Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-21-2001, 07:50 PM   #1
I always see people with chrome or 18's or 19's talk about how their rims slow them down, and get them poor times at the track... How much of a difference do they really make?
Is there some sort of formula or way to calculate how bad it would be? How much heavier can they be then stock for you to still get reasonable or unnoticeable acceleration?
I am about to get some 2000 SE/GLE 16 X 6.5" rims.. They are 20 lbs each. How much would that slow me down? Would I really notice the extra 3-4 lbs per wheel I will pick up? Diameter will remain the same, since the tire is 50 series in profile...
so would 4 or maybe 5 extra lbs per wheel compared to stock make a big difference? What would that throw my 1/4 time off by?
thanks....
__________________
1 3rd gen, 2 4th gens, 2 5th gens.. gone
Acura CL-S 6spd.. gone
MB CLK.. here
NYCe MaXiMa is offline   Reply With Quote
Old 04-21-2001, 07:52 PM   #2
My other car is a Hybrid
Chunger's Avatar
Dunno about the exact 'numbers' but it'll be enough so you'll want "BIG BRAKES", headaches and all
__________________
"Run of the mill" Pebble Beige Maxima
Chunger is offline   Reply With Quote
Old 04-21-2001, 08:10 PM   #3
Got Bent?
UMD_MaxSE's Avatar
Send a message via AIM to UMD_MaxSE Send a message via Yahoo to UMD_MaxSE
Basically, the thing that will determine how much of an impact a wheel has on accleration is the moment of inertia. For a wheel + tire combination, most of the weight is at the radius, furthest from the axis of rotation. The moment of inertia is proportional to the mass multiplied by the radius squared. So, as the radius increases, the moment of inertia (I) goes up squared. The mass also causes I to increase. So, changes to the radius or mass results in big changes to I. Now, knowing the moment of inertia, we can look at the equation for torque, tau = I * alpha. tau = torque, I = moment of inertia, and alpha = angular acceleration. Using this, we can see that a larger I will require more and more torque to reach a certain angular acceleration. Thus, the engine must be able to produce more torque to achieve a certain acceleration.
But, the handling benefits of larger wheels can not be ignored
UMD_MaxSE is offline   Reply With Quote
Old 04-21-2001, 08:14 PM   #4
Permanent Maxima.org Resident
Confused's Avatar
16's here I come
Quote:
__________________
MAXIMA.ORG "Where old threads never die"
Confused is offline   Reply With Quote
Old 04-21-2001, 08:14 PM   #5
Chunger's Avatar
Aren't you sorry you asked now!
Quote:
Originally posted by UMD_MaxSE
Basically, the thing that will determine how much of an impact a wheel has on accleration is the moment of inertia. For a wheel + tire combination, most of the weight is at the radius, furthest from the axis of rotation. The moment of inertia is proportional to the radius squared. So, as the radius increases, the moment of inertia (I) goes up squared. So, changes to the radius results in big changes to I. Now, knowing the moment of inertia, we can look at the equation for torque, tau = I * alpha. tau = torque, I = moment of inertia, and alpha = angular acceleration. Using this, we can see that a larger I will require more and more torque to reach a certain angular acceleration. Thus, the engine must be able to produce more torque to achieve a certain acceleration.
__________________
Old 04-21-2001, 08:16 PM   #6
Chunger's Avatar
Re: 16's here I come
I hope it doesn't come down to that!
Quote:
Originally posted by Confused
__________________
Old 04-21-2001, 08:21 PM   #7
Got Bent?
UMD_MaxSE's Avatar
hehe I was bored
Old 04-21-2001, 08:41 PM   #8
.3 sec in the 1/4. Now, wasn't that easy. 16" wheels aren't that bad.
brubenstein is offline   Reply With Quote
Old 04-21-2001, 09:27 PM   #9
Confused's Avatar
Re: Re: 16's here I come
me too... i like my wheels dunno if the spacers are the answer
__________________
Old 04-21-2001, 10:15 PM   #10
I'm not sure if there is a corelation or not, but my friend had a set of stock 17" GS400 wheels on his car and came across a set of light weight 17" wheels with the same tires and all. Apparently the ride was smoother and felt more solid with the stock wheels. He gave his stock wheels up to me and got himself a set of 18's...so we're both happy.
Kevin Wong is offline   Reply With Quote
Old 04-21-2001, 10:43 PM   #11
uhh
UMD Max, sorry I asked..
Brubenstein, thank you, that was what I was looking for, not that I race my car or anything...
20 lbs per wheel, compared to the 15-16? stock ... tire + wheel combo of 16's = 44-46 lbs..... stock 36-39? Not too bad, I've driven with 30 pound 17 inch rims, so 20 will seem cool..
Big Brakes, no thanks, I'm good for now
__________________
MB CLK.. here
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
