Go Back   Maxima Forums > Maxima Discussions > General Maxima Discussion
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 05-20-2004, 11:53 AM   #1
Send a message via AIM to nismomaxse97
Driveablity.....Stalling in Reverse?
Hey guys and gals,
97 SE Automatic
Car stalls in reverse, yet once in Drive shows no sign of sputtering or stalling.
Just wondering if anyone has had the same driveablity problem and is willing to share a fix of possible fix.
Thanks in Advance
nismomaxse97 is offline   Reply With Quote
Old 05-21-2004, 03:41 PM   #2
Jatan's Avatar
Points: 13,163, Level: 74
Points: 13,163, Level: 74 Points: 13,163, Level: 74 Points: 13,163, Level: 74
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Does it actually stall (like you would have to restart the car) or does it feel like it's in neutral (the engine just revs)?
I had the neutral thing happen to me. When I would drive the car, it would drive fine, but when I would put the car in reverse, the car would just rev like it was in neutral. My tranny needed to be rebuilt.
This happened when I was going to a meet in Wisconsin. The heat from driving 70-110 MPH caused my dying tranny to die faster... Going to add the tranny cooler soon and going to put in the VB mod later on
Some TSBs that might help: Looking for the 4th gen who put the 350z seats in his car...
If it's actually stalling then I don't know
__________________
07 Maxima SL
Jatan is offline   Reply With Quote
Old 05-22-2004, 06:39 PM   #3
Jatan,
It will actually stall.....The gears are hooking up great so it is not the tranny. However last night I stayed up and cleaned the TB and changed the fuel filter. It has stopped stalling for now. However when in reverse the idle will jump from 750/800 to 1500 and back again. The tack also jumps when in neutral and drive as well. Acceleration is great with no hesitation, but when coasting the car tends to pulse also. It is driveable but I hate how its acting.
I am thinking it may be the fuel pump but I do not know.
thanks for your response
brett
Old 05-23-2004, 04:46 AM   #4
Say Candyman 5 times
CandiMan's Avatar
Points: 13,613, Level: 75
Points: 13,613, Level: 75 Points: 13,613, Level: 75 Points: 13,613, Level: 75
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Quote:
Originally Posted by nismomaxse97
Hey guys and gals, 97 SE Automatic Car stalls in reverse, yet once in Drive shows no sign of sputtering or stalling. Just wondering if anyone has had the same driveablity problem and is willing to share a fix of possible fix. Thanks in Advance
When it was stalling more prominently would it stumble then stall or did it stall out right light someone turned off the ignition?
If it was stumbling and then stalled as soon as you put it in reverse I would probably think somehow the tranny was lugging down the engine causing it to stall. It's kinda like when a torque convertor locks up when in gear waiting at a light. I can't think of anything that's different when you put a tranny in drive compared to reverse, besides the actual internal of the tranny. (valves, clutches, gears, etc)
If it was stalling like someone turned off the key that might be something else, sensors, idle motor, something?
Now you're saying the stalling has stop after cleaning the TB and changing the fuel filter, but now you're getting idle fluctuation in reverse, neutral and drive. I assume you were not getting this idle fluctuation before, just the stalling problem. If that's the case I would concentrate more on the intake and idle control system. Clean the idle motor and EGR valve, make sure your TPS is adjusted properly, everything and anything.
MIKE
CandiMan is offline   Reply With Quote
Old 05-23-2004, 05:33 PM   #5
MIke,
Thanks for the tips, I think it may be the TPS sensor.
I will change the EGR valve as well.
The cars idle or tach has been jumpy the whole time, I just did not
note that the first time.
Thanks again
Brett
MIKE
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
