Camber is off by .11 degrees. should I worry?
My right front camber is .11 degrees out of specifications. Should I worry about it?
it's -1.11 and specifications is between -1 and .5 degrees.
I'm lowered on H&R springs and I did change out that axle before. Last time I had an alignment all these were in specifications and nothing has changed on the vehicle besides tires since the last alignment.
Should I worry? Why would it be out?
Probably error in the machines if it was in spec before and it's not now... that much out isn't a problem anyway. you might wear just a tad on the inside tire on that corner, but it won't significantly decrease the life of your tires or anything..
Loosen the lower strut bolts and pull the top of the hub out twards you. (positive camber)
There is enough play in the holes to get you back into spec.
You will need to have your toe set again once you do that.
Just the bottom two on the strut mount--> knuckle.
if you're really concerned about it, call up cattman or stillen or anyone else that sells suspension products and pick up a set of camber bolts. they're $30-40 or so, and you can adjust about 1 degree on them.
carid
09-17-2015 05:00 AM
