What are the best yellow fog bubls?
Originally Posted by Dasyce
i like my Piaa Ion Crystals!
the contrast off the HIDS are beautiful..
Narvas can be 55W, 85W and 110W. The gold though is 55W. go to www.suvlights.com
If your looking to get something like the lexus type foglights i would buy narva gold and also lamin x film to put over your foglights, Irish44 has them out including other members i think they look very close to oem lexus and nice in general.
I have some Hella Yellow Gold 85w H3s.
The one on the right is a the 85w Hella Yellow Gold. The one on the left is a 55w XD5. My headlights are also XD5s. The bulbs are somewhat yellow, but not enough for my taste. I am probably going to buy some kind of projectors. I have yellow stock fogs on my Infiniti QX4 and I like the way they look.
I think the 95-96 glass is a little more hefty from what I've read. Search if you can. Just make sure you don't touch the bulb or get any moisture in the housing.
It's only been about 6 months since I've had my Narva's but I hvaen't had any problems with them.
Is there a huge diffrence between the NARVA 85W and 55W bulbs? I am going to think that the 85W is much brighter but doesn't it run the risk of buring the wiring with an 85W bulb.
Originally Posted by R.I.P. Grandma
Yes if you run an 85w bulb in your fog you could either crack your lens or burn your harness. Run a 55w and you should be fine.
I got mine in Feb so it's acutally been 9 months. It's been through 3 months of Northeastern winters, Northeastern rains in the spring and hot, humid summers. No problems what so ever. Now, it's important to know that I was meticulous when I installed them and made sure NOTHING got into the housing and no fingerprints or anything got inside.
85 watts is bright as hell. I had 55w but they were dull against my HID's. 85 was the way to go. i am smart about using it. I rarely will use it on long 9 hour drives continuously unless I need it. When I am tooling around town however, I usually have them on all the time at night.
If you are really worried about the burning issue, you can replace the thin wire with thicker gauge wire. If you don't have HIDs, go with 55w, you will be happy with them but if you have HID, 85 is awesome!
good luck
good luck
Great info Rowan. one more question is there any truth to 95-96 fog lights being better quality than the 97-99 fogs? i would love to get the 85W but i am probally just going to get the 55W since there will be no problems. i can't afford to replace those expensive fogs
Originally Posted by CKOTuHA
How much are Narva 55W bulbs?
narva golds @ 55W are 18 and some change at www.suvlights.com
I only see Candlepower - Gold at www.suvlights.com available with 55W for H3. Narvas are 85W.
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Calabar
10-05-2015 09:57 PM
