bodyshop turned my car PINK.. HELP !
I brought my car back from the bodyshop ( I needed a new hood), and guess what. There are micro sized pink particles, or dust, or paint droplets, whatever you wanna call it, its all over my car. Its not so obvious at first sight, but when you touch the car, its very scratchy, and from a certain angle, the car LOOKS FRIGGIN PINK... I'm so ****ed.. how do I get this stuff off? Someone mentioned using a meguiar clay bar or something.. detailing experts, please help. thank you.
Re: bodyshop turned my car PINK.. HELP !
wtf
Bring the car back and b i t c h at 'em
Originally posted by gtr_rider
jeff must be proud
jeff must be proud
Hokiemax you should be able to take it out with Rubbing Compound or Meguiar's Clay Bar (probably should try this one first), but if I were you I would take it straight back to the shop. No need for you to spend hours working on the car when it's not your fault.
-Cyrus
Originally posted by tomj
I know this sucks, but I wouldn't bring it back to them. If they can't spray correctly what makes you think they will fix your car correctly. I wouldn't trust them. Do it yourself.
Not only would I take the car back, I would stay there and watch them every minute. If the clay bar will work, it will be much less abrasive on the paint. I certainly wouldn't want the body shop to use an abraisive rubbing compound to quickly remove the overspray.
As everyone else said.. you didn't cause the problem, THEY did. let THEM fix it. they'll have the buffing and polishing equipment necessary to clean it up quickly and properly. don't waste a second on it yourself. just call them up and tell them it's got overspray all over it and make an appointment for them to fix it.
First of all, meguiars clay sucks. Try mother's or clay magic. Secondly, most retail grade clay bars are meant for mild overspray situations or removing road contamination. You may have to step up to a professional cut clay for this situation. I strongly urge you to post your problem at www.autopia.org and let the experts there take care of it.
Compounding your car will NOT help. It is for removing surface imperfections not, stuff ON the surface. Think about it, you're taking an abrasive compound and working a layer of your clear coat off. All the while you are rubbing in these micro droplets of dried pink paint deeper into every crack and crevice of your finish. The proper procedure would probably be to clay the car, then go over with a light cut polish to restore the finish, and cover it up with a wax.
I would not take it back to the same shop if I were you. Obviously they do not have the 'show car' mentality. I would make them aware of the problem, take photographs. And then go to a professional detailer and attempt to have him fix the problem for you. Afterwards, I would bring pictures of the 'after' and an invoice with you back to the original guy who screwed you, and make him reimburse you. If he refuses, threaten to file a BBB complaint and pursue a civil suit.
Good luck.
Good luck.
Lakersallday24
06-16-2019 01:35 AM
