View Poll Results: Otto vs Custom Enterprise
Otto
34.04%
Custom Enterprise
27.66%
other (specify)
18
38.30%
Voters: 47. You may not vote on this poll
Newbie’s question – FSTB
#43
Driving is the next best thing
Hey people, finally installed and tested my FSTB
Installation was not as easy as I thought. In order for the brackets to fit perfectly I had to trim both the brackets and the metal on one of the strut towers. After that I covered those spots with clearcoat and only then installed the FSTB
The holes on the brackets were wide just enough for the bolts to fit in. I tightened the nuts to 40 lbs-ft and FSTB bolts to 30 lbs-ft. Fist, wanted to make them tighter but it felt like they were ganna crack - they would probably never crack but I got scared and stopped.
Driving impressions:
Today I took my car for a drive and drove it on highway, highway ramps and bumpy roads. During normal driving I got a slight increase in steering feel. At highway speeds 70 – 100 the increased steering feel is more noticeable. On bumpy roads the car handled better but the ride became a little harsher (I don’t think a passenger would notice this difference though) than before.
Highway ramps is where my FSTB demonstrated the most noticeable difference. Before when I would take a corner at car’s maximum abilities it showed horrible understeer. Now, when I took my favorite “test ramp” I was very pleasantly surprised. Obviously, the car still understeers but now it is much closer to neutral. Basically, if we take understeer of a stock Max as 100% and neutral steer as 0% than the bar decreased understeer buy at list 60 -70% Previously, the fastest speed I could take that ramp was a little under 40 mph with the front tires literally screaming. Today, the needle was at 43+ and the car felt much more predictable.
Bottom-line: I recommend FSTB to everyone who still does not have it.
Thanks to everyone who helped me deciding on which bar to get and explaining how to install it.
#44
I've got a question kind of related to this thread...does hard cornering wear out the ball-joints and all the other links that are connected to the steering system? I know it wears out the tires much faster but what about the steering components? How about bearings?
#52
#53
The strut towers are not perfectly smooth (as you can see on the lower part of this pic). So when I put the brackets on, one of those uneven spots got in the way and did not let the brackets be in a full contact with the strut tower surface. To fix that, I simply cut a small piece off of each bracket. I also had cut off a small metal thing that got in the way of the bar (driver side strut tower, not shown on the pic).
Sorry, it's been pretty long time ago so I can't describe exactly what I did...
#56
Originally Posted by d00df00d
Well, first of all, I can't really say much about the performance of the 5th gen bar because.... I have a 4th gen, and I got the 4th gen bar, which IMO is pretty different. The 5th gen still looks like a pretty stout design to me, and I still think it'd be a better alternative than the Stillen bar because it's much cheaper, but since it's designed more like most FSTBs than the 4th gen one, I just don't have enough info to tell you whether it'd be as worth it for the money as the 4th gen one is.
I bought the 4th gen one because it's designed a lot more robustly than most bars we see in the US. Look at how broad the bar is, and look at where the bar attaches to the mounts: It's a heck of a tougher way to mount the thing than those thin attachment points on every single other FSTB for the Maxima:
#59
Originally Posted by EnsignB
Is the Otto bar no longer available for a 2002 Maxima?
Thanks.
Thanks.
i tried buying a otto bar back in may of 06 and procarparts said there would be a 2month wait so i cancelled my order. now that i want it again, its not available. sigh
#60
Nothing like digging up an old post, but FYI.......
I just purchased a NEW OTTO FSTB about 1 1/2 months ago although it was $90. It is really a great bar; nicely finished and fit perfectly.
It seems that there may be still a few available new out there. I don't know if I can post the name of the place which I bought it but if anyone is interested in knowing where, let me know!
#61
I'd like to know where you got it. Been looking for one.
Thanks!
Thanks!
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
