Energy Suspension Motor Mounts installed.
#121
These will increase vibration but not as much as the much harder Place Racing type. Its certainly vibration that can be overcome by slip launching at 3K.
Why would you put the bushings in hot water? That would only expand them. If anything put them in the freezer.
#122
#123
What ive seen and sounds pretty good is to take a tower melt the inards, then take a sawsall and cut the inner ring out of the mount. Then take and put the insert in the mount just enough so that it will stand up right. Once its able to stand on its own and straight put it in a vise bench and press it in.
#124
Almost all materials, with the notable exception of water, expand as they get hotter and contract as they get cooler. So no. But I think that heating the bushings would make them softer so that could make them easier to press in.
#125
Does anyone know of any write-ups on removing and installing motor mount inserts for the do-it-yourselfer? I may have to resort to that.
#126
#127
vquick you can check the sr20forums as alot of them have done them thereselves. You will what a sawsall because it is openeded and powered. I would also get some metal blades so you can actually cut the metal. The regular ones dont work so well.
I also think some lube a piece of wood and a sledgehammer will probably work.
#130
For future reference, here's the thread (see post #11): http://www.sr20forum.com/showthread.php?t=70291 Props to Justin on that forum for his method!
Thanks everyone.
#131
Ok....I'm bringing this thread back.....
Broaner- Do you have personal experience with both?
Has anybody else gone from PR mounts to ES? My PR mounts vibrate a good deal at idle. I would like to see if anybody else had experience with both.
#132
The listing on the suspension.com says that the Energy Suspension Motor Mounts will not work with my Automatic maxima? why is that?
Is filling them with urethane my only option besides buying new ones from the dealer?
Thanks,
Dave
Thanks,
Dave
#134
in addition to achieving the cores at the junk yard, that another option is for the maxima automatic since I have looked very much in Internet and there are no others restored, although any of them manage they do not say that it marks they are but alparecer is the same of ES, a good serious idea that someone providing which is the diameter of motor mounts front, the automatic support measured 10 cm., someone can say all that measures the manual.
http://dl18cg.rapidshare.de/files/28...7/DSCF1201.JPG
sorry for my english only speak spanish
QueensMAX
09-15-2015 04:14 AM
Violator
09-09-2015 10:14 AM
