Who all is running copper NGK's for NA use?
Old 11-25-2003, 07:05 AM
deezo's Avatar
Please sign in.
I'm thinking about going copper my next go round. Which part number are you using?
deezo is offline
Old 11-25-2003, 07:24 AM
STFU n00b!
Matt93SE's Avatar
I'm using the regular NGKs that are meant for the VG. change 'em about once a year and they're great. screw that $9 per plug, I'm going $9 per set!
Dunno if they'll work on the VQ, but I'm happy with them in my VE.
Matt93SE is offline
Old 11-25-2003, 07:31 AM
Maximajism94se's Avatar
same as matt here....
Maximajism94se is offline
Old 11-25-2003, 07:40 AM
Stephen Max's Avatar
If I was NA I would. (I'm boosted and I do.) It's so easy to change the plugs on a Maxima, I don't know why any self respecting car guy would pay for the plats just so he didn't have to change the plugs as often.
Stephen Max is offline
Old 11-25-2003, 08:07 AM
ejj
ejj's Avatar
I did when I was NA. BKR5E IIRC.
ejj is offline
Old 11-25-2003, 08:09 AM
mod or sell?
internetautomar's Avatar
Cheap Asses
internetautomar is offline
Old 11-25-2003, 08:13 AM
STFU n00b!
Matt93SE's Avatar
Why pay 6x as much for something when you're going to change them every year anyway?
Matt93SE is offline
Old 11-25-2003, 08:30 AM
Cheap Asses
Lazy ****
1234567890
Old 11-25-2003, 08:41 AM
skandalouz's Avatar
not on the 3.5s... it's a real pain to change them out....
skandalouz is offline
Old 11-25-2003, 08:46 AM
Not DAVEB the parts guy
Dave B's Avatar
I'm running the NGK coppers and I've run my PB with them. I forget the part number, but just tell the guy you want 6 NGK coppers for your 95 Nissan Altima because the coppers won't be listed for the 95+ Maxima.
Dave
Dave B is offline
Minister of Silly Walks
mzmtg's Avatar
I am. BKR5E-11
No discernable performance difference over the plats. Got em for less than $2 each from Advance Auto Parts.
mzmtg is offline
Old 11-25-2003, 09:27 AM
ejj
ejj's Avatar
Dave
Before I could remember that part number, that's what I did.
FYI you don't need the "-11" part of the part number. That just means they're pre-gapped. If you just get BRK5E's you can gap them yourself. I always re-check and/or re-gap all my plugs anyways.
I change my coppers now about every 10k, or whenever they're out (for compression test, etc). Its just to cheap to pass up.
ejj is offline
Old 11-25-2003, 09:30 AM
99Maxima5sp's Avatar
I was running plats, then i had to switch since i started spraying. Now im running 1-step colder plugs which slightly hinders N/A performance...
Eric
99Maxima5sp is offline
Old 11-25-2003, 09:45 AM
Sprint's Avatar
Sprint is offline
Old 11-25-2003, 10:14 AM
hokiemax's Avatar
I run copper NGKs in mine too. they're great. forgot the part number though.
hokiemax is offline
Old 11-25-2003, 11:52 AM
SLOW
Nealoc187's Avatar
Platinum plugs are a waste. 60k miles for $8 or 30k miles for $2. Copper is a superior conductor to platinum anyhow though you won't see any performance difference.
Nealoc187 is offline
Old 11-25-2003, 12:17 PM
voltman's Avatar
I thought the point of fewer plug changes was because the aluminum of the VQ block was more prone to damage from constant threading. I read that somewhere.
voltman is offline
Old 11-25-2003, 12:40 PM
Just don't overtighten. All it takes is about 2/3 to 3/4 of a turn past finger tight to crush the washer.
Old 11-25-2003, 12:51 PM
V^___^V
happyricefob's Avatar
Eric
yea i was planning to spray, but not anymore so i'm goin back to platinum tip pretty soon...
happyricefob is offline
Old 11-25-2003, 12:56 PM
nismology's Avatar
Is this with or without anti-seize?
nismology is offline
Old 11-25-2003, 01:01 PM
The anti-sieze won't change how much of a turn it takes to crush the washer - that is determined by the thread pitch. It's a good idea to always use anti-sieze, though, since it prevents galvanic corrosion between the aluminum head and the steel spark plug. Then again, if you use coppers you're not going to give galvanic corrosion long enough time to build up to any significant level. I'd still use it, though.
