how to stop battery terminal oxidation?
Old 12-13-2005, 06:30 PM
super6's Avatar
i keep cleaning it, even using sandpaper on it, and still it comes back every week, i know those little green pads dont work, how the hell can i get did of it for good? only happens on the neg terminal.
super6 is offline
Old 12-13-2005, 06:35 PM
JwaxMax99's Avatar
Coat the terminals in grease.
JwaxMax99 is offline
Old 12-13-2005, 07:44 PM
Slider's Avatar
Dielectric grease
Slider is offline
Old 12-13-2005, 08:05 PM
NightRider's Avatar
Usually when the battery terminals start corroding that often its a sign that the battery is coming to the end of its life. I's start looking for a new battery soon.
NightRider is offline
Old 12-13-2005, 08:22 PM
I Broke OT
86maxima96's Avatar
is that true?
86maxima96 is offline
Old 12-14-2005, 08:51 AM
super6's Avatar
but its only 18 months old
super6 is offline
Old 12-14-2005, 08:55 AM
ronin22357's Avatar
Get a battery terminal cleaner, use it, then coat them in vaseline
ronin22357 is offline
Old 12-14-2005, 09:29 AM
AscendantMax's Avatar
clean the terminals with a wire brush as mentioned, or if you don't have one, mix some warm water and baking powder and clean with that. once you get all the oxidation off, apply a layer of dielectric grease to the terminals.
AscendantMax is offline
Old 12-14-2005, 10:01 AM
geenowalker's Avatar
Hey AscendantMax
I'v been using baking soda on my terminals which kills the corosion. how well does the baking powder work.
geenowalker is offline
Old 12-14-2005, 10:30 AM
An atavistic endeavor...
endus's Avatar
Buy a sealed battery and this wont happen anymore. I will never use another battery that isn't sealed. My battery corrded like insane, and the corrosion went all down into the tray and onto the frame. Put in a sealed battery, scraped and painted the corrosion and it's no longer a problem.
Dielectric grease will help your current situation though.
endus is offline
Old 12-14-2005, 11:16 AM
I Broke OT
86maxima96's Avatar
no pun intended!
Also, some people say to use dielectric grease, while others say just vaseline. Is there any advantage/disadvantage with one over the other? Would vaseline more or less be good enough?
Old 12-14-2005, 11:52 AM
jimmycapp's Avatar
Di-Electric grease is the optimal thing to use. I have never heard of vas.
James
jimmycapp is offline
Old 12-14-2005, 09:41 PM
Maximus_95's Avatar
man, i have the same problem i just dont know why i never asked, now i know.
Maximus_95 is offline
Old 12-15-2005, 09:25 AM
tripleGmax's Avatar
my last battery had a small leak causing oxidation and crap all over the terminal. I had a "strong" tested battery, but it had a leak and caused my car to not start sometimes it was so bad. take a multimeter with the ground on the batterys ground and move the positive stick from your multimeter around the battery (not touching the battery) this will tell you if you have a leak, a small voltage pick up will indicate it.
im rocking a red top now
tripleGmax is offline
Old 12-15-2005, 10:15 AM
super6's Avatar
sounds intresting, never thought to test it that way, but what i did was find my recipt for the battery and the warranty was for 18 months full replacement and pro-rated at 1.50 per month thereafter...so i went and piked up a brand new battery for $4.50!
super6 is offline
Old 12-15-2005, 10:16 AM
tripleGmax's Avatar
4.50, thats pretty nice. what brand battery do you have?
Old 12-23-2005, 04:29 PM
retired moderator
irish44j's Avatar
irish44j is offline
Old 12-24-2005, 06:40 PM
Wrightsfd's Avatar
Vaseline will work
Vaseline is the perfect solution, cheap (you probably already have some) and works very well.
Ah, Vaseline
Wrightsfd is offline
Old 12-28-2005, 01:14 PM
Soaknfused's Avatar
You can also buy that "crap in a can" to spray on after you clean the terminals, works good.. just a lil messy if you don't spray carefully.
Soaknfused is offline
Old 12-28-2005, 03:39 PM
konak85's Avatar
The Haynes manual says to use vaseline.
konak85 is offline
Old 12-28-2005, 05:42 PM
Pointy Elbows
00MaxSE's Avatar
And if the Haynes manual told you to drive off a cliff... JK
I just bought a small pouch of the dielectric tuneup grease from Murrays. Just a few bucks.
00MaxSE is offline
Old 12-28-2005, 05:44 PM
tripleGmax's Avatar
jason my manual says that you are supposed to go to the junkyard and buy me that bumper.....
Old 12-28-2005, 05:48 PM
Pointy Elbows
00MaxSE's Avatar
Oh ok Gregg, I'll get right on it.
00MaxSE is offline
Old 12-29-2005, 10:15 PM
konak85's Avatar
vaseline is best, you can use it for many other purposes too
konak85 is offline
Old 12-30-2005, 12:32 AM
Originally Posted by geenowalker
Hey AscendantMax
seems to work pretty well...seems to neutralize any acid in the area.
Old 12-30-2005, 01:28 AM
MrGone's Avatar
don't forget to mix some baking soda and water and wash down the area around the battery every 6 months or so.
your car will thank you in the long hall (well, and you will too )
MrGone is offline
Old 01-05-2006, 08:42 PM
Tenn05's Avatar
White lube engine assembly grease works well,,,,,,,,,, or you can try the old trick, super glue two pennys on the top of the battery the copper is suppose to do something for it.????????????????
Tenn05 is offline
D Mason
06-21-2016 04:43 AM
BobTX10
10-07-2015 08:43 AM
bigfrank
10-01-2015 12:51 PM
maxima297
09-30-2015 03:32 PM
Quick Reply: how to stop battery terminal oxidation?
