13" Cobra + Q45 / J30 Caliper upgrade possibility
Old 12-09-2005, 01:56 PM
I'm needing a caw
Jeff92se's Avatar
As you know, the more common bbk here on .org is the Cobra 13" rotor / 300z 4 piston caliper upgrade. This requires my bbk relocation brackets and my centering rings. Along with the correct brake lines and some minor extra bolts/washers/nuts. Pic is here
bbk upgrade
Although wheels that clear this setup is never been easier to get. ie.. 17"+ G35/350z/98 Cobra etc..... some still view as this too expensive.
Now the point:
The 90-96 Q45 and 93-97 J30 use the iron 2 piston caliper and the oem rotor thickness is about 30mm. Same as the 30mm 300z iron/Alumin calipers. These calipers also share the same mounting dimensions.
As long as the caliper shape is the same as the 300z sans the 2 outside caliper pistons, we should be able to use the following:
My bbk brackets/rings + 13" Ford Cobra rotors + correct lines + minor amount of bolts/nuts/washers to bolt right up to a 3-gen/4-gen/5-gen (with minor additional mods).
This should allow for a cheaper route for upgrading (Calipers are pretty cheap) and finding wheels that clear should be ALOT easier as both pistons are in the inside vs the 300z (2 inside 2 outside)
This hasn't been tried yet as far as I know. But I'd be willing to offer one set of brackets/rings for let's say $70 shipped vs the normal $90 shipped if someone were ready to go. ie..has the calipers and just needs to try. Or maybe I can send just one of my prototype bracket/ring for a trial test fit.
Does someone have a picture of a Q45/J30 Caliper?
Jeff92se is offline
Old 12-09-2005, 06:02 PM
The Definitive AE Master
Larrio's Avatar
I think this is it Jeff:
http://cgi.ebay.com/ebaymotors/BRAKE...spagenameZWD1V
Larrio is offline
Old 12-09-2005, 06:24 PM
'Trynna' is not a word
mtrai760's Avatar
I was thinking about just throwing on some stock Q45 front brakes to see how much of an improvement, if any, they offer. Won't be until summer though. I don't want to replace my stock wheels.
mtrai760 is offline
Old 12-09-2005, 07:28 PM
I'm needing a caw
Jeff92se's Avatar
That's only 1/2 of the caliper. It's missing the piece outside.
I looked at a set of Q45 calipers tonight. From what I see, this should work.
Originally Posted by Larrio
Jeff92se is offline
Old 12-09-2005, 10:40 PM
es_amixam's Avatar
I have a set of Q45 calipers and i just measured them. The caliper bracket width is 28mm at the top of the opening and widens to 33mm throughout the rest of the opening. I'll be trying this upgrade tomorrow and seeing if the calipers fit under stock 15" wheels.
es_amixam is offline
Old 12-10-2005, 07:49 AM
SLOW
Nealoc187's Avatar
I know a guy with J30 calipers on his 3rd gen.
Nealoc187 is offline
Old 12-10-2005, 08:43 AM
Zack342's Avatar
tilley installed J30 calipers on a max not to long ago.
Zack342 is offline
Old 12-10-2005, 10:39 AM
Lightly modded
95maxrider's Avatar
And he likes them a lot more than the 300zx calipers he had on before. He thinks it's due to our master cylinder not being up to the task of the 4 pistons in the 300zx, but being able to handle the J30's 2 pistons better. Kind of makes sense too....
I might eventually be interested in some Cobra/J30 upgrade when my brakes need replacement....
95maxrider is offline
Old 12-10-2005, 01:48 PM
Tha Snatcher
Iron Scimitar's Avatar
sounds promising! sign me up!
Iron Scimitar is offline
Old 12-11-2005, 05:57 AM
I30tMikeD's Avatar
I have been planning to run J30 calipers with stock size rotors in the spring. Want to keep my 15's.
I30tMikeD is offline
Old 12-11-2005, 11:00 AM
jimmyfloyd's Avatar
So the J30's actually fit onto the back of the maxima? Would you suggest finding used ones, or buying new? Money is tight, but stopping is desired.
jimmyfloyd is offline
Old 12-11-2005, 11:09 AM
SLOW
Nealoc187's Avatar
We are talking about the front brakes here, not the back.
New ones will run you hundreds of dollars, so I'd suggest used...
