04-21-2001, 08:52 AM
had a little accident with a spray paint car what would be the best way to possible remove this ...
thnx in advance.
04-21-2001, 09:08 AM
Your not going to beleive this, but it actually works (I've done it myself after *%^$ing vandals spray painted my old car back in 1990). Go to the grocery store and get some "Lemon Extract Juice". I beleive McCormick brand sells it. It takes the paint right off and doesn't hurt your cars paint. A guy who used to work on typewriters tipped me in on this. He said it was the only way to get "white off" off of a typewriter without damaging the type writer itself. Good luck.
04-21-2001, 09:17 AM
Minister of Silly Walks
Points: 37,185, Level: 100 |
Clay bar?
__________________
2001 Xterra XE
04-21-2001, 09:33 AM
hi i have used wax/cleaner to remove small amounts of spray paint
04-21-2001, 09:40 AM
clay bar...
it will come right off...
04-21-2001, 09:41 AM
A lot of elbow grease in my opinion. No, but what I would suggest trying is using "a tad" of nail polish remover, also depends what color your car is. Try it, give us the results.
04-21-2001, 12:07 PM
clay bar works for sure
__________________
2006 SGM IS350 - selling...
1991 FJ80 - MetalTech front, Superwinch EP9, sliders, IPOR skid, 5.29s, ARB/Aussie Lock'd, 35s KM2, OME 850+1/863, BajaRack, Warfield drawers
Gone: 1995 Nissan Maxima, H&R/KYB AGX, Cattman y-pipe, dry 50-shot NOS, UR UDP, VB mod, Greddy exhaust, Rota Battle 18s, Stillen kit...
03-02-2006, 02:34 AM
SHIFT_om nom nom nom
I use bologna and soda
__________________
Quote:
Originally Posted by airwolf09
nah, that is not the TPMS icon. as my tire pressure (!) is still off. this is the icon  triangle with exclamation mark. so it is some type of warning.
Quote:
Originally Posted by Metal Maxima
NO, WE HAVE NEW FOLX
Quote:
Originally Posted by JAMAICANLOVRBOY
OR FOLX, WHICHEVER WORKS BEST FOR YOU
03-02-2006, 05:34 AM
Play with my balls
Points: 23,906, Level: 94 |
goof off strips the clear coat. do not use that.
03-02-2006, 08:36 AM
EZ off oven cleaner!!!!
03-02-2006, 09:06 AM
Try claybar first. Other chemicals have the risk of causing damage to the clear coat.
03-02-2006, 09:14 AM
STFU n00b!
Points: 40,020, Level: 100 |
DO NOT use fingernail polish remover or oven cleaner!!! It WILL damage your paint.
to remove the overspray, you have several options.. if it's just the misty overspray crap, you can take it right off with a clay bar. If you actually 'painted' the car, you'll probably need to go to somethimg more aggressive, like rubbing or polishing compound and an electric buffer. That will take it right off, then you just need to re-wax that part of the car and you're done. will only take a few minutes.
If you got it on your glass (GLASS ONLY!!!), you can use a razorblade or some very fine steel wool and gently rub on the glass to remove it.
03-02-2006, 01:51 PM
100 grit sandpaper
03-02-2006, 03:07 PM
The Definitive AE Master
I used 3M rubbing compoud, came right off
03-02-2006, 03:40 PM
larrio, any idea how to get caliper paint off leather seats?? just ONE drop
MaximaOrg
Nissan Maxima
Paid Advertisement
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
