Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 03-28-2001, 09:52 AM   #1
MAXDriver
What are the consequences of putting in 3 quarts of 10w-30 and 1 quart of 10W-40 at oil change ?
Old 03-28-2001, 10:11 AM   #2
Quote:
Mixing viscosities is all right. However, Nissan prefers 5W-30. Cold-start engine noise has been attributed to thick oil.
__________________
Daniel B. Martin
Nissan owner and D-I-Y mechanic
Daniel B. Martin is offline   Reply With Quote
Old 03-28-2001, 12:15 PM   #3
OzziSVT
Quote:
100% corect, basically you would end up with a a viscocity of 10W-32.5, which is OK as long as your car can run in those parameters. But if a Maxima is supposed to run 5W-30, then do it or next time you take a corner at high revs you might drop oil pressure low enough to spin a bearing and f*** your engine. Don't screw around by putting in the wrong oil in order to save yourself $15. The consequences could be DISASTEROUS!
Old 03-29-2001, 11:52 AM   #4
Alex9
Service manual lists 10w-30 and 10w-40 for temperature higher then 0 F and 20w-50 for over 50 F. So if you don't drive around the north pole - that's ok. And pressure with the thicker oil is always higher than with 5w-30, no matter what revs are. That's why 5w-50 and 15w-50 recomended for heavy duty driving.
Alex.
Quote:
Old 03-29-2001, 01:54 PM   #5
Engine oil viscosity
Quote:
Originally posted by Alex9
Service manual lists 10w-30 and 10w-40 for temperature higher then 0 F and 20w-50 for over 50 F. ...
Which service manual? Not mine.
__________________
Daniel B. Martin
Old 03-29-2001, 03:48 PM   #6
Points: 11,927, Level: 71
Points: 11,927, Level: 71 Points: 11,927, Level: 71 Points: 11,927, Level: 71
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Re: Engine oil viscosity
i just bought a whole box of mobil 1 synthetic 10W-30 motoroil..is 10W thicker than 5W? also, does this mean my gas mileage will suffer if i use this stuff for summer driving?
VQdriver is offline   Reply With Quote
Old 03-29-2001, 03:49 PM   #7
Alex9
Sorry, it was user's manual for 95 maxima.
Old 03-29-2001, 03:51 PM   #8
I'm needing a caw
Jeff92se's Avatar
Points: 42,809, Level: 100
Points: 42,809, Level: 100 Points: 42,809, Level: 100 Points: 42,809, Level: 100
Activity: 0%
It should be okay. But in the future, try to avoid 10w40 oils if they are dino type. It's a really big viscosity gap for the dino oil to maintain.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 03-29-2001, 04:03 PM   #9
Re: Re: Engine oil viscosity
Quote:
Originally posted by VQdriver
i just bought a whole box of mobil 1 synthetic 10W-30 motoroil..is 10W thicker than 5W? ...
Yes.
Quote:
... does this mean my gas mileage will suffer if i use this stuff for summer driving?
Yes, but by only a small amount. Go ahead and use the oil you bought.
__________________
Daniel B. Martin
Old 03-29-2001, 06:00 PM   #10
Points: 15,282, Level: 79
Points: 15,282, Level: 79 Points: 15,282, Level: 79 Points: 15,282, Level: 79
Activity: 0%
Send a message via AIM to Synki
10w30 and 10w40? I have always used 5w30 in my 92 and 99 maxima. When i used 10w30 in my 99, i lost about 20-30 miles per tank. My manual says to use 5w30 and when i worked at Jiffy Lube, all that was used was 5w30 as well. Just my 2 cents though.
__________________
When Lightning strikes, the Heartbeat stops.
04 SB Lightning 12.4@107 *sold*
04 Vortech Mustang GT
Synki is offline   Reply With Quote
Old 03-30-2001, 04:07 AM   #11
Send a message via AIM to plrod Black 95 SE Send a message via Yahoo to plrod Black 95 SE
I live in FLA and when I use to use 10W30 or 10W40 would experience a little engine noise on cold starts. I now use 5W50 Castrol Syntech and no longer get that noise. Also make sure the filter you use has the valve in it to keep the oil from draining down into the pan. It looks like a spring inside the filter, and it's not on all oil filters which are sold for our cars.
__________________
Been there, done that.
Non-donating ex-owner/member!
plrod Black 95 SE is offline   Reply With Quote
Old 03-30-2001, 06:23 AM   #12
I am using 10w-50 fully synthetic.
__________________
1995 BMW M5(euro) 1995 bmw 318TI(M3 engine) 1994 Mercedes 300ce(winter use)
JDwyer2821 is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