Old 12-11-2005, 11:15 AM
retired moderator
irish44j's Avatar
I wonder if they would be direct bolt-up using the 6th gen rotors .....
irish44j is offline
Old 12-11-2005, 11:19 AM
I'm needing a caw
Jeff92se's Avatar
The stock MS is enough for the 300z calipers. I've run my setup for almost 2 years. Drive a maxima with 13" rotors and 300z calipers and report back if you think they aren't up to the task. The difference in bore diamters for the maxima/300z is 1/16". The only reason I bring this possibility up is to still allow great breaking but with more wheel options
Jeff92se is offline
Old 12-11-2005, 11:22 AM
I'm needing a caw
Jeff92se's Avatar
No. Nissan rotors have the wrong offset to make this work. Plus the 6th gen rotors are too small for my brackets. People that want a bolt on option with smaller/thinner rotors should use the entire 6-gen setup
Jeff92se is offline
Old 12-11-2005, 07:27 PM
retired moderator
irish44j's Avatar
gotcha....after re-reading it I see what you're saying.....this thread is a bit convoluted
I already have the full 6g setup, just looking at other options that would be lighter weight (probably 2pc rotors)...
irish44j is offline
Old 12-11-2005, 07:33 PM
michaelnyden's Avatar
matt blehm just recently had the 6gen rotors made in 2 piece but they are rather expensive...inquire him for more info...
michaelnyden is offline
Old 12-11-2005, 07:42 PM
Tha Snatcher
so...what are we waiting on? Is this possible w/ Jeff's bbk brackets/rings + 13" Ford Cobra rotors + correct lines + minor amount of bolts/nuts/washers to bolt right up to a 3-gen/4-gen/5-gen? Is this proven?
Old 12-11-2005, 07:58 PM
SLOW
Nealoc187's Avatar
You don't need different lines with the J30 calipers. Yes it works, as a few have said there are people already running j30 calipers (not with jeffs brackets though.)
Old 12-11-2005, 08:00 PM
Tha Snatcher
so one could just swap out the stock caliper w/ the j30s?
Old 12-11-2005, 08:32 PM
SLOW
Nealoc187's Avatar
well the stock rotor is pretty thin for the j30 caliper which is made for 30mm rotors... I think the 4th gen rotor is only 24mm if my memory is correct. it might work though but I don't know if anyone has tried that. The guy I know who did it used 300ZX (same as J30) rotors. Use the maxima torque member and the j30 caliper, j30 rotor, maxima brake line.
BTW the pads are the same between the J30 and max iirc so no you don't have to buy new pads either.
Old 12-12-2005, 02:38 AM
Tha Snatcher
nice, great info
Old 12-12-2005, 10:35 AM
SomePsychoGuy
SPiG's Avatar
Could someone double check to see if the pads are the same between the 2 piston Q45/J30 and the 1 piston Maxima? If they are then this will be a very nice upgrade.
SPiG is offline
Old 12-12-2005, 10:40 AM
I'm needing a caw
Jeff92se's Avatar
I would assume they are different. It's not a big deal to buy pads for the J30/Q45 calipers.
Jeff92se is offline
Old 12-12-2005, 10:49 AM
Cutler's Avatar
I am sure the maxima MC is up to the task, but could a j30 or q45 MC be more advantageous? When I upgraded the brakes on my 91 SE-R to NX2k brakes, I upgraded my MC to the Altima MC. It made a nice difference. It's just a thought and may be a nice upgrade that no one thought about until now....
Just a thought.....
Cutler is offline
Old 12-12-2005, 10:53 AM
es_amixam's Avatar
The pads are different for sure. They are slightly wider and the notches holding them to the caliper bracket are smaller.
Old 12-12-2005, 10:55 AM
I'm needing a caw
Jeff92se's Avatar
If it were just plug and play to upgrade to a 300z MC, I would. But the mounting and the lines are completely different. It's way too much work for that ever so slight diff in pedal travel. The Q45/J30 have 1/2 of the pistons the 300z has. And I don't think their MC is any larger anyway. I'll have to look. But I know it's not any bigger than the 300z
Just a thought.....
Jeff92se is offline
Old 12-12-2005, 11:38 AM
I like Maximas
vipervadim's Avatar
ok guys a few things here from the maxima brake master:
0. If you don't have SS brake lines (and Speedbleeders, IMHO) you need to go get them ASAP if you want better braking, that's a NO ARGUMENT discussion.
1. 300zx brakes don't necessarily need bigger rotors or those brakets to extend them out, they fit in stock caliper location perfectly, BUT a small modification to rotors (20mm maxima thicknes vs 30mm for 300zx rotors) is required by milling the rotor diameter 4-5mm. ($20/rotor in a machine shop)
why would you want to extend the caliper further out if you don't have to?
(only reason i can think of to get bigger rotors, to increase surface area so it cools better, but that's extra weight, and you don't want to drive with heavier calipers, heavier rotors, and heavier wheels, unless you specifically WANT to)
and you can still use a 16in wheel, not 17's for those days when you go to the track with 300zx, more on wheels see 4.