Old 11-25-2003, 01:02 PM
Sprint's Avatar
http://www.vqpower.com/v2/modules.ph...howpage&pid=33
Nissan Part # for these plugs are 22401 - 50Y05
Sprint is offline
Old 11-25-2003, 01:50 PM
deezo's Avatar
To do the job right, get a torque wrench. You won't go wrong and won't have to worry about overtightening.
deezo is offline
Old 11-25-2003, 01:51 PM
I'm needing a caw
Jeff92se's Avatar
And use some anti-seize on the plug threads.
Jeff92se is offline
Old 11-25-2003, 01:57 PM
Maximam's Avatar
I am running copper NGKs.
Maximam is offline
Old 11-25-2003, 02:26 PM
voltman's Avatar
I'm not personally worried about it. It's just something I've read.
voltman is offline
Old 11-25-2003, 03:48 PM
Y2KSESteve's Avatar
I've run nothing but copper plugs in my maximas..
Y2KSESteve is offline
Old 11-25-2003, 04:17 PM
hakk97se's Avatar
I paid a lot for my NGK plat's and when I was working on my car with Turbo95Max he mentioned that copper gives a better spark and it's not hard to change em on the VQ30. The only difference is price and the fact that you dont have to gap the plats.
Next time around I will be going NGK copper.
hakk97se is offline
Old 11-25-2003, 05:26 PM
mod or sell?
Y would you change them every year?
I pull em, check em, Make sure they're all good and the car is running right and slap em back in.
Old 11-25-2003, 08:30 PM
Sports Button FTW
meccanoble's Avatar
i will go copper next go around but i'm worried about gapping. How hard is it to gap?
meccanoble is offline
Old 11-25-2003, 08:45 PM
OG
SmoothMax's Avatar
Haven't sprayed in some time now, however I still run the NGK coppers.
SmoothMax is offline
spirilis's Avatar
If the NGK V-Power copper core plugs for the Maxima are similar to the ones I used in my old Mazda, you won't need to gap the plugs at all. Gapping is easy as hell though; buy a wire plug gap gauge (for cheap at Advance Auto or Autozone, they may even have them up at the cashier counter in a stack) and try to stick the proper size wire loop (.044") through the plug gap... if it's too tight, open it up, if it's too loose, close it down a little... they have a little notched tool on the gauge for bending the ground electrode (setting the gap involves merely bending the ground electrode to widen/shorten the gap).
spirilis is offline
Old 11-25-2003, 10:25 PM
Future Camaro SS owner
MyownNismo's Avatar
I got about 45,000 miles on my ride and am going to change my spark plugs soon is there a write-up on how to change these I haven't had to change them yet and the rears look like a PITA. Would you reccommend the copper plugs for NA use. or what would the best ones be for my car with my mods.
MyownNismo is offline
Old 11-25-2003, 11:45 PM
I30tMikeD's Avatar
NGK coppers for me.
I30tMikeD is offline
Old 11-25-2003, 11:46 PM
davebond007's Avatar
BKR5E-11's on my VE with 166k.
Runs great.
davebond007 is offline
Old 11-26-2003, 12:06 AM
MrGone's Avatar
I am
love it!
MrGone is offline
Old 11-26-2003, 12:08 AM
KLoWnPR109's Avatar
I am as well. Probably time to change them. Although, I have no clue how to
KLoWnPR109 is offline
Old 11-26-2003, 02:49 PM
I still wouldnt go back to plats simply because their so damn expensive. Also, coppers a better conducter as previously stated.
And slightly OT, but why arent you gonna spray anymore?
Eric
Old 11-26-2003, 02:56 PM
MrGone's Avatar
I think I'm going to put coppers in my Dads 2000SE today. Has NGK plat's in there now.
MrGone is offline
captchaos
03-15-2016 12:18 PM
Excalibur23
10-13-2015 04:33 PM
JoshG
51
09-21-2015 10:41 PM
Quick Reply: Who all is running copper NGK's for NA use?
