"scratching" sound on ignition start
Old 05-15-2003, 01:58 PM
shobuddy's Avatar
I don't know about other cars but when I start my 03 SE Max, it makes a scratching sound for like a second right after i turn the ignition. This happened on my 91 sentra too. Havent' paid attentino to it on other makes/models but does anyone know what thats about?
shobuddy is offline
Old 05-15-2003, 02:35 PM
98maxsel's Avatar
its the starter.
98maxsel is offline
Old 05-16-2003, 05:43 AM
shobuddy's Avatar
so its on all cars?
shobuddy is offline
Old 05-17-2003, 12:03 AM
lophix's Avatar
it's the starter.
lophix is offline
Old 05-17-2003, 01:01 AM
Rockin' VK56!!
juani's Avatar
when i had same problem, mine was caused by belts
juani is offline
Old 05-19-2003, 07:16 AM
mingo's Avatar
my starter has been acting up lately too, maybe the gear isn't retracting fast enough.. but as long as it still cranks i'm happy =D
mingo is offline
Old 05-19-2003, 02:39 PM
Old Maxima Legend
Ceasars Chariot's Avatar
mine2
Ceasars Chariot is offline
Old 05-19-2003, 03:07 PM
Eric L.'s Avatar
Does it happen immediately after the car has already started? If so, its the starter.
Eric L. is offline
Old 05-19-2003, 04:06 PM
Frank Fontaine's Avatar
Re: "scratching" sound on ignition start
Since you have an '03 just have the dealer take a look at it. It sounds like the starter, which is a known issue with the 4th gen, I didn't know the newer Maxes had the problem too. It could be belts too if there's moisture in the air but I doubt that's your problem. My car is 5 1/2 years old and about 6 months ago I too had that noise. Then I found from the motorvate website that the 4th gen starters had inadequate grease inside causing the drive shaft of the starter to get stuck. My problem went away once the temps warmed up--I'm sure it will be back by next winter. These parts are outrageously priced, I think over $300 in parts alone to get the genuine replacement, so I urge you to take care of it under warranty. From what I hear there is no true "new" starter, alternator, etc. as a replacement. They use various suppliers and they are of various qualities, but put it in a new box with the same part #. Good luck.
Frank Fontaine is offline
Old 05-20-2003, 05:42 AM
shobuddy's Avatar
it happens immediately after i start and since it happened on the sentra too, i'm not too concerned. just was curious as to what it was.
thanks for all the replies.
shobuddy is offline
Old 05-20-2003, 07:44 AM
Not DAVEB the parts guy
Dave B's Avatar
My 96 has done it for over two years now. OEM starter.
Dave
Dave B is offline
Old 04-11-2007, 05:43 PM
shobuddy's Avatar
Dave
http://www.nissanhelp.com/Ownership/.../NTB03-060.htm
shobuddy is offline
rnb754
09-14-2015 11:39 PM
TheMafia
09-04-2015 08:26 AM
trungg86
09-04-2015 04:58 AM
Quick Reply: "scratching" sound on ignition start