2. 300zx brakes offer MUCH better brake pad selection than J30/Q45 and offer more brake cylinder pressure to the rotors than ANY two piston caliper including the DIRECT FIT A32 Cefiro Dual Piston Calipers, i still have them in a box
3. 300zx brake master cylinder is at 17/16 with 850lf vs 15/16 with 800lf of maxima, a 1/8 difference, significant when you increase from 4 total caliper pistons to 10 caliper pistons, furthermore the REAR brakes work much better due to 300zx proportioning valve (more clamping force also goes to the rear brakes, i can actually feel them working now!)
4. 300zx needs bigger offset wheels, due to two pistons on one side of the caliper and two on the outside of the caliper. why not use N/A 300zx rims like i did, 16.0lbs each with size of 16x7.5 - rims will run you about $300 on ebay. if you have stock 215/55/16 tires they will transfer right over too. although i'd rather use the 225/50/16's with Z32 Rims.
5. Let's talk about weight everybody likes to save a little off the car, then why would you replace the already heavy iron stock calipers with even heavier two piston iron calipers? aluminum 300zx's weight as much as the stock single piston brakes (but you get an extra 3 pistons and a very well distributed clamping force from both sides equally, other than even having TWO pistons clamping on ONE side.)
6. looks. everybody wants their BIG brakes to look good, 4 piston calipers stick out and look much better than the stockers painted ANY color. besides you will have the BEST factory NISSAN calipers made for the 300zx, R32 Skyline, and that will get you more points at shows/ and more peace of mind because THEY WILL SAVE YOUR LIFE when that uncertain time comes when you need to bury than pedal in, to stop from hitting something (just be buckled up or YOU WILL FLY OUT THROUGH THE WINDSHIELD, no kidding!)
the only thing i don't like about my brakes now is the stock rear POS weak calipers which will be replaced with 2-piston 300zx rear calipers and 300zx E-brake drum assembly after the winter. then i'll have complete 300zx brakes conversion
and some statistics:
300zx ~3600lbs, 300hp 12 pistons total in all calipers
Maxima ~3100lbs, 190hp 4 pistons total in all calipers
which would you rather have stopping your Maxima?
one more question.
which brakes are the Supercharged/Turbocharged people running? stock? is that really such a good idea with all that power?
ANYBODY want to please chime in and prove me wrong???
P.s. Brakes are a big confidence booster, you can drive faster and harder if you know you have great brakes, and then the maxima becomes a Fun car to drive. i have tons of pics of my installs if somebody wants pics, or to weigh your options, pm me
-vipervadim
vipervadim is offline
Old 12-12-2005, 11:53 AM
Tha Snatcher
one more question.
-vipervadim
What are you trying to prove? That the 300ZX upgrade is better than the J30/Q45? Well, that's been proven, (4 piston vs dual pistons per caliper blah blah blah) but the J30/Q45 combo looks to be the "bang for your buck" option which gives the driver improved performance over stock.
Nobody is talking down the 300ZX BBK (it kinda sounds like you are defending it), the J30/Q45 combo just offers a more cost-effective solution w/o going overkill on the 300ZX upgrade....just offering us another option.
I'm needing a caw
Jeff92se's Avatar
There is a slight pedal feed difference. That's about it. It's a good idea to swap if your oems are old though
A few incorrect things. Moving the torque arm out futher by relocating the calipers outward GREATLY increases the braking. More than having more pistons and the stock smalled sized rotors alone IMHO.
And the modification is to the rotor's DIAMETER/RADIUS. Not the rotor's THICKNESS. You are talking about two very different things.
See above.
Do you have the calculations for me to see? MORE pistons do NOT always equal MORE pressure. It's the total piston cylinder AREA that dictates how much force is applied.
You have pics of the 300z MC in your maxima? Because the mounting and brake line direction is very different.
People do all the time with the simple 300z swap.
You DO know that the Z32 300z were NOT that highly rated for braking right? Why? Because they had to cram the calipers to fit inside the oem 16" wheel. So they had to use smallish rotors. Hurt performance and often warped the rotor.
I already run these. But that's not the point of THIS thread.
I suggest buying this kit from Matt Blehm. It's not an easy swap. Fortunately, I can run 1" larger rotors on my 3-gen very easy.
Jeff92se is offline
Old 12-12-2005, 12:07 PM
Cutler's Avatar
I totally understand the Geometry issue, the Altima MC was a direct replacement but if the 300xz MC isn't a direct bolt on then I think it's not worth all the fabbing that would be required.....
