think?
Old 01-05-2006, 09:55 AM
dot dot dot ...
NmexMAX's Avatar
But the flywheel on a Z33 is a smidge heavier than that of your A32.
NmexMAX is offline
Old 01-05-2006, 10:03 AM
stock vs. stock?
then aftermarket his JWT at 14lbs vs. mine Fidanza at ... <10lbs according to Cattman's site.
So gains could be very similar.
Old 01-05-2006, 10:06 AM
dot dot dot ...
NmexMAX's Avatar
No, stock Z33 is ~ 33lbs IIRC, and yours is a much more modest 18 lbs..
Where the hell's JClaw when ya need him
NmexMAX is offline
Old 01-05-2006, 11:00 AM
The Definitive AE Master
Larrio's Avatar
The closest comparison for flywheels would be jay25's 1/4 mile trap speeds before and after he installed the flywheel. But since he was boosted at the time, it doesn't provide a accurate source. Hnda_etr also dyno'ed with every bolt on including a jwt flywheel, but IIRC the vq35 has a dual mass flywheel and difficult to compare against the vq30. I have his dyno (248whp 6spd) and you can compare that against other cars with similar mods
As for the UPD, I believe scopium did dyno before and after but I'm unsure if it was on the same machine. There is probably some buried in all the information on the org, but it would be hard to find.
You should look in the dyno forums and see if two cars with similar mods and compare those dynos. Or you can wait until I dyno as i've recently installed a fidenza and udp and have the before dyno comparison also
Larrio is offline
Old 01-05-2006, 11:13 AM
that'd be great!
how soon are you looking to dyno?
what other mods do you have?
also, percentage wise:
Z33: stock = 33lbs, after 14lbs ~ 58% weight decrease
A32: stock = 18lbs, after <10lbs ~ 47% weight decrease
not a huge difference. So the gains could be very similar. 1-1.5 hp off.
Old 01-05-2006, 12:23 PM
Larrio's Avatar
01 5spd Original dyno: 197whp/197wtq SAE correction
Intake, Y-pipe, ECU, 18" wheels
Super rich 12.2-12.5 A/F
Mods since then:
UDP, Flywheel, B-pipe, Fuel computer to correct A/F
I probably won't dyno for a bit since dyno shops in my area do not open on weekends, so you'll have to wait patiently.
Originally Posted by maxihari77SE96
that'd be great!
Larrio is offline
Ben2003GLE
31
07-17-2016 08:13 AM
MaximaDrvr
08-19-2015 08:20 PM
Chebosto
12-19-2001 06:34 AM
Nismo87SE
10-23-2000 08:15 AM
Quick Reply: Dynos
