New personal Best...14.19@100.16mph
Copied from 1/4 mile forum
http://forums.maxima.org/showthread.php?t=348201
Went to the track tonight. I ran in full street trim with no weight reduction other than spare tire/ jack. The only mods that I have done since my last 1/4 mile track visit here were :
Cattman Headers
Cleaned air filter
Adjustable fuel pressure regulator (adjusted 2-4psi over stock)
I ran a :
60...2.172
1/8...9.202
mph...77.16
1/4...14.197
mph...100.16
other passes were 14.217@100.60mph, 14.381@100.27, 14.396@100.22mph.
Weather was not ideal, low 60s but with 100% humidity. My windows stayed fogged up the whole time. My clutch also slipped on the 1-2 ans 2-3 shift every time. I think I also fried my clutch on the last run trying to launch too high but the new clutch is on the way anyway. I don't want to jinx myself but 13's will definately come in ideal conditions. I am excited to finally trap over 100mph though.
Who has the fastest trap speed for a N/A 4th gen on street tires? Neal?
Cattman Headers
Cleaned air filter
I ran a :
60...2.172
1/8...9.202
mph...77.16
1/4...14.197
mph...100.16
Awesome times! You were putting down some insance #'s with the auto, now your trapping at insane mph's with the manual. Humidity here was terrible also. I think Neal ran high 13's (?) with street tires.
Originally Posted by UNCDooD
what kind of fuel pressure regulator are you running? nice times and very nice trap speeds!
It is a universal OBX FPR. It was cheap, nothing fancy was needed. Instead of getting a SAFC and having to go back to the dyno to tune it, I figured it was easier to bump up the fuel a little because I could test that at the track. The JWT ecu makes it pretty lean on top end, and I am pretty sure with all my mods that I was lean all over the curve. I will probably dyno in the near future anway, to maximize the AFR after some other mods.
where'd you get it from? i might buy one myself. last time i dyno'd the TS ECU had me running pretty lean.
Originally Posted by Dave B
Stupid question but you could post a pic of the FPR and how it's installed. Does it simply replace the OEM FPR?
tank > fuel pump > fuel filter > front fuel rail > rear fuel rail > FPR > tank return
You hook it up with the fuel line coming out of the fuel rail and into the input line of the FPR, and the the out line of the FPR goes to the tank return line. There is also a vacuum port hookup on the FPR.
I have a few bad pics of the FPR on the 2nd page of my cardomain page, but you get the general idea. Hope this helps anyone interested. Link in my sig.
was it a company selling the FPR on ebay or what?
ebay link
Watch out for the seller though, he has alot of negative feedback, and he sent me the wrong item, the auction clearly stated that this was for a blue fpr, and you can see by my pics what color I got.
oh. the red looks better anyways.
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
think this one would work? i mean FPRs are pretty much universal right?
Stupid question #2
I recently replaced my 2001 GrandPrix GTP with a brand new 2004 Maxima SE 5spd auto. I have never been to the track with it yet. The closest track where I live is only 1/8 mile long.
My best time with the completely stock GTP on that track was 9.08. Can I expect to do better with a stock 2004 Max?
Thanks,
Stephen.
Thanks,
Stephen.
Thanks,
Stephen.
Thanks,
Stephen.
9.08 1/8 mile is about 13.9-14.1....you say you ran that stock?
Since I own the Max, I have noticed that it seems a bit shy in the low end torque, but pulls when high revs are reached.
Maybe the 1/8 mile track is not the preferred playground for our rides
Stephen...
Just in case you don't know the GTP is factory SuperCharged and GM claims 240HP@5200 & 280 LB/Ft Torque @ 3600
Maybe I am just to used to looking at maxima time slips, and a 9.0 1/8 is more like a 14.6 or so for a GTP....but I dont' think that is the case
GTPs have a lot more low end then the 04 maxima, I raced one when I was stock and it beat me off the line and in the 1/4. Im not sure if he was modded but I ran a 14.3 and he pulled a 14.1. his traps were high and his 60ft was better but it was a close race.
here is the slip of a Regal GS (same cars as a GTP) that I ran against several times last year at the track. IIRC, he had 2 or 3 sizes smaller pulley, headers and full exhaust. It was also in the low 50's that day....and yes it was at Byron Dragway.
2.15 60'
8.93 1/8 @ 79mph
13.8 1/4 @ 98.97
2.15 60'
8.93 1/8 @ 79mph
13.8 1/4 @ 98.97
KabirUTA13
19
10-17-2015 02:15 AM
pears
09-18-2015 05:25 AM
0m3nc0w
09-11-2015 05:21 PM