Cutler is offline
Old 12-12-2005, 12:14 PM
I like Maximas
vipervadim's Avatar
Jeff if you read carefully i never mentioned anything about milling thickness, i wrote the difference in maxima/300zx thickness, the milling of 4-5mm is from the diameter like I stated. please re-read carefully
yes i do have pics of everything installed, i just don't have any on the web. i can send you e-mail if you are interested.
the 300zx MC is direct swap you just need to have ***** to undertake the (messy, lots of brake fluid) swap. most people on the org talk about doing things, only few have those aforementioned ***** to rip into their maxima, especially if it's something people say can't be done.
my whole brake swap cost me about 500. Matt's rear brake setup is close to $1000, and that's about the cost of a 3.5L so which would you think i'd do first if i had the money to spend?
about brake pressure:
i had the Cefiro 2-pistons installed before i went the 300zx route. there is A HUGE feel difference between the 2-piston and 4-piston even on the stock MC. with the 300zx the proportioning is better, so brake bias is not so much to the front as stock MC.
about wheels:
you WILL need to run more offset wheels than stock maxima wheels to clear the 300zx calipers. 300zx are a good affordable direct replacement if you don't have $1000 to spend on bigger rims and tires.
on surface area:
if you have bigger rotors then why is the surface area of the pad contact to the rotor still the same? it will only be as big as the pad gets, your calipers just sit more outward than mine
where did you get the info about z32 brakes having less clamping? link please?
Old 12-12-2005, 12:28 PM
I'm needing a caw
Jeff92se's Avatar
Jeff if you read carefully i never mentioned anything about milling thickness, i wrote the difference in maxima/300zx thickness, the milling of 4-5mm is from the diameter like I stated. please re-read carefully )
Cool
Email pics to me in my contact here. "Jeff_Iwata@yahoo.com"
Exactly how is it a direct swap when the mounting bolts are east/west and the maxima is north/south? It CAN be done. But it's not easy.
Send those pics too
I didn't notice much difference. And my bias is fine with my larger 1" larger Z31 rotors.
about wheels:
I'm well versed on what wheels clear/don't clear. As I've run mustang wheels/G35 wheels/350z wheels that all clear my bbk w/ no spacers.
on surface area:
if you have bigger rotors then why is the surface area of the pad contact to the rotor still the same? it will only be as big as the pad gets, your calipers just sit more outward than mine :
And because they sit out ALOT futher, the torque arm advantage is MUCH greater. It's why makers offer 13" bbk setups Ever wonder why all high performance cars run larger rotors now?
Torque arm advantage is exactly why AEM offers larger rotor package w/ stock calipers for the hondas. It's also why there is a larger rotor package for the G35 using the oem calipers. It's why Matt offers the 6-gen rotor package that uses the stock 5-gen calipers.
ie..http://www.racingbrake.com/main/prod...ct_release.asp G35 / Z upgrade.
I didn't. I was asking where you got the info that the Z32s had more.
Jeff92se is offline
Old 12-12-2005, 06:36 PM
SLOW
Nealoc187's Avatar
Hello McFly... I said you use the Maxima torque member which is what holds the pads, thus you use maxima pads...
Old 12-12-2005, 07:52 PM
ColdSHO's Avatar
anyone know if the q45/j30 clipers will work witht he relocation brackets and 04 rotors?, i know where i can get a set of each at the j-yard that im going to tomo. if not, ill get them anyway, either way ill have at least one set to sell
ColdSHO is offline
Old 12-12-2005, 08:39 PM
I'm needing a caw
Jeff92se's Avatar
No. Why does everyone try to mix and match so much. My brackets are designed for the 13" Cobra rotors. The 6-gen rotors are too small in dia and have the wrong offset
Jeff92se is offline
Old 12-13-2005, 06:21 AM
ColdSHO's Avatar
im thinking of mixing and matching casue id liek the best brakes(like everyone else) but i need them to fit under stock 17s, i figured the j30s to be smaller than the z32 which we all know wont fit. so it seemed the j30/q45 calipers+relocation brackets+04 rotors+good pads-stock 17inch rim clearance=the best setup.
ColdSHO is offline
Old 12-13-2005, 11:11 AM
I'm needing a caw
Jeff92se's Avatar
Actually he used a combination of J30 2 piston cylinder body and maxima torque member. He's using a different method to avoid having the rotor shaved.
Jeff92se is offline
Old 12-13-2005, 04:07 PM
MAX2000JP's Avatar
Jeff, I know you are trying to sell your brackets here.
Can't you use Matt Blehms Brackets, then J30 calipers will work with 12.6" rotors? Am I missing something here. A friend of mine has 12.6" 350Z rotors that he is giving Neal for free. We figured those rotors and J30 Calipers would be a nice upgrade over stock.
MAX2000JP is offline
Old 12-13-2005, 04:13 PM
I'm needing a caw
Jeff92se's Avatar
If you want to do that, just use the whole 6-gen assembly.
Jeff92se is offline
Quick Reply: 13" Cobra + Q45 / J30 Caliper upgrade possibility
